Darkness
Ariel Badger
PostPosted: 23:09 - 07 Jun 2007    Post subject: Darkness Reply with quote
I took the Ariel HS to the AOMCC Selly-Oak branch last night for general posing purposes. The lighting system is 12V total loss and I was wondering how long the lights would last on the way home, the headlamp bulb is a 50/40W unit and I erred on the side of discretion and rode off on dip. After about 2 mins I swung into a tight right hander and the light went out, I hit the dip switch and got full beam and survived the corner.
The dip switch was not new so I suspected a bad contact but twiddling it did not bring dip back on but I had full beam so I pressed on through the lanes. In reality the HS exhaust note was rather complimented by the high beam in your face and refusing to dip headlight, a HS is an arrogant machine.
After about three miles I came into the outskirts of Brum and gunned her down Primrose Hill, the lights went out again. Primrose Hill is a council estate on a hill but their aint no primroses, there are however lots of ratboys with chivs and electronic tags and it is one of my least favourite places to break down. Fortunately all was quiet and for once the Kevs were abiding to the curfew orders on their ASBOs and I was not molested. All kinds of switch flicking did nothing so I decided to improvise . I pulled the headlamp to bits and the bulb was clearly blown so I stuffed it in my pocket and pondered if riding though Britain's second city on an underslung pilot light was a good idea, it was not.
I always carry a little HID LED torch powered by a watch battery, you need to hold the rubber button in to get it to work though. I had already pulled a knife from my boot ( Primrose Hill insurance policy) and I used it to cut my boot lace in half, I then fashioned my lace into a loop with a knot and worked it over my little keyring torch. It worked and the knot kept the light on so I bunged it inside the headlamp shell through the bulb hole and fired up the HS again and under the bleary eyed gaze of freshly woken chavs headed towards the city centre casting a very dim blueish shadow in front of me. Three times the knot moved, three times she went out and three times I striped it back down and sorted it out again.
I got home at midnight, cracked a beer open and contemplated on what had happened. The bike runs on a battery with no charging system so power surges were not an issue and the wires had not leaked smoke, very careful examination of the bulb revealed a 4mm long crack in the glass ( my mate at school could not see it even when I pointed it out but it can just be felt by a finger-nail) I believe this was there from manufacture and allowed air into the bulb allowing each filament to go pop as it oxidised .
Not a recommended experience even though it seems funny today. If you do have to use a LED as a main beam be sensible and try not to go over 60mph in built up areas and a very tuneful exhaust helps.
W
PostPosted: 23:26 - 07 Jun 2007    Post subject: Reply with quote
Depends how many LEDs you use. Wink
You can buy big packs of high intensity, white LEDs off ebay. Wire them up on a big block of alloy as a heatsink and you're laughing.
Unfortunately there is a law in the UK stating your headlamp must use a filament bulb.
Or you could get an acetylene one for it, then you just need to stop and piss in the carbide if it goes out on you. Laughing
Ariel Badger
PostPosted: 23:34 - 07 Jun 2007    Post subject: Reply with quote
I had only one LED Mr. Green
As to the law......... It also says I should not have a number plate from another one of my bikes on the HS but needs must at times Mr. Green
mr.z
PostPosted: 23:44 - 07 Jun 2007    Post subject: Reply with quote
Sure people have used those posh halogen battery pushbike lights before with some success?
Lights something I'd never compromise on, but then there's not much in the way of lighting the route I'm normally on, and its usually night time I'm riding..
PostPosted: 23:46 - 07 Jun 2007    Post subject: Reply with quote
Shhh! Don't tell them that one, they'll all be at it. Wink
My mate Danny got caught out a beauty doing that going down to the dragon rally one year. He'd seized his Jawa but a mate of his had one that had been laid up for ages. He chatted up said mate and they struck a deal whereby Danny would get the bike up and running if he could use it for the rally.
Quick carb strip-down and it was up and going but without tax, MOT or insurance. Easy sorted, swap the plates over and Bob's your uncle. If a copper runs the plate, he's expecting to see a red Jawa 350 and that's what's sitting in front of him, he isn't going to start looking for chassis numbers.
Got to the rally entrance and ran into the worlds biggest and loudest Jawa anorack (ok, second biggest Embarassed ). "Wow, haven't seen an oilmaster actually on the road for ages. Hang on though. You've got the twin-leading drum and that engine casing is a bit too square. Isn't that the later Jikov carb with the built-in float bowl? Hey, this bike doesn't go with that registration, this is a 638 and it should be a 623 if it's that year. ".
"Yeah numbnuts, I know now keep it down would you? There's coppers about.".
The last post was made 18 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 49.56 Kb
