Kick start disconnected ????
popeye
PostPosted: 23:57 - 11 May 2007    Post subject: Kick start disconnected ???? Reply with quote
Hello, i have just bought my son a Derbi 50 supermoto and when he stalled at the lights he kicked it and pulled off leaving the kick start stuck down on the footrest, he noticed after a few hundred yards because of the noise and sprang it back but it still made the noise but now seems disconnected completely. Any ideas what i need to do and what part/s may need replacing ? Confused
Paddy Blake
PostPosted: 00:19 - 12 May 2007    Post subject: Reply with quote
Is the kick start staying up or does it fall down.It maybe the spring or the
sprocket.If the kick start is returning then the sprocket might be missing
the teeth.Not a big job but I dont know the price of the parts.It cant be
much.
Paddy
popeye
PostPosted: 07:10 - 12 May 2007    Post subject: Reply with quote
The kick start springs back fine, it just doesn't engage with the engine and he has found if he lets it go all the way back it whines but if he pushes it back a fraction it stops, so he has taped it back and bumps it at the mo.
kiers
PostPosted: 10:18 - 12 May 2007    Post subject: Reply with quote
how did you manage to get a massive, flickering avatar? :S
'but this wasn't any ordinary clio197.this was the SUPER DUPER version.
ooh i can't wait for the next instalment of superluke and his tales of skullduggery.' - lurker 27 sep 2008
Catalyst
PostPosted: 10:26 - 12 May 2007    Post subject: Reply with quote
ive got an Aprilia SX50, its the exact same bike, engine etc. so if you need parts they would also fit, not sure how it broke? my kick start usually springs up unless the bike hasnt started
|--Previous--|:2007 Aprilia SX50...Neutral--Current--|: 2007 Kawasaki ER-6N
SlimRick - I can cook really well - but it's a useless skill, as I'm not a woman and it's their fucking job!
popeye
PostPosted: 15:17 - 12 May 2007    Post subject: Reply with quote
Thanks people i will have a look during the week and post a picture perhaps. Saw somewhere a kickstart shaft is £43+ vat. About the avatar i was politely told i was naughty and had wrist slapped. Mr. Green
cagiva gezzer
PostPosted: 16:34 - 12 May 2007    Post subject: Reply with quote
Its not the same as the aprilia.
Drain the gearbox oil, remove the coolant pipes and clutch cable. Remove all the bolts (noting where they go) and have a look at the kickstart shaft. Prob just sheared some plastic teeth off or pulled the spring out of place.
If you take a look on the derbi forum you'll find a manual.
popeye
PostPosted: 19:09 - 12 May 2007    Post subject: Reply with quote
Brilliant thanks for that, i will have a look. Derbi forum i will google i presume ? Thumbs Up
cheekythomas
PostPosted: 21:50 - 12 May 2007    Post subject: Reply with quote
Newer ones are the same... since piaggio brought Aprilia they all use piaggio engines now... so the 2006 onwards SX50s have the later spec derbi engine fitted! Wink
Catalyst
PostPosted: 13:02 - 13 May 2007    Post subject: Reply with quote
yep, i've got a 2007 SX50 so it's the same, even looks the same apart from 1 or 2 small differences.
popeye
PostPosted: 16:43 - 16 May 2007    Post subject: Reply with quote
Thought i would mention, i have wiggled the kick start about and after a bit it will engage and kick over so could it be an easier fix maybe ?
The last post was made 19 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 71.54 Kb
