| Johnster |
 Johnster Renault 5 Driver
 Posted: 10:46 - 17 May 2007 Post subject: CG125 gone POP!!! |
Hi All,
When i set off from Work yesterday eve to go home i noticed my little CG was underpowered (Well, more than usual anyway) Putting this down to a headwind whilst traveling down the motorway i thrashed the knackers off the poor thing.
About 1 mile from home i noticed the engine seemed louder than normal and as i reached the exit slip road off the motorway all power was lost and the bike ground to a halt.
The engine will not start and when i kick there does not seem to be as much resistence as there was before.
Looking at the engine there is a small amount of oil that has seeped out of where the bottom gasket is. Otherwise nothing out of the ordinary.
Sounds like a blown bottom gasket leading to loss of compression to me but i was just wondering if anyone has any other ideas before i strip down.
Cheers again guys
John |
 Posted: 12:56 - 17 May 2007 Post subject: |
There's definately oil in it? Running out of oil is about the only way I can think of killing a CG.
Having a look at the plug electrode may give you a clue as to what has happened. If it's down on compression you may have dropped a valve or holed the piston. If you've holed the piston the sparkplug will be looking decidedly the worse for wear.
A CG being so inherantly unbreakable, it is also possible one of the tappets has tightened up on you and is holding a valve open (which would take a matter of minutes to fix). This would explain the earlier lack of power too.
So check the plug, then whip the inspection covers off and have a look at the tappets for signs of them closing up or a dropped valve. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Johnster |
| 0ddball |
 0ddball World Chat Champion
 Posted: 13:24 - 17 May 2007 Post subject: |
Oil leaking out of the base gasket is unlikely to be what's caused the problem unless it's got to such an extent as to cause a drop in oil levels/pressure. Would be an issue on a 2-stroke but not on a CG.
I've seen the barrels on an old push-rod BSA so loose that you could literally see them moving up and down as the engine ticked over. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MarJay |
 MarJay But it's British!
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 13:49 - 17 May 2007 Post subject: |
Honda CG's don't go pop. It's a fake I tell thee!  ____________________ My Flickr |
| Johnster |
| Wafer_Thin_Ham |
 Posted: 14:11 - 17 May 2007 Post subject: |
Depends what's gone. It's only a CG engine so it can't be THAT complex. ____________________ My Flickr |
| Johnster |
| Johnster |
| lukamon |
 lukamon World Chat Champion
| Johnster |
 Posted: 14:50 - 07 Jun 2007 Post subject: |
Thanks. I guess it has the added bonus of eating the magnum beforehand!  |
| SilvaRizla |
 SilvaRizla Spanner Monkey
 Posted: 18:15 - 07 Jun 2007 Post subject: |
CG125 + Motorway.....
Are you mental man?!?!?! ____________________ I'm Ivan Dobski the Meatsafe Murderer only I never done it, I only said that I done it so they'd take the truncheon out of my bottom |
 Posted: 18:16 - 07 Jun 2007 Post subject: |
Or you can saw a split along one side of the last 1/2" of a short piece of copper pipe. Bend the split bit open like a spoon and hammer it flat. Hey-presto, one scraper. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| SilvaRizla |
| Johnster |
| Johnster |
| Johnster |
| Rockhopper |
 Rockhopper Trackday Trickster
| Johnster |
 Posted: 23:11 - 07 Jun 2007 Post subject: |
I think the engine has just become tired as it has done about 62k miles and has never been rebuilt.
WHilst running it burned oil quite badly and the power seemed restricted. Im assuming this was because of the damage to the side of the piston, possibly caused by low oil levels..
WHen it went POP traveling down the motorway, Im pretty sure this was the piston rings breaking up causing severe loss of compression.
The engine did start after the incident by bumping it but the engine didnt produce much power i.e. not enough to move the bike without stalling!
Im gonna fir the new piston etc and see how it goes!
Wish me luck!  |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
| speedster |
 speedster Derestricted Danger
| bladerunner |
| SilvaRizla |
The last post was made 19 years, 27 days ago. Instead of replying here, would creating a new thread be more useful? |
