how do you take the forlks off a bike with no center stand?
rocket_richie
PostPosted: 22:39 - 24 May 2007    Post subject: how do you take the forlks off a bike with no center stand? Reply with quote
i have a zx6r f3. she needs new seals ive preplaced them on bikes with a center stand(big hevy tool box on the back) is it a zurst off and a trolly jack under the engien joby ?
rs50 x2 rs125 zx6r f3 gs500e gsxr 400 zx6r f3
PostPosted: 22:45 - 24 May 2007    Post subject: Re: how do you take the forlks off a bike with no center sta Reply with quote
Ideally get an abba stand or under yolk front stand.
You can suspend the front end, from a rafter if you have them or even something like two wheelie bins.
Make sure the bike's kept steady while you do.
Seen people use two axle stands under the rigid footpegs of race bikes.
Exhausts off and something decent under the sump should do it.
Paddy Blake
PostPosted: 23:20 - 24 May 2007    Post subject: Reply with quote
Avoid taking off the exhaust if you can as it can add complications.
Wheelie bins are handy but don't start the night before bin day. Smile
Paddy.
Gazdaman
I did a trackday!!!
PostPosted: 14:52 - 25 May 2007    Post subject: Reply with quote
https://www.gaz-racing.co.uk/images/TZR/Full/DSCI0031(Small).jpg
Just wedge something under the sump.
This was just a TZR250 so hardly heavy. But personally I'd get a trolley jack under the sump, some jacks under the pegs, and maybe a rope around a rafter just to be sure.
Gaz
Whosthedaddy
PostPosted: 15:01 - 25 May 2007    Post subject: Reply with quote
Trolley jack then a couple of axle stands.
https://www.bikechatforums.com/files/fzr600_051.jpg
https://www.bikechatforums.com/files/fzr600_052_190.jpg
The FZR had some nice engine rails to balance on the stands, the tricky bit is jacking the bike up in the first place as it tends to be a little wobbly, so try and get a second person to give you a hand.
PostPosted: 15:46 - 25 May 2007    Post subject: Reply with quote
I've just sent an email to Danny on this very subject.
MarJay wrote:
You’ll need a paddock stand, and either a car jack or a front paddock stand which hooks into the bottom yoke. Put the bike on the paddock stand (or abba stand), and put a bit of wood under the exhaust downpipes and jack the bike up using the bit of wood. Because the load is distributed across the downpipes it should be pretty stable.
Get some tie downs and wrap them around the head stock and up around some rafters.
Whosthedaddy
PostPosted: 15:48 - 25 May 2007    Post subject: Reply with quote
You may want to loosen the nuts a little before you balance or hang the bike.
Gazdaman
I did a trackday!!!
PostPosted: 20:14 - 25 May 2007    Post subject: Reply with quote
Hetzer wrote:
Funny looking sump you've got there. Looks like exhaust down-pipes to me. Wink
I suggested the sump, didn't say I used it Wink
On a lighter bike the downpipes are ok IMO. Wouldn't try it on anything bigger though.
EDIT: And the sump on a 2 stroke is a touch non-existant.
Gaz
PostPosted: 22:01 - 25 May 2007    Post subject: Reply with quote
Gaz
Gaz, I'd say that it was OK on most 4 cyl four strokes, but two stroke expansion chambers are not known for their strength. I've never seen a dented four stroke downpipe but I've seen plenty of dented 'spanny chambers to know I'd rather try jacking under a ZX6R than a TZR or something.
Ted
PostPosted: 22:17 - 25 May 2007    Post subject: Reply with quote
Did mine not so long ago... used a trolley jack under the engine, then slipped an axle stand under the front of the frame... easy!
rocket_richie
PostPosted: 23:30 - 25 May 2007    Post subject: Reply with quote
u shur my down pipes will take the wait she is a fat old beasty
Gazdaman
I did a trackday!!!
PostPosted: 09:00 - 26 May 2007    Post subject: Reply with quote
If you actually read the thread no-one's suggesting you put it on the downpipes.
It's even suggested you take the exhausts off and whack a jack under the sump.
MarJay: These spanny chambers were beasties, and the bike was so light I lifted it onto that box. It also had no tank on, fairings etc. It was perfectly happy.
Gaz
The last post was made 19 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 80.06 Kb
