Bandit S Fuel Tap
Adam.I
PostPosted: 08:58 - 11 Jun 2007    Post subject: Bandit S Fuel Tap Reply with quote
Hello all. I was fiddling around with the bike yesterday and after much struggling, I managed to get the fuel tap to turn to all three points, so now it turns freely. However, upon closer inspection, I have noticed that when it points to the up position, it says 'RES', which I assume is reserve, when it points to the right position, it says 'PRI' - perhaps primary? And when it points down, it says 'ON'. On my YBR, it says RES pointing to the top, OFF in the middle and ON at the bottom - easy, you know what they all mean, but not too sure about the Bandit, any ideas?
Veni Vidi Vici
Jamie S
PostPosted: 09:09 - 11 Jun 2007    Post subject: Reply with quote
PRI = prime
ON/Run
RES = reserve
Adam.I
PostPosted: 09:22 - 11 Jun 2007    Post subject: Reply with quote
So when I'm out and about, it should be 'ON', when I run out whilst out and about 'RES', and when I get home 'PRI'?
Veni Vidi Vici
Jamie S
PostPosted: 09:27 - 11 Jun 2007    Post subject: Reply with quote
Pri, is for when you first start your bike, it should only be used for a minute or to well the bike warms up, as soon as you want to set of you should switch it to On.
Adam.I
PostPosted: 09:31 - 11 Jun 2007    Post subject: Reply with quote
So there is no OFF position then? Ah well, just so used to flicking it to of on the YBR after I've finished.
Veni Vidi Vici
Jamie S
PostPosted: 09:44 - 11 Jun 2007    Post subject: Reply with quote
Have a look at this diagram , between the 3 positions there should be an off, it won't be wrote on it but there should be no fuel coming out when you put it to the position in the picture.
https://i155.photobucket.com/albums/s297/honda_tlr/tap.jpg
Paddy Blake
PostPosted: 11:00 - 11 Jun 2007    Post subject: Reply with quote
Res and On are off when the engine is not turning as they work by a
vacuum from the intake to the engine.
I would only use prime if the carbs were empty for any reason.
Paddy.
Kris
PostPosted: 15:14 - 11 Jun 2007    Post subject: Reply with quote
As others have said, for normal day to day riding the tap should be in the 'ON' position. If you get low on fuel then turn the tap to 'RES' (reserve) and it'll allow you to use the remainder in the bottom of the tank (~30 miles max.)
PRI is prime. I've only used this once after draining the carb floats. Basically it allows fuel to pour out of the tank petrol hoses and begin filling the carbs without the engine running.
If you ever have to take the tank off the bike, make sure the tap is in the 'ON' position. This way the fuel stays in the tank and doesn't pour out all over you and the garage floor Embarassed
www.prisonplanet.com
JonB
Afraid of Mileage
PostPosted: 10:11 - 12 Jun 2007    Post subject: Reply with quote
I only ever used the Prime once and that was when I had dismantled the carbs from the airbox and fuel tank to take my restrictors out. The bike was not starting at all, so I left it on Prime for 20 seconds and it started well.
I would not leave it on Prime whilst the engine is on. If you need additional fuel when starting normally, just use the choke. Thumbs Up
The last post was made 19 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 60.74 Kb
