Zxr400 Carbs
Dam_buster
PostPosted: 01:30 - 20 May 2007    Post subject: Zxr400 Carbs Reply with quote
right as a few of you know my zxr400 has been off the road for a little while,
getting it started took a while and it wouldn't idle properly, so im assuming its gummy fuel in the carbs,
now i removed teh fuel tank and air box to view the carb inlets and you have the "dash pot" style slider that moves up and down, and the butterfly type valve behind which moves when twisting the throttle,
now these dash pot sliders, how do they open up? are they operated on a vacuum? im quite confused about it all. the bike seems hesistant to rev, and sticks at 6thou.
now im thinking bout removing the float covers and giving them a blast with some carb cleaner, to get rid of any gummy fuel,
but would a good blast on the bike free up the carbs and get rid of that "flatspot" whilst revving?
hope this all makes sense, just desperate to get this baby on the road!
Hope to hear!
JIM
Yamaha R6 5EB, BMW 328i Touring, BMW 328i Coupe
DaveH
PostPosted: 09:55 - 20 May 2007    Post subject: Reply with quote
Its the rate of the air passing past the sliders that draws them up. Not sure if adding redex to the fuel will help clear out the carbs, or just block the jets a bit.
Is it cleanfuel that you're using, or stuff that was already in the tank, and if so how long was it sittng?
https://www.timhastingsracing.co.uk/
ZX7R & ER6F
Dam_buster
PostPosted: 10:46 - 20 May 2007    Post subject: Reply with quote
i put new clean fuel into the bike, but the bike has been standing since december, reason why i think its gummy fuel.
so i might swill this tank out again with clean fuel, pour it out, fill it again, and put some redex carb/fuel treatment in it.
so the slides go up and down whilst the engine is on. brilliant thats what i wanted to hear, and not, "their supposed to move with the throttle" lol
i'll get on the case of that today,
cheers for the speedy reply
jim
DaveH
PostPosted: 11:24 - 20 May 2007    Post subject: Reply with quote
Have you drained the carbs already?
ZX7R & ER6F
Dam_buster
PostPosted: 11:33 - 20 May 2007    Post subject: Reply with quote
not yet, removing the carbs today to take the float covers off, give them a good clean out.
DaveH
PostPosted: 12:14 - 20 May 2007    Post subject: Reply with quote
Thumbs Up Cool
ZX7R & ER6F
Dam_buster
PostPosted: 17:38 - 20 May 2007    Post subject: Reply with quote
right well today i had the float covers off, gave them a good spray with carb cleaner, made sure the floats were moving freely. re-assembled and tried to fire her up....
nothing just starter motor lol
put some fuel additive in with the fuel,
but just waiting for the carbs to fill with fuel now really.
so will this take some time with constant starter motor action?
hope to hear.
jim
DaveH
PostPosted: 23:45 - 20 May 2007    Post subject: Reply with quote
Hmm, has it not got a fuel pump, or are any of the pipees kinked and thereby restricting the flow of the petrol....it shold be gushing in there til the float valves stop it
ZX7R & ER6F
Dam_buster
PostPosted: 07:22 - 21 May 2007    Post subject: Reply with quote
cheers for the tip will have a look, it does have a fuel pump!
will have a look
cheers
jim
Dam_buster
PostPosted: 21:53 - 21 May 2007    Post subject: Reply with quote
right had a look, but didnt see any kinked pipes or anything,
had the bike started, today, it revs really high 4,5,6 k and then goes down to 1k then stalls, got a mega idle problem,
any ideas how to sort this?
JIM
DaveH
PostPosted: 23:21 - 21 May 2007    Post subject: Reply with quote
Does it usually cut out after about the same length of time?
Sounds like fuel starvation, immediately after it stalls switch the engine ignition off and see if you can drain any petrol from the carbs...if it is fuel starvation, it may be accopmapnied by a loud ticking from the fuel pump.
ZX7R & ER6F
Dam_buster
PostPosted: 23:23 - 21 May 2007    Post subject: Reply with quote
how do i go about draining fuel from the carbs? is it that lil sprung screw on the nipple on the bottom of the carbs?
if its fuel starvation, whats needed more fuel in the tanks? it has 5l in it,
jim
Dam_buster
PostPosted: 23:30 - 21 May 2007    Post subject: Reply with quote
what am i looking for when opening these bleed nipples? lots of fuel coming out??
DaveH
PostPosted: 23:33 - 21 May 2007    Post subject: Reply with quote
jim
Try it with the fuel cap open.
To drain the carbs, there should be a screw, or allan bolt in the position indicated, unscrewing it will allow fuel to flow from the spout at the base.
Edit: Embarassed
ZX7R & ER6F
Dam_buster
PostPosted: 23:35 - 21 May 2007    Post subject: Reply with quote
and if its not draining fuel then its fuel starvation?
possible faulty pump?
what will running with the fuel cap open do?
sorry for all the questions
but thanks for your speedy replies! Thumbs Up Thumbs Up
DaveH
PostPosted: 23:39 - 21 May 2007    Post subject: Reply with quote
It could be a faulty pump, with the fuel tap closed, but fuel in the carbs, disconnect the feed to the pump and see how strong the suction is.
I suggested running the bike with the fuel cap open incase the petrol tank breather pipe was blocked and it was creating a vacuum in the tank and preventing proper fuel flow.
One other thing in migh be worth checking is for an air leak between the carbs and the engine. Spray wd-40 liberally over the area and see if the engine note changes..
ZX7R & ER6F
DaveH
PostPosted: 23:40 - 21 May 2007    Post subject: Reply with quote
Not stupid questions at all, only hope you can get it working and if not that someone else can chip there tuppence worth in as well as I'm running out of ideas...
ZX7R & ER6F
Dam_buster
PostPosted: 23:42 - 21 May 2007    Post subject: Reply with quote
Thumbs Up Thumbs Up cheers bud, i will have another go tommorrow evening,.
will try runnin with the tank open, and the wd-40 trick. then i will try the pump.
so i have to get the bike running, then turn it off, and drain the carbs to see if they are filling properly.?
DaveH
PostPosted: 23:45 - 21 May 2007    Post subject: Reply with quote
Once its cutting out, check the float bowl, to determine if they are empty or not.
One other way to check the pump would be to disconnect the pipe to the carbs and aim it into a jar, turn the ignition on and try the starter, petrol should gush out.
Good luck Thumbs Up
ZX7R & ER6F
Dam_buster
PostPosted: 23:48 - 21 May 2007    Post subject: Reply with quote
cheers buddy your a star!
M1ke
Ped Boi
PostPosted: 00:31 - 22 May 2007    Post subject: Reply with quote
I'd put money on it being the fuel pump, sounds exactly like the symptoms i'd expect.
The only other thing that makes it rev high is if you forget to attach the suction pipe to the fuel tap from the carb (should be the petrol pipe + suction pipe attached)
I'd say 95% your fuel pump though.
Dam_buster
PostPosted: 07:10 - 22 May 2007    Post subject: Reply with quote
what would make it high?
the pipe from the fuel tap to the carb.. thats the main feed for fuel?
have you any pics or illustrations to help explain Laughing
cheers for the info!! Thumbs Up Thumbs Up
JIM
DaveH
PostPosted: 11:17 - 22 May 2007    Post subject: Reply with quote
If its got a fuel pump then it won't have a vacuum operated tap and therefore won't have the vacuum pipe between the carbs and tap. Thumbs Up
ZX7R & ER6F
Dam_buster
PostPosted: 20:13 - 22 May 2007    Post subject: Reply with quote
right got the bike started again today, had a fiddle, gonna adjust my choke etc. do i want to go tighter or looser, if when i open the choke it revs to about 6k?
just checked for suction from the pump "took the feed line from the tank and hit the starter"
And couldnt seem to feel anything?
should i feel some definate suction?
just about to check the carbs for any drainage.
cheers guys!
JIM
Dam_buster
PostPosted: 20:49 - 22 May 2007    Post subject: Reply with quote
drained the carbs, well 3 of 4 as i cant get onto the last one Embarassed
but to give an idea how much came out of each one, id say about half of a 500ml aerosol cap.?
so i no the carbs are filling.
just the revs are now sticking, and i felt for suction from the pump and i couldnt feel any.
also if i rev the bike hard, it will stall..
spark plugs?
hope to hear.
jim
The last post was made 19 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 130.42 Kb
