Goodridge Braided hoses
gmanxiii
PostPosted: 11:13 - 06 Jun 2007    Post subject: Goodridge Braided hoses Reply with quote
Any good? or should I spend abit more on some better ones? Bear in mind its just to replace some standard brakelines which are broken. Ta!
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
yzf750r
PostPosted: 11:39 - 06 Jun 2007    Post subject: Reply with quote
theyre braided brake hoses! Theyre all near enough same quality - dont pay more because you wont beable to tell the difference. Goodridge must be good cos racers use it. Thumbs Up
Go for what ever is cheapest for your bike.
I got a full set of Hel Brake lines - front and back - for my old blade and I paid £15 brand new off eBay.
KTM Gordo
PostPosted: 12:37 - 06 Jun 2007    Post subject: Reply with quote
Goodrich are one of the "premium" brands that you can buy. I fitted them to the Fazer recently and, as long as you get the right fittings, it was an easy job.
The main difference between cheap braided hoses and more expensive ones is that there is a clear sleeve over the braiding to stop any damage to bodywork etc. caused by the hoses rubbing against it. A non-sleeved braided hose will cause a lot of damage to a plastic fairing.
HTH Smile
Change is inevitable - except from a vending machine.
KTM 990 Adventure | KTM EXC 250 Racing | Land Rover Freelander SE Td4
SoulRider
PostPosted: 12:43 - 06 Jun 2007    Post subject: Reply with quote
Ive got them in stainless steel and a suzuki blue blue colour, improved my brakes no end and look alot better, their definatly not one of the "cheap" brands.
My Bike Pics
Dazbo666
PostPosted: 14:22 - 06 Jun 2007    Post subject: Reply with quote
I got mine via Busters in Swansea...
braided with a black sleeving over it.
And even for a complete bike newbie like me. it was a simple enough job to swap the old rubbery OEM line. Thumbs Up
Word of the day : DILLIGAF
gmanxiii
PostPosted: 15:02 - 06 Jun 2007    Post subject: Reply with quote
ah ok cheers guys i just saw them on fleabay, and they are marketed as a budget hose, just looking on busters website now they are a damn sight cheaper, might as well get some. Whats the difference between the different lines though? im confused, alloy? stainless steel? cadium? will any do?
I kills hondas
SoulRider
PostPosted: 15:31 - 06 Jun 2007    Post subject: Reply with quote
I was advised stainless steel as they dont rust, where as alloy do. Only word of mouth though so dont take my word on it.
You will pay a bit more for SS though. Cadium i have no idea.
My Bike Pics
Bru
PostPosted: 15:58 - 06 Jun 2007    Post subject: Reply with quote
I have read here and elsewhere that aluminium fittings are not a long-term solution, because they corrode quickly in contact with the braiding or bolts (it's a galvanic thing). SS is the expensive option. I chose the zinc plated Goodridge fittings, as they are cheaper than SS, without the corrosion/cracking issues of aluminium alloy. The plating may corrode eventually, but it will take years of neglect before you are faced with any real difficulty. The hose is all the same.
Dazbo666
PostPosted: 16:25 - 06 Jun 2007    Post subject: Reply with quote
I was advised stainless steel is best for road riding, due to it being the best for it's tolerance against corrosion.
Alloy / aluminium / cadmium for road racing due to its weight saving, plus the fact that race bikes are more likely to have regular, ongoing maintenance etc that keeps a close check on the state of the inevitable corrosion.
Or so I was told - and it sounded like common sense to me. Wink
phill_sumner
PostPosted: 17:58 - 06 Jun 2007    Post subject: Reply with quote
stainless ones look cool, are corrosion/abrasion resistant and the main reason for use is because the plasicy/rubber ones expand once the brakes get hot and are under great loads (from track riding or hard road riding im guessing) whereas SS ones dont, which results in greater braking performance.
Wouldnt bother unless your having problems with your current ones, cheers
parting the A1 like moses parted the red sea
phill_sumner
PostPosted: 18:00 - 06 Jun 2007    Post subject: Reply with quote
Whosthedaddy
PostPosted: 18:04 - 06 Jun 2007    Post subject: Reply with quote
Had Goodrich braided lines front and rear on the ZXR, looked cool and stopped more than sharp enough Thumbs Up
PostPosted: 20:00 - 06 Jun 2007    Post subject: Reply with quote
Unlikely to make any difference on the road choosing different brands.
However avoid the alloy fittings. They can be lethal.
https://www.alfa-pages.co.uk/TempPicture/HelensBrakes.jpg
https://www.alfa-pages.co.uk/TempPicture/mikesBrakes.jpg
One of those was still holding on pretty much by luck (poke the fitting while pulling the brakes hard and some fluid did leak out) while the other was found about 2 days before they were going touring round Europe.
Of the others, pretty much down to choice. Cadmium are the cheapest, and don't look great. Corrosion protection is OK but not great, will work fine. Chrome plated fittings look good, but possible to damage the plating when fitting them. Stainless look good and will not corrode.
gmanxiii
PostPosted: 20:58 - 06 Jun 2007    Post subject: Reply with quote
Brilliant guys Thumbs Up tons of help, goodridge they are then! just got to figure out how to fit them now Razz
I kills hondas
KTM Gordo
PostPosted: 21:06 - 06 Jun 2007    Post subject: Reply with quote
If you need a hand then you're welcome to come down to Gordo Towers (St Neots). I've done brake lines a few times on various 'bikes and it's fairly straightforward provided the old ones come apart (and you've got the correct new fittings!).
HTH Smile
SoulRider
PostPosted: 21:32 - 06 Jun 2007    Post subject: Reply with quote
Blimy im surprised they still make and sell the alloy ones, should provide some kind of warning atleast. Glad i did get SS.
My Bike Pics
gmanxiii
PostPosted: 22:06 - 06 Jun 2007    Post subject: Reply with quote
HTH Smile
Thanks for the offer Gordo, its very much appreciated but im afraid that your a bit too far away Smile Anyways reason why i asked was because my brake lines were torn out in a crash several months back. Just bought her back off the insurers and currently (trying to) put her back on the road again. So trying to work out the best way to replace all the broken and missing parts. My clutch cables gone as well and i see that goodridge also do a stainless steel braided clutch line... does clutch line = clutch cable? i take it theres no benefit other than looking pretty right? sorry im a n00b to fixing bikes.
Cheers!
I kills hondas
SoulRider
PostPosted: 22:12 - 06 Jun 2007    Post subject: Reply with quote
Not entirely sure, i know some new bikes have clutch fluid so im guessing their hydrolic rather than cable lines. So will be two different things, mines a cable rather than fluid.
What bike have you got?
My Bike Pics
PostPosted: 22:26 - 06 Jun 2007    Post subject: Reply with quote
That will be a braided line for a hydraulic clutch. Hydraulic clutches seem to be getting less common on bikes (the race reps prefer the couple of grams weight saving in exchange for needing a new cable regularly).
gmanxiii
PostPosted: 22:43 - 06 Jun 2007    Post subject: Reply with quote
ah ok cheers again, that makes sense then! i've got an nc30 so its a cable clutch. save myself some money then woohoo!
I kills hondas
KTM Gordo
PostPosted: 17:51 - 07 Jun 2007    Post subject: Reply with quote
For what it's worth, both of my KTMs have hydraulic clutches. They don't need adjusting either Smile
gmanxiii
PostPosted: 21:26 - 07 Jun 2007    Post subject: Reply with quote
cool, i just ordered them this afternoon, went for full Hel kit in the end as it worked out abit cheaper than the goodridge.
I kills hondas
Timmeh
PostPosted: 22:00 - 07 Jun 2007    Post subject: Reply with quote
Stainless steel banjos and unions FTW.
Don't get the cheapy anodised ones because the finish comes off and they become loose.
Goodridge ones come with proper CNC'd bolts and nice thick copper washers.
Best to have the best kit when it comes to things like this, I think.
The last post was made 18 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 121.85 Kb
