Problem... help!
Syfoon
TRUCK!!!
PostPosted: 15:43 - 20 Sep 2003    Post subject: Problem... help! Reply with quote
OK, riding along, doing about, 40ish. I go to change down gear, but my gearlever isn't there...
I look down, and its hanging a lot lower then it should be. Had to ride home in 3rd.
Got home, can see its hanging WAY below where it should be, and isn't responding well to being clicked up/down (Clicking up usually puts it back in its normal place, but clicking down just drops it into its broken position.
Any help/ideas?
Not here...
McJamweasel
BCF Junkie
PostPosted: 15:51 - 20 Sep 2003    Post subject: Reply with quote
Sounds like the pinch bolt has come undone/come out. Have a look.
zaknafien
PostPosted: 15:53 - 20 Sep 2003    Post subject: Reply with quote
Yeah happened to me, the threads had gone on the lever i tried tightening the bolt but it just slipped again a week later.
I eventually got a bigger bolt and screwed it in as tight as possible, due to it being bigger it helped the rod that sticks out to grip.
02 Firestorm.
Syfoon
TRUCK!!!
PostPosted: 15:54 - 20 Sep 2003    Post subject: Reply with quote
What do I need to do? :S.
Pinch bolt?
/me is as technical as a plate of chips Sad.
Not here...
TiN
Pocket Tin
PostPosted: 15:56 - 20 Sep 2003    Post subject: Reply with quote
It's the nut/bolt on the end(s) of the gear linkage rod. Just spin the rod clockwise to tighten it, and spin the nut(s) so that they lock up to the ends of the rod.
TiN
dotgems.net
McJamweasel
BCF Junkie
The end of the gear lever should be split, with a bolt running through it to pull the ends together to grip the selector spindle. Check the bolt is there and either replace or tighten it.
TiN
Pocket Tin
PostPosted: 16:00 - 20 Sep 2003    Post subject: Reply with quote
Ok, so I thought that we were talking about the linkage rod working itself loose. I had a similar episode after I installed my rearsets on the Blade. I forgot to tighten up the nut, and I was just slowing to pull off of the M'way when I noticed that my footpeg had become more "racy" (Razz). When I finally found a safe place to stop, the nut was literally about half a turn away from coming off completely. Now that would've been inconvenient.
TiN
dotgems.net
McJamweasel
BCF Junkie
PostPosted: 16:02 - 20 Sep 2003    Post subject: Reply with quote
I thought it the lever was attatched directly, same as on mine.
TiN
Pocket Tin
PostPosted: 16:13 - 20 Sep 2003    Post subject: Reply with quote
You're probably right mate. I can't remember much about the NSR. Confused
TiN
dotgems.net
Syfoon
TRUCK!!!
PostPosted: 17:38 - 20 Sep 2003    Post subject: Reply with quote
Well, took the fairing off for better access to the bolt.
Got Mister 8mm spanner from my big red toolbox.
Went to tighten the bolt, but its rounded off.
What to do now?
Not here...
TiN
Pocket Tin
PostPosted: 17:54 - 20 Sep 2003    Post subject: Reply with quote
Syfoon wrote:
What to do now?
Poke Luke, lots. Razz
Erm, try to cut a groove into the head of the bolt and use a screwdriver to remove it. Then replace said bolt.
TiN
dotgems.net
Luke_Retrofly
Silly Lesbian
PostPosted: 18:32 - 20 Sep 2003    Post subject: Reply with quote
hi
TiN wrote:
Syfoon wrote:
What to do now?
dont look at me i never touched that bolt :S
Luke
Flounced - Long overdue
Fuck you bitch I'm in the top 10 list I can do the what the fuck I want!
bonceunounce This post is not being displayed because the poster is banned. Unhide this post / all posts.
ilovens125f's
PostPosted: 12:25 - 21 Sep 2003    Post subject: Reply with quote
You need to drill out the rounded
bolt and put a new one in.I did this
and it worked fine afterwards.... Mr. Green
Kev the Ns125F lover!!
!!!Dont ignore me!!!
Syfoon
TRUCK!!!
PostPosted: 16:49 - 21 Sep 2003    Post subject: Reply with quote
Gonads.
Got the rounded bolt off. Although waiting was a small suprise.
The teeth on the inside of the gearlever have pretty much all gone, most of the inside is smooth as arseholes.
Looks like a trip to Honda or somewhere else is needed for a new gearlever Rolling Eyes.
S'pose I could get a new rear brake lever while I'm there too Razz.
Not here...
McJamweasel
BCF Junkie
PostPosted: 19:35 - 21 Sep 2003    Post subject: Reply with quote
I have one from the RK going spare, if its the same then you can have it for a very reasonable price! Razz
Syfoon
TRUCK!!!
PostPosted: 19:48 - 21 Sep 2003    Post subject: Reply with quote
bonceunounce wrote:
u need a big pair of molegrips and need to learn bodging skills Razz
Oh, I've got bodging skills Wink. See here Razz.
Jammy, check to see if its the same, might consider it Razz.
Zim says that he might have one spare from his NSR, so whichever works, it looks like I'll be back on the road soon. Smile
Not here...
The last post was made 22 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 97.22 Kb
