2 Stroke Oil Pump Settings.
mrbluesbox
PostPosted: 15:50 - 16 May 2007    Post subject: 2 Stroke Oil Pump Settings. Reply with quote
Can anyone tell me how i can check if the oil pump on my Derbi GPR 125 is set up right.
im getting quite a bit of smoke from it (really bad first thing in the morning) and i think it might be putting pumping in a bit too much oil but im unsure of how to check.
Thanks
Gaz.
I seem to have misplaced my pants...................
PostPosted: 16:28 - 16 May 2007    Post subject: Re: 2 Stroke Oil Pump Settings. Reply with quote
Thanks
Gaz.
Is the bike going well? Because if it is I wouldn't worry.
Two strokes all smoke a lot especially when cold, and tbh too much oil isn't a problem. Better to have a smidgin too much oil than try to adjust it down because you think its smoking a little to much and then seize the engine.
c-m
PostPosted: 16:43 - 16 May 2007    Post subject: Reply with quote
completely different bike, but my KH125 has little markings on the pump that are actually balancing marks.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
Marci
PostPosted: 16:50 - 16 May 2007    Post subject: Reply with quote
Generally, you pop the pump cover off, and adjust two locknut style adjusters (similar to throttle cable adjusters). There should be a marking cast into the engine casing, and a marking on the pump itself. Hold throttle fully open, the two marks should align. That's it. Well, that's how it's been done on all my bikes... for yours, see here: https://homepage.ntlworld.com/j.cowell4/gpr.pdf (GPR125 workshop manual - 6.2Mb)
Only time to worry about excessive (bluish) smoke really is MOT day... as it'll fail... hence never take a 2 stroke for an MOT without riding it around for a good hour or so first to warm it up... if you MOT a 2 stroke from a coldstart, even a perfectly setup bike, the majority can fail quite easily.
Excessive white smoke is a much different matter... usually a water problem (either water in fuel, blown headgasket, or just condensation in the exhaust from being stored outside overnight)
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
mrbluesbox
PostPosted: 17:17 - 16 May 2007    Post subject: Reply with quote
yeah the bike seems to be running pretty well - no power loss or anything - theres a bit of a stutter as it goes into the powerband about 6k but i can live with that for the time being - just a bit annoying in the morning when i get to deal with a big ass cloud in the back garden Smile
Ill check the pump for markings and things when i get in and can get the cover off:)
Ill let ya know and post some pix if i need to .
ta
Gaz
The last post was made 19 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 3 - MySQL Queries: 13 - Page Size: 46.19 Kb
