bike wont start : (
Zeus
PostPosted: 12:54 - 08 Jun 2007    Post subject: bike wont start : ( Reply with quote
i tried to start her up this morning, but whenever i start the ignition button it just gives me a low hum. it comes from the 2 red and black things.
https://www.angelfire.com/planet/batman13/bike/thumbnails/400x300/P1010094.JPG
it works perfectly fine when i kick start it.
it connectes straight to the battery so is that the problem? if so how does a noob go about fixing it? i
its a lifan 125 if thats any help.
thank you.
Ichy
PostPosted: 13:08 - 08 Jun 2007    Post subject: Reply with quote
Have you tried charging the battery up? Sounds like its a bit run down.
Zeus
PostPosted: 13:10 - 08 Jun 2007    Post subject: Reply with quote
could be, but i wouldent have a clue how to charge it up again and find out. is it that hard a job to do?
mrbluesbox
PostPosted: 13:16 - 08 Jun 2007    Post subject: Reply with quote
definitely a good place to start with the battery - whenever mines gives me that stupid hum its always time to stick the charger on.
if you wanna definitely check get yourself a voltmeter and stick the probes on the battery terminals - you should get 12v when the engines not being revved.
all youd need to do to charge it is get hold of a decent charger and stick the clip on the right terminal and leave for a few hours.
something like an Optimate 3 charger is a decent one and will last you forever.
the bike should also charge its self when you ride so if you can start it with the kickstart - go give a good ragging for a few miles and that should stick some charge in the battery for ya.
hope that helps.
gaz.
I seem to have misplaced my pants...................
Zeus
PostPosted: 13:23 - 08 Jun 2007    Post subject: Reply with quote
ok thanks ill look into it, but in the mean time will it be ok to keep useing? its just im half way through my exams and i need my transport.
mrbluesbox
PostPosted: 13:30 - 08 Jun 2007    Post subject: Reply with quote
yeah you should be fine - especially cos its gos a kick start on it - you dont even need to bump start it.
all your lights and things should all run off the alternator and things once its started so you should have no probs.
TBH once youve given it a good run round there should be a load of charge in the battery anyway (provided all the charging bits are working ok - but i wouldnt worry about that yet cos it probably is)
Timmeh
PostPosted: 13:40 - 08 Jun 2007    Post subject: Reply with quote
Also a good idea to get it running and check the battery. Put a voltmeter across the terminals when the bike is running.
A good generator should give you about 13.2 to 14 volts on a 125.
Also, if the battery gets hot during use, the plates have sulfonated and it won't hold its charge, so it's time to buy a new one.
Bardeey
PostPosted: 13:48 - 08 Jun 2007    Post subject: Reply with quote
99% a battery problem.. Running it will recharge the battery anyway.
Try the horn.. What does it sound like? Weak? If so it's the battery.
:: P Speedfight 49cc => Gilera DNA 124cc => Suzuki Bandit GSF V 400cc ::
:: CBT=Passed 07/08/05 :: Theory=Passed 31/05/07 :: Practical= Passed 02/08/07::
Zeus
PostPosted: 14:46 - 08 Jun 2007    Post subject: Reply with quote
thx for help guys
the horn just makes a little couching sound so guess its the battery
i like that Optimate 3 charger, think ill buy that 1.
im just looking at voltmeters and i came across this one. will it do the trick?
https://www.halfords.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10151&productId=237839&categoryId=79859
mrbluesbox
PostPosted: 14:58 - 08 Jun 2007    Post subject: Reply with quote
optimate 3 is the one ive got and is really good - you can leave it permanantely connected to your bike cos it switches its self off automatically.
i just got myself a cheapo voltmeter off ebay - cost about 7 quid including delivery.
Zeus
PostPosted: 17:22 - 08 Jun 2007    Post subject: Reply with quote
is it worth spending a little extra and getting a nice voltmeter or is it just beter to buy a cheap and nasty one like this?
https://cgi.ebay.co.uk/DIGITAL-LCD-MULTIMETER-VOLTMETER-AMMETER-OHM-METER_W0QQitemZ140126537477QQihZ004QQcategoryZ58277QQrdZ1QQcmdZViewItem
Zeus
PostPosted: 23:23 - 08 Jun 2007    Post subject: Reply with quote
well i just ordered the charger only to know find the site is closed till the 13th of june and with no way to cancel it : ( just my bloody luck.
Zeus
PostPosted: 21:15 - 11 Jun 2007    Post subject: Reply with quote
well today was the big day. had my exam in the morning and all went well for a few miles until the bike decided to die on me. after giving the bike some encouragement i.e shouting some abusive at it, i was off again. it once again died on me at which point i had to give up and get a lift.
on the plus side, my exam went well : )
Robert2014
PostPosted: 00:53 - 12 Jun 2007    Post subject: Reply with quote
are u driveing with your light's on ??? if so try turning them off and driveing and also if it going to cut out hold the clutch in and rev it that will keep it going sound's to me as if it's the battery how old is the bike mate ???
If you require a mechanic then I am your man. Bike collection and recovery service available. Don't let a monkey work on your bike, call the family run business on 07778 873 184 01505684994 https://www.rdbikes.co.uk [email protected]
Zeus
PostPosted: 07:31 - 12 Jun 2007    Post subject: Reply with quote
the bikes pretty new, but i had a little bump recently and it stood for over a month which I'm guessing drained the battery. it did get it going again yesterday when i went to bring it home but some tit on a bike got in the way just after i shifted up and i lost it.
Bardeey
PostPosted: 16:52 - 12 Jun 2007    Post subject: Reply with quote
You may have charged it but how topped up is it? (That's if it's acid & not gel!)
Robert2014
PostPosted: 17:16 - 12 Jun 2007    Post subject: Reply with quote
try changeing the earth wire from the battery to the body for a thicker one that should help put charge into the bike if not is the bike still underwarrntery ??d
Robert2014
PostPosted: 21:13 - 12 Jun 2007    Post subject: Reply with quote
Listen if u ant got anything good to say please bugger off as most of the chinise Bike's iv worked on has had problem's with battery not chargeing and i change the earth wire to frame and it dose the job so beat it ok
BLUEX5Posted: 17:28 - 12 Jun 2007 Post subject:
BlueX5 wrote:
I would ask you to explain this statement but I won't as i think you are just chucking ideas around based on how much crack cocaine you've eaten today.
Zeus
PostPosted: 19:24 - 16 Jun 2007    Post subject: Reply with quote
well i finally got my battery charged and back in the bike. i was just testing it with the volt meter and the highest it will go is just under 13. my haynes manual says the level should never go below 13.5. so do i have a problem or am i just being paranoid?
PostPosted: 09:46 - 17 Jun 2007    Post subject: Reply with quote
If it's a gel-type battery and you let it run flat over time then it will be knackered and you need a new one.
If it's a gel battery and you charged it with a normal-type charger and the sides are now bulging slightly they it's definately ruined.
If it's a normal lead-acid battery and you charged it on a normal charger then that voltage should be fine.
Zeus
PostPosted: 11:52 - 17 Jun 2007    Post subject: Reply with quote
ah good, thx for the feedback.
The last post was made 19 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 118.03 Kb
