| vfr800 |
 vfr800 Spanner Monkey
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 07:10 - 25 May 2007 Post subject: |
the standard oil in the vfr800 and late 750s is hondas ss8 fork oil,
it has a weight of 7.5w which is really light compared to most bikes but ive heard that the bike doesnt react properly with 10w oil in it.
i think standard 5w oil is fine, but i think i would shell out a little more and get "pro honda suspension fluid ss8" ____________________ the humans are dead
I kick arse for the lord
| vfr800 |
| hmmmnz |
| vfr800 |
| hmmmnz |
 Posted: 07:36 - 25 May 2007 Post subject: |
bugger, in this case i wouldnt listen to haynes on getting the seals out.
there is a slightly easier way,
get a wood screw, and jam it into the seal then try and get it to bite, then pull the seal out.
not really a professional way but, its quick and it works
unless its easy to split your forks, i can't remember if it is on yours or not ____________________ the humans are dead
| vfr800 |
 Posted: 15:22 - 25 May 2007 Post subject: |
Sounds like a good bodge to me, all up for that shit!
I will be part stripping the forks to get the height of the oil right. Not something i've done before but well in my capabillities. (one would think)  ____________________ don't take it easy 'ride it like you stole it' |
| veeeffarr |
 veeeffarr Super Spammer
 Posted: 15:25 - 25 May 2007 Post subject: |
| hmmmnz wrote: | bugger, in this case i wouldnt listen to haynes on getting the seals out.
unless its easy to split your forks, i can't remember if it is on yours or not |
Can you insert the new one in situ as well?
T |
| hmmmnz |
| vfr800 |
 Posted: 16:21 - 25 May 2007 Post subject: |
I'de like to see a fork seal changed with the fork insitu !
I've located a set of seals nearby so i'll fetch them in the morn and get them changed, they're the good nipon parts aswell.
Cheers, Ian[/quote] ____________________ don't take it easy 'ride it like you stole it' |
| veeeffarr |
| hmmmnz |
| vfr800 |
 Posted: 16:56 - 25 May 2007 Post subject: |
insitu.
short for insituation. That does'nt sound that clear either so in short,
"change the fork seal without completely dismanteling the stantion".
Hows that sound?  ____________________ don't take it easy 'ride it like you stole it' |
| hmmmnz |
The last post was made 19 years, 158 days ago. Instead of replying here, would creating a new thread be more useful? |
