Vibration/knocking coming from rear wheel (Hornet)
dabigginger
PostPosted: 22:56 - 15 May 2007    Post subject: Vibration/knocking coming from rear wheel (Hornet) Reply with quote
When riding along at around 40-50mph on my Hornet (2000 model with 16" front wheel), I can feel a kind of knocking, which feels like it's coming from the rear wheel, which I can feel ever so slightly through the footpegs. It knocks once on every revolution. I can just about feel it at lower speeds, but it is barely noticeable. Above 50-60mph, I can't feel it at all.
One of my mates suggested that my chain is probably in need of oiling (it was last done around 550 miles ago until today), so I gave it a good spray after a quick ride to warm it up. The tension is fine right now.
I haven't had a chance to ride it since oiling it, so I'm not sure if it is okay yet, but I just want to check if there is anything else I should look out for. The bike is coming to the end of its 3 month warranty, so if there are any problems, I'd like to get them checked out for free!
Hopefully, oiling it should have fixed it, though!
Thanks in advance for any info/advice!
SM.Morgan
PostPosted: 23:54 - 15 May 2007    Post subject: Reply with quote
Could be your wheel bearings on the way out, which i doubt (unless someone has been doing stoppies all day Wink )
dabigginger
PostPosted: 23:57 - 15 May 2007    Post subject: Reply with quote
I haven't tried any wheelies or stoppies - I can just imagine it would end up in tears!
If it is the wheel bearing, should I be checking for excess play in the rear wheel, just like I would check on a car?
Thank you!
sanchezz_182
PostPosted: 00:01 - 16 May 2007    Post subject: Reply with quote
check ther is no tight spots on the chain, also check to see the wear on front an rear sprockets,
also remove the rear wheel and check the bearings,,
no sig, thats gay!!
SM.Morgan
PostPosted: 00:04 - 16 May 2007    Post subject: Reply with quote
yup i'm guessing you know how?
if not get the wheel off the floor and give it a bit of movement either way (left to right.)
you might not always get feedback from doing this as it might be a notch in the bearings, if you run the wheel in a full revolution, try finding a place where it becomes stuck, this will indicate a notch.
this test also works for headstock bearings.
Trixie
PostPosted: 08:54 - 16 May 2007    Post subject: Reply with quote
It could be a couple of dodgy links in the chain. My advice would be to check the chain carefully if the noise hasn't gone away yet.
Dead nobodies in company cars...
dabigginger
PostPosted: 18:19 - 16 May 2007    Post subject: Reply with quote
Right, just rode it, and all seems fine now. I got one of my mates to ride it, just to be 100% sure, and he says it's all fine. So, brilliant! Thanks for your help, guys!
The last post was made 19 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.05 - MySQL Queries: 13 - Page Size: 50.56 Kb
