| befdelta7 |
 befdelta7 Brolly Dolly
 Posted: 22:14 - 22 May 2007 Post subject: urgent help is needed.... please!! clutch wise **SORTED ** |
hi,
i have fitted the complete clutch unit from e-gay, but now the starter wont turn the engine over. but THE BATTERY IS FINE!! the starter engauges but doesnt turn the engine over, feels like the the piston is stuck, although it isnt.
all i can think is i have fitted the clutch incorectly.
how tight should the bolts that compress the springs be? iv done them up as tight as possible.
should they not be tight? when i removed the bolts holding the springs they wer well loose.
also whilst trying to bump start the bike in all the gears(tryed them all) the engine doesnt turn over when the clutch is released but the back wheel still spins like the clutch is slipping. any ideas on that?
iv had it with this bike now, so pissed off just want to put a match to the petrol tank!! been fixing my bike up all day and trying to solve this problem for the last hour, but as usual it got dark... my luck or rather lack of it! and to top it off the rear tyre i got from a shop (wont name and shame just yet) that i was assured was in very good usuable condition has 2 holes in it.
could some one please please help me out, like an idiot guide to fitting the clutch as you've guessed it... i am an idiot! the manual i have is complete sh1t doesnt explain how to do it.
if i could find out what the problem might be then tomorrow ill have a go at it. i personally think the bolts holding the springs are way to tight, but am open to any ideas.
thank you all very much for your replys and help.... i am very greatfull  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
| Paddy Blake |
 Paddy Blake World Chat Champion
| befdelta7 |
| Paddy Blake |
| Vincent |
 Vincent Banned
| cagiva gezzer |
 cagiva gezzer World Chat Champion
 Posted: 09:02 - 23 May 2007 Post subject: |
The workshop manual is fine. You just need a bit of interpretation.
Did you take the basket off? If so, you'll need to make sure the balancer shaft is timed right.
This piccy should clear it all up.
https://i67.photobucket.com/albums/h294/supercitybity/Cagiva/frizione.gif[/img] ____________________ "because one stroke isnt enough and four strokes waste two" |
| befdelta7 |
 Posted: 14:45 - 23 May 2007 Post subject: |
ji,
yes i took the basket out, whats the balancer shaft? how do you time that right?
thanks for your replys!  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| cagiva gezzer |
| befdelta7 |
| befdelta7 |
| befdelta7 |
| befdelta7 |
 Posted: 19:08 - 23 May 2007 Post subject: |
hi,
think iv found the problem.
when the casing is fully bolted on without the original gasket the engine is very stiff to move and the starter wont turn the engine over. bit if i loosen the bolts very slightly the engine turns over easily on the button, so im guessing i need a new gasket, as i was using gasket paste. the original was destroyed when dis-assembling.
anyone in the know how think this could the problem?
if so i feel like a right plank as iv been doing this for 2days now.
thanx  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| Paddy Blake |
| befdelta7 |
| Paddy Blake |
| cagiva gezzer |
 Posted: 22:00 - 23 May 2007 Post subject: |
Don't make one as you've already worked out that the thickness is critical.
I (wrongly) asuumed that you wouldn't be silly enough not to use a gasket.
Call mitomondo in the morning and he'll have one to you friday morning.
Before bolting it all back togther make sure the balancer shaft is lined up correctly, otherwise you'll have it ALL apart again.
Two marks on balancer (left) and intermediate (right) need to point togther.
https://i67.photobucket.com/albums/h294/supercitybity/Cagiva/Cagiva10.jpg
https://i67.photobucket.com/albums/h294/supercitybity/Cagiva/Image062a.jpg
It can be fiddly, but it wont work unless you get it spot on. Read the manual. Reverse the piston position stated in the manual.
If you've removed the basket with the bike upright your timing will be out. ____________________ "because one stroke isnt enough and four strokes waste two" |
| befdelta7 |
 Posted: 22:13 - 23 May 2007 Post subject: |
cheers paddy
i think ill order a gasket as i did try to make one earlier but it was a right pain in the arse fitting it as its got to 100% accurate otherwise it creases and moves out of position.
what would happen if i use a gasket on the clutch casing that was too big EG insted of 1mm used a 2.5mm?
would it cause impropper clutch operation, or have a damaging effect?
the gasket that came off the casing was id say 1mm thick maybe 1.5mm.
i cant beleve that a gap of 1mm can cause the problems im having with the clutch -- suppose an engine is engineered so presice that small amouts matter a lot.
thankx for your reply  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| Paddy Blake |
| befdelta7 |
| Paddy Blake |
| befdelta7 |
 Posted: 00:27 - 24 May 2007 Post subject: |
hi,
when i get a new gasket i'll let you all know if it solved the problem(you will know anyway i suppose as ill be back asking for more ideas if it dont LOL)
thanx for your help and advice... karma for each and every post thats been posted!
james. ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| Paddy Blake |
| befdelta7 |
 Posted: 10:37 - 26 May 2007 Post subject: |
hi,
the problem has been sorted
new gasket on it... bam! it s all working fine, the bike runs well now. clutch is brilliant, i accually feel more power now as the old clutch was well worn and slipping.
the bikes happy as its had four oil changes since last week when i started the job LOL. just got to get my new tyre fitted today, fit the ktm looking headlight and alls done.
thanks for all your help and replys lads! an E-pint of the finest beer coming your way! ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
The last post was made 19 years, 82 days ago. Instead of replying here, would creating a new thread be more useful? |
