Squeaky Back Break (NSR)
SilvaRizla
PostPosted: 17:51 - 10 May 2007    Post subject: Squeaky Back Break (NSR) Reply with quote
Hi,
I've noticed my back break has been squeaking, I know it isn't the pads because I've already changed them. (Not especially, they were wearing thin).
What else would cause the breaks to squeak?
Thanks
Silva
I'm Ivan Dobski the Meatsafe Murderer only I never done it, I only said that I done it so they'd take the truncheon out of my bottom
Jebus
PostPosted: 18:50 - 10 May 2007    Post subject: Reply with quote
id suggest i gave them a good clean, use copper grease on the back of the pads and make sure that and shims are fitted if they are meant to be there.
2nd time around Smile CBT: 8/9/11
125 Varadero
PostPosted: 18:54 - 10 May 2007    Post subject: Reply with quote
Contaminated disk.
Crap got into the old pads and onto the disk, then while you fit the new pads the crap on the disk rubs off onto the pads and makes the squeak again, it's happened to me before.
Best thing to do it get used to it, or sand your pads and attack your disk with brake cleaner/diesel/meths/ petrol so get the contamination off it.
adamj
PostPosted: 19:28 - 10 May 2007    Post subject: Reply with quote
I've had it happen to me and was told to file a chamfer on the pads, something to do with rough edges on the disc.
Never tried it in the end just delt with the noise, however I did try cleaning it a lot and it was only a temporary solution to the problem.
Prehaps someone else could shed some light as to if this works?
Finglonga
PostPosted: 19:30 - 10 May 2007    Post subject: Reply with quote
BRAKE!
Andy Sez....
F.Y.Y.F.F.
moonym20
PostPosted: 09:46 - 14 May 2007    Post subject: Reply with quote
a chamfer on the pads works well, as said place a good amount of copper grease on the back of the pads and give the disk a real good clean, that should get you sorted Thumbs Up
A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot Smile
The last post was made 18 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 47.4 Kb
