carb balancing advice please
timjim
PostPosted: 21:15 - 09 May 2007    Post subject: carb balancing advice please Reply with quote
Ive just invested in a decent set of carb gauges and want to balance my carbs ..bloke at work did mine ages ago,but sold his gauges...what i need to know is
1.anyone else do there own balancing?
2.what do you use as a dummy tank?
By the way its on a 96 Bandit 6 .thanks..any info/advised welcomed graciously.Tim Thumbs Up
PostPosted: 21:21 - 09 May 2007    Post subject: Reply with quote
I have some and use them. Tend to use a large syringe with the plunger pulled out as a fuel reservior.
Make sure you blank off the vacuum line to the fuel tap.
Ichy
PostPosted: 21:38 - 09 May 2007    Post subject: Reply with quote
I use the original tank but with an extra long fuel line and the tap set to prime.
Do you have a twin or quad gauge? What make?
timjim
PostPosted: 22:01 - 09 May 2007    Post subject: carb balancing Reply with quote
4 dial gauge set up,made by a company called Trident..had some excellent reviews of them,BIT pricey at just over a ton.
Ichy
PostPosted: 22:48 - 09 May 2007    Post subject: Reply with quote
If you want to spend a bit more money you could get one of these auxiliary fuel tanks
Paddy Blake
PostPosted: 23:26 - 09 May 2007    Post subject: Reply with quote
I know I have said it before some where but don't put the choke on while
the gauge is connected.It can mess up the gauge and it will be useless.
Paddy.
xlfive
PostPosted: 23:46 - 09 May 2007    Post subject: Reply with quote
2lt coke bottle conected to a hose siliconed into the the bottom of the bottle and hung from the garage door works ok for me Wink
The last post was made 19 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 51.35 Kb
