rev limiter?
MaybeGuy
PostPosted: 16:10 - 09 May 2007    Post subject: rev limiter? Reply with quote
yes, point and laugh... another CB400 superdream thread.
my problem THIS time is i think the rev limiter is set to 6krpm.
if i rev the bollocks off it, it bounces on 6k. ANNOYING when riding it.
anyone got any super cool tips for someone who doesnt know anything about tackling the adjustment of a rev limiter or what one looks like or ANYTHING about them apart from they're annoying if set wrong?
veeeffarr
PostPosted: 17:01 - 09 May 2007    Post subject: Reply with quote
Would a superdream have a rev limiter? :S
PostPosted: 17:06 - 09 May 2007    Post subject: Reply with quote
I thought the limiter was hard wired into the CDI, so it can't be changed easily.
MaybeGuy
PostPosted: 17:58 - 09 May 2007    Post subject: Reply with quote
bugger. why would it be bouncing off 6k then? :S
Jamie S
PostPosted: 18:24 - 09 May 2007    Post subject: Reply with quote
Sounds like the timing is set wrong.
MaybeGuy
PostPosted: 18:34 - 09 May 2007    Post subject: Reply with quote
reckon if i ripped one off a cb250 it would work?
PostPosted: 18:41 - 09 May 2007    Post subject: Reply with quote
What a CDI??
Why not just reset the timing.
MaybeGuy
PostPosted: 18:56 - 09 May 2007    Post subject: Reply with quote
a 250 CDI doesnt work, just toiled for 10 mins in the rain to get angry splutters so i swapped back Very Happy
how would i reset the timing?
(i can build the things, but adjusting them is new to me Very Happy)
just so im sure, a CDI is the little box under the tank opposite the box the spark cables are attatched to?
cheers
PostPosted: 19:28 - 09 May 2007    Post subject: Reply with quote
i really couldn't tell you tbh. Sounds about right though.
Did you do any work on the bike before it started stuttering at 6k?
only way the timing would get out of whack would be if you'd had the cam shafts out.
MaybeGuy
PostPosted: 19:31 - 09 May 2007    Post subject: Reply with quote
the top cover on the engine is different to the rest, so it may well have had the cam shafts out.
it isnt a sudden problem, its been there since i got the bike.
i take it its not as simple as pressing a 'reset' button is it?
PostPosted: 19:41 - 09 May 2007    Post subject: Reply with quote
nope, i think it involves taking the cams back out and putting them back in the correct position. That is assuming it's the timing. Although i'm not sure what else it could be.
CDI perhaps? Coils?
Sorry I can't help you more mate.
MaybeGuy
PostPosted: 20:22 - 09 May 2007    Post subject: Reply with quote
bugga, ah well, ill sort it out some other time.
cheers for the help.
Davo
Davo To The Rescue!
PostPosted: 22:46 - 09 May 2007    Post subject: Reply with quote
Is it an jap import? If so have you been messing around with the restriction wires? (e.g. the ones in the back of the speedo that kicks in at 180kph)
Had a similar issue on the CB-1 when I tried to derestrict it on the cheap, only to find it would stop accelerating at 6,000 rpm.
PostPosted: 22:49 - 09 May 2007    Post subject: Reply with quote
If it is a proper old CB400N Superdream (Wetdream, Nightmare) then first thing is to check the rev counter is reading correctly.
Cam timing could be out, but only likely if someone has taken it to pieces and put it back wrong.
MaybeGuy
PostPosted: 22:56 - 09 May 2007    Post subject: Reply with quote
yes, the rev counter is mechanical, got one of those groovy spinning cables Very Happy
i dont think its reading wrong, because i physically feel it lurch forwards as it gets to 6k.
if someone has put it back together wrong, would that still be the case if it revs perfectly up to 6k?
ive ridden bikes with rev limiters on before, and it feels exactly the same, im just not sure how the rev limiter works.
PostPosted: 23:00 - 09 May 2007    Post subject: Reply with quote
Mechanical ones can be inaccurate.
It would likely run poorly at low revs as well if the cam timing was out.
Might be worth going somewhere with nobody around, stick a timing light on the bike and try revving it in neutral. See if either plug is cutting out once past 6000rpm.
MaybeGuy
PostPosted: 23:27 - 09 May 2007    Post subject: Reply with quote
thanks kickstart, ill try and get hold of some of them.
it revs out at 6k in neutral and in gear.
if one spark isnt sparking past 6k, would that suggest bad plugs?
MaybeGuy
PostPosted: 01:51 - 23 May 2007    Post subject: Reply with quote
ok, im now beginning to steer away from the idea that it could be cam timing...
rather than at high revs it spluttering, its doing it as i turn the throttle more.
eg: if i go very slowly from 1000 to 6000 its ok, but if i fully neck it it bogs down and struggles for 3000.
this suggests a fuelling problem/air intake right?
i dismantled my airbox and had a lil' ol' lookie.
what i found was another smaller filter inside the filter. this was damp... normal?? it smelled a bit like petrol, not entirely though.
are air filters supposed to be 100% dry?
i also took out the metal mesh gauze covering the carbs because i checked my choke wasnt stuck, cant get the bassard back on Very Happy
any ideas? it seems physically impossible!
it wont affect the bike, so im not too bothered.
cheo
bish777
PostPosted: 12:03 - 23 May 2007    Post subject: Reply with quote
blocked filter would cause your problems.
I'd not run the bike without the airbox for now as thats swapping one problem for another.
Get the airbox on and try taking it for a spin without the filter, if the bike runs properly youve solved the problem.
GSXR1100J
Jamie S
PostPosted: 12:12 - 23 May 2007    Post subject: Reply with quote
! NEVER RUN A BIKE WITH NO AIR FILTER FOR MORE THAN A FEW MILES !
hmmmnz
PostPosted: 12:35 - 23 May 2007    Post subject: Reply with quote
OK JAMIE
first thing i would do would be change out the plugs for new ones, then if still being a pain, see if one side is still cutting out.
change the coils over and see if the other side is cutting out, if it is then its a coill issue and best bet is to replace the coil,
if its still the same side with the coils swapped then have a look at the wiring,
make sure you are getting good contact at the join where the 2 coils get there power.
ill post a super dream diagram in a bit
the humans are dead
I kick arse for the lord
bish777
PostPosted: 12:40 - 23 May 2007    Post subject: Reply with quote
Thats why i said take it for a spin, you dullard. Not go for a 800 mile round trip......
GSXR1100J
bish777
PostPosted: 12:44 - 23 May 2007    Post subject: Reply with quote
It may be a good idea to replace the coil(s) as a matter of course, its an old bike now.
Pattern coils are pretty cheap.
If the HT leads and caps are quite a few years old they are bound to be breaking down!
GSXR1100J
The last post was made 19 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.86 - MySQL Queries: 13 - Page Size: 131.88 Kb
