nc30 wont spark
mogoly2003
PostPosted: 19:42 - 23 May 2007    Post subject: nc30 wont spark Reply with quote
hi after not rideing my nc30 for a few weeks it wont fire up. There is no spark to any the plugs i test with spare plugs no joy. So i changed the coil and kill switch any ideas just dosent want to spark.
thanks
Trixie
PostPosted: 19:44 - 23 May 2007    Post subject: Reply with quote
HT leads (provided they didn't come already attached to the coils)?
Dead nobodies in company cars...
PostPosted: 19:51 - 23 May 2007    Post subject: Reply with quote
Is there any need for 2 threads?
Paddy Blake
PostPosted: 19:59 - 23 May 2007    Post subject: Reply with quote
Does the neutral light come on.Could it be the side stand switch sticking
or the switch at the clutch lever.
Paddy.
PostPosted: 20:01 - 23 May 2007    Post subject: Reply with quote
Paddy.
You can start NC's in neutral with the stand down, so should matter. Thumbs Up
Paddy Blake
PostPosted: 20:05 - 23 May 2007    Post subject: Reply with quote
Yep that is why I asked if the light came on as if it did not work then the
stand switch could stop it sparking. Wink
Paddy.
PostPosted: 20:11 - 23 May 2007    Post subject: Reply with quote
Paddy.
Aha.
Well as I said in the other thread
CDI?
Flat Battery?
Charging system? Reg-Rec?
Cillit-BANG
PostPosted: 21:02 - 23 May 2007    Post subject: Reply with quote
There is no side stand switch on the NC30.
Are all the connections on the CDI looking clean? If both coil packs aren't sparking then it could be the CDI or the coil pick-ups.
You may need a spare hour with a wiring diagram and a multi meter to get to the problem.
I presume you have checked the ignition fuse Question
Hope this helps....
https://i139.photobucket.com/albums/q292/Cillit-BANG/WiringDiagramPB-1.jpg
The last post was made 19 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.29 - MySQL Queries: 13 - Page Size: 55.27 Kb
