NS 125 R - Oil and engine type
radders
PostPosted: 19:35 - 24 May 2007    Post subject: NS 125 R - Oil and engine type Reply with quote
Hi, finally sorted model out NS125 R not NSR 125 first question, what are the engine variations between the two? i have on the RH side the water pump, i notice that the later engines have the oil pump above the water pump on the RH side.
Secondly, oil - i have only literature for he NSR, i need to know what type of 2 stroke oil is used, and also transmission are any likely to be synthetic?
Cheers folks,
Radders.
hmmmnz
PostPosted: 19:39 - 24 May 2007    Post subject: Reply with quote
basically with any high revving smokey you should use top quality 2 stroke oil,
with the transmission it doesnt matter, just regular car oil
the humans are dead
I kick arse for the lord
mr jamez
PostPosted: 19:54 - 24 May 2007    Post subject: Reply with quote
I just use 10/40 car oil in the 'box. And for engine oil I use Advance VSX semi synth at £5.40 a litre from:
https://www.am-oils.co.uk/mcycles.htm
PostPosted: 22:44 - 24 May 2007    Post subject: Reply with quote
The NS and NSR engines are pretty much totally different engines. Honda just said SAE 10W40 SE or SF oil for the transmission.
Paddy Blake
PostPosted: 23:11 - 24 May 2007    Post subject: Reply with quote
Some car oils are not made to allow for wet clutch so you need to check
that out.
Paddy.
SM.Morgan
PostPosted: 23:14 - 24 May 2007    Post subject: Reply with quote
listen to paddy, you can't use car oil if the clutch uses the oil from the transmission, car oils have anti-stick chemicals in them which will cause serious clutch slip if used.
PostPosted: 23:20 - 24 May 2007    Post subject: Reply with quote
Occasionally true, but mostly not. Use car oils in bikes regularly and not had any clutch issues due to it.
Paddy Blake
PostPosted: 23:46 - 24 May 2007    Post subject: Reply with quote
The simple thing is to get the oil from a bike shop just in case.
Paddy.
PostPosted: 23:53 - 24 May 2007    Post subject: Reply with quote
True, if you want to pay massively more for the oil. I have used BP mineral, semi sythetic and fully synthetic in bikes. Bought in bulk the mineral oil was under £1 a litre. Cannot get the bike oil for a reasonable price and cannot get it in bulk 20L drums.
Only person I know who has had clutch problems due to car oil was Ste with some Texaco oil. Also heard reports about the Castrol Maganatec. Know loads of people who use car oils without any problems at all.
The last post was made 19 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 62.04 Kb
