Slightly fudged rivet link
rvfdan
PostPosted: 17:55 - 26 May 2007    Post subject: Slightly fudged rivet link Reply with quote
Hi,
I've just changed the chain and sprockets on my bike and it seems i was slightly over zealous with the riveting tool. The heads of the pins have split slightly where they have been "squashed" in too much. Is this going to be a problem? It still "looks" like the side plate has no chance of coming off.
I have ordered another link just in case. Bit of a pain really, it was probably done right the first time but i went back and gave the pins another good seeing to as i was paranoid they hadn't been done enough. Sad
Cheers,
PostPosted: 18:08 - 26 May 2007    Post subject: Reply with quote
I would say that so long as the side-plate is pressed-home fully you'd be ok for normal riding. If you're going out for a good thrash I'd be thinking twice about that.
razy60
PostPosted: 18:43 - 26 May 2007    Post subject: Reply with quote
change it, soon as you can, having a chain fly off is not a pretty sight
PostPosted: 18:49 - 26 May 2007    Post subject: Reply with quote
Yes agreed. On reading my reply it suggests I mean leave it on for normal riding. I meant as a get-you-by until your new link turns up.
rvfdan
PostPosted: 18:57 - 26 May 2007    Post subject: Reply with quote
Thank you for the replies. Its ok, the bike isn't being used yet. Im getting it ready for summer at the moment, so ill change the link when the new one turns up.
Cheers,
dibs
PostPosted: 22:52 - 26 May 2007    Post subject: Reply with quote
the chain has tension appled to it and very little torsion if the wheel is aligned properly, so even if the heads of the soft rivets are slighty split this shouldnt be a problem as you are not trying to twist them off
rvfdan
PostPosted: 14:05 - 27 May 2007    Post subject: Reply with quote
I was thinking along the same lines myself but if i don't change it I'm only going to worry about the thing, and if it did let go, well that would be kinda crap and i wouldn't be able to blame someone else. Very Happy
I posted really in the hope that loads of people would say "don't worry about it, i always do it" type thing, but as there is even a hint of doubt ill change it.
The last post was made 19 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 52.48 Kb
