Indicators Troubles
Mini_Stalk
PostPosted: 11:38 - 11 May 2007    Post subject: Indicators Troubles Reply with quote
The Indicators on my piaggio zip 50 dont work please could people shed some light on possible problems.
many thanks
David
SR 125 Rat
D O G
PostPosted: 11:54 - 11 May 2007    Post subject: Reply with quote
Fuse? Bulbs? Faulty switch. If they all don't work I would suspect a fuse or the main switch.
mattjs895
PostPosted: 11:55 - 11 May 2007    Post subject: Reply with quote
is the battery charged, if so then you may find that the relay has gone, best way to check this is to get a voltmetre to check if any power is going to the relay, if it is then, more than likely you will need a new one.
hope this helps
matt
Mini_Stalk
PostPosted: 12:07 - 11 May 2007    Post subject: Reply with quote
i have tryed the fuse, swich, battery and i has no relay. what else could it be.
david
SR 125 Rat
mattjs895
PostPosted: 12:27 - 11 May 2007    Post subject: Reply with quote
are all the wires are connected properly.
sagiliam
PostPosted: 13:19 - 11 May 2007    Post subject: Reply with quote
Check all the earths on your bike.
I you sure you dont have a relay?
Ls
Mini_Stalk
PostPosted: 20:05 - 11 May 2007    Post subject: Reply with quote
Tryed all of them but still no joy
SR 125 Rat
Paddy Blake
PostPosted: 20:49 - 11 May 2007    Post subject: Reply with quote
It must be the relay.If you had no relay the indicators would not flash
They would just stay on or off.
Paddy.
Mini_Stalk
PostPosted: 13:05 - 12 May 2007    Post subject: Reply with quote
Paddy.
I cant find a indicator relay on the bike or the wiring diagrams, the only one there is is the starter relay.
David
SR 125 Rat
cheekythomas
PostPosted: 22:02 - 12 May 2007    Post subject: Reply with quote
Nope theres no indicator relay... its all built in the regulator assy Wink (Finned metal box under the LH rear side panel)
Is battery charged and dash lights up, horn works etc?? If yes then could be... if other things dont work as well, but battery and fuse is ok, older zips 2000-2004 had a habit of the cables under the floor boards breaking...
Mini_Stalk
PostPosted: 22:13 - 12 May 2007    Post subject: Reply with quote
The lights work and the horn everything appart from the indicators. Mad
David
SR 125 Rat
cheekythomas
PostPosted: 22:27 - 12 May 2007    Post subject: Reply with quote
Sounds like a regulator failure then!
Take the panel off and stick a multimeter onto the black/blue wire with ignition on and it should be a pulsing 12v supply.... if not its dead. Wink
cheekythomas
PostPosted: 22:30 - 12 May 2007    Post subject: Reply with quote
https://img412.imageshack.us/img412/2299/untitledtn1.png
nick606
PostPosted: 22:37 - 12 May 2007    Post subject: Re: Indercater Troubles Reply with quote
many thanks
David
hehehe
Paddy Blake
PostPosted: 00:35 - 13 May 2007    Post subject: Reply with quote
[quote="cheekythomas"]Nope theres no indicator relay... its all built in the regulator assy Wink
So there is no relay but it is built in.So there is a relay.
Just messing with you.
Good call on it.
Paddy.
cheekythomas
PostPosted: 09:46 - 13 May 2007    Post subject: Reply with quote
Nope no relay at all... look at the diagram and see where the feed comes from.. is there a relay shown even internally?? Nope...
The system works by always providing a 12v pulsed feed, but not just when the indicators are on, its there all the time, the indicator switch then feeds it when needed to the lights...
...where as a relay only pulses its 12v feed when needed.
But i get what ya saying! Laughing
matthab
PostPosted: 10:00 - 13 May 2007    Post subject: Reply with quote
were they working before or after you hit the bush Laughing
2005 - 2006:Peugeot jet force 50 TDSI (sold)
2006 - Present: Yamaha YBR125 06 (extras:pilot sporty tyres and screen)
cheekythomas
PostPosted: 12:19 - 13 May 2007    Post subject: Reply with quote
Hit the bush Shocked
Oh the whole story is coming out now! Shocked
Mini_Stalk
PostPosted: 12:25 - 13 May 2007    Post subject: Reply with quote
They did not work before that.
SR 125 Rat
cheekythomas
PostPosted: 12:46 - 13 May 2007    Post subject: Reply with quote
Check the voltage on the Black/blue wire... if thats ok chances are its a dead switch.
Mini_Stalk
PostPosted: 15:20 - 13 May 2007    Post subject: Reply with quote
Will do
SR 125 Rat
The last post was made 18 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 107.83 Kb
