Removing broken Fairing bolt
R1stu
Shrek!
PostPosted: 12:49 - 25 May 2007    Post subject: Removing broken Fairing bolt Reply with quote
One of the bolts that holds the fairing on has snapped off into the frame.
It is the middle one on the left mid fairing, the bike was like this when I got it.
Im not getting a bit fed up with it flapping a bit and want to replace it! Whats the best way of removing it?
Its not very wide diameter will the kits fit?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
PostPosted: 12:56 - 25 May 2007    Post subject: Reply with quote
drill.
hacksaw across the head and get it out with a screw driver?
R1stu
Shrek!
PostPosted: 16:21 - 25 May 2007    Post subject: Reply with quote
Big_Ham wrote:
drill.
the heads snapped of and the rest is flush to the frame.
razy60
PostPosted: 17:35 - 25 May 2007    Post subject: Reply with quote
you need to drill it. although there are special tools that are used which cost a couple of quid each, basically drill a hole and wind the tool in(its a bit like thread cutter (tap)) it has an opposite thread which as you wind it in it unbolts what ever is stuck. you can get them at halfords or your best bet is a decent tool shop.
jimbothe
PostPosted: 18:06 - 25 May 2007    Post subject: Reply with quote
But dont screw it in and give it shed loads of pressure as the tools break quite easily.
Spray the bolt first with duck oil or something similar and leave overnight before you try the tap set.
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
The last post was made 19 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 44.8 Kb
