Coolant?
rpg
PostPosted: 21:37 - 08 May 2007    Post subject: Coolant? Reply with quote
hi, can i buy coolant ready to pour into the radiator, or is it a mix of solutions? Sorry to be dense, im used to 1960s vintage motorcycles! Bike is VFR400 NC30.
many thanks
Walloper
PostPosted: 22:34 - 08 May 2007    Post subject: Reply with quote
You want a 50% solution of a glycol based antifreeze.
Most have about 2% inhibitor too.
But check.
You can get pre mixed but it's very easy to do your self.
Bottle of drinking water. (if you don't trust wot cums oot yer taps.)
1/2 Antifreeze
1/2 water
Mix together
Add to radiator neck.
Leave it for a bout an hour to make sure all the wee bubbles have came to the top and add some mixture to top off.
(Squishing the hoses helps the bubbles thing)
The level in the expansion tank should be what you are aiming for.
It has been washed out hasn't it?
Stiffler
PostPosted: 23:23 - 08 May 2007    Post subject: Reply with quote
Really you should use Deionized water. You can buy premixed stuff at Halfords or as Walloper says just mix your own at 50:50.
Once you've drained old coolant the Haynes suggest you use a flushing solution, then fill up the system with water and run it until the bike is at normal temperature drain again, then add you coolant.
Fill it up to the base of the filler cap, squeeze the hoses (too and from radiators) tilt the bike a bit to will help. Then run the bike with the cap off, let it warm up and give it a few tugs on the throttle (up to 5k) to help clear out any trapped air. Top up the radiator if needs be and the expansion tank to the upper limit. Replace the Radiator cap and you're good to go!
Go for a short ride and check levels when you get back Cool
Tim
Current Bikes - Kawasaki ZX-6R (636) | BMW G650GS
Jamie S
PostPosted: 00:12 - 09 May 2007    Post subject: Reply with quote
AFAIK you can buy premix , it should be good enough for most modern bikes. Thumbs Up
PostPosted: 08:52 - 09 May 2007    Post subject: Reply with quote
Pre-mix is a con, it's cheaper to get de-ionized water and concentrate, then mix it yourself. At least it was a con last year. Wink
Finglonga
PostPosted: 11:26 - 09 May 2007    Post subject: Reply with quote
I just used to use what came oot me Wink tap and never had any problems, depends if you live in a hard water area though.
Andy Sez....
F.Y.Y.F.F.
Wooly R6
PostPosted: 13:32 - 09 May 2007    Post subject: Reply with quote
I got some Silkolene pro cool not long ago - you just pour it in!!!!
I would rather buy the mix yourself stuff but i liked the look of the pro cool.
R6 has been sold - 2004 Honda VFR VTEC now sold too - no bike at the moment
PostPosted: 16:41 - 09 May 2007    Post subject: Reply with quote
You should see the inside o' me kettle, didn't fancy my engine internals looking like that! Laughing
The last post was made 19 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.38 - MySQL Queries: 13 - Page Size: 56.81 Kb
