| rtcabal |
 rtcabal L Plate Warrior
 Posted: 06:37 - 25 May 2007 Post subject: kawasaki zephyr 550 |
hi there. this is my first post on this forum. any help would be greatly appreciated...
i've had a '91 kawasaki zr550 for a little time. man, is it quirky! long story short, i had a bunch of work done on it before i put it in storage for the winter. it ran like a champ at the end, though it took them all summer to finish. now, i try to get it running for happy spring time and i can't get it to idle. maybe i'm just using poor cold start procedures, so, like i said, i'd be grateful for any help.
i can get it fired up with the choke on, but that's it. it revs high (about 5k), and it will only stay running with the choke on full. i let it get warm like this, trying to coax it to idle, but nothing.
thanks for looking,
taylor |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 06:58 - 25 May 2007 Post subject: |
like most bikes that have been sitting for a while,
do the basics first,
drain the float bows, check that the oil hasn't got any petrol in it from faulty float valves letting the fuel past, (probably best just to drop the oil an way)
change he plugs,
once its basically running check that its firing on all cylinders.
you might be running on 3 and thats why it not idling properly.
try all that and go from there
good luck  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| rtcabal |
| hmmmnz |
 Posted: 07:22 - 25 May 2007 Post subject: |
| ZRX61 |
 ZRX61 Victor Meldrew
| Finglonga |
 Finglonga World Chat Champion
| bish777 |
 bish777 World Chat Champion
| ZRX61 |
| bish777 |
| rtcabal |
| stinkwheel |
 Posted: 21:52 - 01 Jun 2007 Post subject: |
Might be worth putting some fresh fuel in anyway. I dragged my H100 out today for the first time in a couple of months and it ran like a bagowank until I'd got some fresh fuel in there. Couple of miles on from the filling station and it was ringing away like a good-un. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Scotsman37 |
 Scotsman37 World Chat Champion
| rtcabal |
| Scotsman37 |
| ZRX61 |
 Posted: 05:12 - 11 Jun 2007 Post subject: |
| rtcabal wrote: | thanks alot.
the #2 spark plug was fouled. i pulled it, cleaned it, then couldn't get the damn thing to start at all.
if its not firing in that cylinder, what should be my next order of business? i want to avoid taking the carbs off, as they are a major pain to get back on, sandwiched between the airbox and the motor like they are.. |
You're not going to like this bit:
Take the carbs off, pull the float bowls, floats, float valves, mains, pilots, blow a bit/lot of air thru the orfices, clean ALL the parts you removed. Make sure the slides actually slide (you can do this without popping the carb tops off) Reasemble & fire it up.
Which is what ya should have done after I told ya the pilots are gunked back on May 25th...
With the tank off the bike:
Pop the intake boots back INTO the airbox, but not all the way. Do NOT loose the spring thingies.
Remove the front brake lever (just the lever part)
Loosen the clamps on the intake mainfolds
Pull carbs backwards out of the manifolds
Pick up the piece of metal plate that I'm about to tell you about below* & slide it between the manifolds & the carbs to make it a LOT easier to:
Swing the carbs out to the right side of the bike.
Take the 2 screws out of the righthand handlebar switch cluster & pull it apart (now ya see why I told ya to take the brake lever off?)
Pop the cable ends out of the throttle housing
Pop the other end out of the carbs & put the carbs on the bench.
Now go the hardware store & buy 32 M4 Stainless Allen bolts & a 4mm allen key. You want the allens to be 14mm long, so thats M4x14mm. While you're there buy what is called a "split pin remover" which looks like a buggered screwdriver with a curvy pointy tip.
Now go back to the bit where I said "you won't like this bit" & do what I said.
* bit of thin (1mm or so) aluminium or steel etc approx 3in wide & 15in long.
I guess you can figure out how to pop the choke cable off without me having to go out into my backyard in the pitch black & look at the one I've got leaning against the wall?
& now that all time favourite line from Kawasaki manuals:
"Assembley is the reverse of disassembley"
The "buggered screwdriver" looking thing is to help ya get the boots back onto the back of the carbs.
Any questions? |
| ZRX61 |
 Posted: 03:22 - 12 Jun 2007 Post subject: |
Apparently "no" is the answer to the any question enquiry then?
Or have you been stunned into immobility?  |
| rtcabal |
| ZRX61 |
| rtcabal |
| ZRX61 |
 Posted: 02:36 - 19 Jun 2007 Post subject: |
You stated earlier it wasn't firing on #2, so thats either a plug or fuel. NOT the ignitor.
However, It's been about a week since I told you how to fix it & almost a month since I told you what the problem is. At this point I'm done. Go do whatever the fuck you want with it.  |
| bish777 |
| rtcabal |
| ZRX61 |
There is a gap of 355 days between these two posts... |
| Beena22 |
 Beena22 Derestricted Danger
There is a gap of 8 years, 12 days between these two posts... |
| newellphillip... |
 newellphillip... L Plate Warrior
The last post was made 10 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
