Brake fade?
Itchy
PostPosted: 19:21 - 11 Jun 2007    Post subject: Brake fade? Reply with quote
Any way to prevent it or minimise it? ,its not a case of harsh over braking since I plan well in traffic and try to
keep moving at all times. my NTV seems to be suffering from it slightly recently , its not like Toby R brake fade
ie right up to the bar and its not doing anything, my discs are not warped and my pads in good condition , and
my brake fluid isn't cooking off either. I didn't notice it last year at all.
Or is it just a case of in summer its always been like that and you've only really realised it because you have a
shiney newer floating dual disc CBR sitting at home to compare it against which has very very sharp brakes. which
is possible since my GT550 felt a bit like that when I first got the NTV.
Any thoughts?
Ta
Rookie
PostPosted: 20:21 - 11 Jun 2007    Post subject: Reply with quote
As far as I know, the only way to reduce it is by buying wavey discs. The Thundercat suffers a bit from it as well, and I just had the calipers overhauled and new pads fitted. Every now and then when I've been braking heavily it's just not quite as responsive. But it's never bad enough that it becomes dangerous, so I live with it. Oh and I'm getting some braided lines fitted, but whether they'll help with fade I don't know.
mr jamez
PostPosted: 20:34 - 11 Jun 2007    Post subject: Reply with quote
Try a different pad compund. Also if the lines are the original rubber items and are past their best they will expand even more due to the heat caused by heavy braking.
Walloper
PostPosted: 20:50 - 11 Jun 2007    Post subject: Reply with quote
Brake fade on discs brake systems is not as severe as drums.
This means the drum expands due to heat and moves away from the shoe so the lever moves to compensate for the loss.
Disc brake 'fade' is a different thing.
This is down to fric
Changing/Upgrading the pad material used is the quickest route as suggested.
Also consider braided hoses.
Liquids (brake fluid) transmit force equally in all directions This pushes the pads onto the disc but also expands the rubber in the hoses. Which absorbs some of the brake lever effect.
Braided hoses are rubber re-inforced with steel wire braid and will remove some of the sponge feel. But they can reduce the fine control during light braking. You get used to it though.
I hope you didn't know all that? Embarassed
Tip:
Don't go so bloody fast and you wont need to stop as hard Laughing
curryfishball
PostPosted: 21:28 - 11 Jun 2007    Post subject: Reply with quote
sometimes if the brake fluid is too old it could have an impact. try changing that as well.
The world is a book, and those who do not travel, read only a page.
timjim
PostPosted: 22:13 - 11 Jun 2007    Post subject: brake fade Reply with quote
id agree with all the above replys so far..start of with the cheap repairs first, fit braided hoses,change the brake fluid as due to its moisture absorbing properties(its called hygroscopic..but not sure 100% on spelling) and if the fluid is too contaminated,the fluid can actually boil inthe lines,try a different pad compound..i tried EBC HH compounds but found them too unforgiving on the discs so changed them to DP sintered metals..available from,what used to be called Motorcycle City and is now called Infinity,Carcone Lorraine have also had good reviews..i cant comment on what effect wave discs would have as i only have a rear wave disc fitted at present
Syx
PostPosted: 22:25 - 11 Jun 2007    Post subject: Reply with quote
Hygroscopic is right Thumbs Up
PostPosted: 22:39 - 11 Jun 2007    Post subject: Reply with quote
Fade is due to heat. Sometimes from boiling the fluid, possible with basic DOT 3, but most likely only if you the fluid is old and has absorbed some water (which will boil at a far lower temperature).
Most likely from the pads getting way too hot.
Wavey disks might help, but not by much. You need to be using a pad with a suitable heat range for the use.
Surprised about the comment on the Thundercat brakes. They certainly shouldn't suffer from fade.
Braided hoses are unlikely to help much with fade, except for you changing the fluid at the same time. Sure there might be a tiny bit less expansion, but for that to have any real impact the brakes would need to be so bad that the lever was almost back to the bars.
gmanxiii
PostPosted: 22:48 - 11 Jun 2007    Post subject: Reply with quote
sorry slightly off topic but how are you supposed to dispose of brake fluid? i mean responsibly
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
PostPosted: 23:06 - 11 Jun 2007    Post subject: Reply with quote
I chuck it in with the used engine oil.
Rookie
PostPosted: 23:14 - 11 Jun 2007    Post subject: Reply with quote
I was suprised too; they're the brakes off an R1, they should have no problem with a Thundercat. But then again, it's an 8 year old bike and I didn't spring for expensive brake pads (mostly because he only had bog standard ones in stock) and I haven't had the discs checked out, though they look OK.
I'm hoping the braided lines sort it out, it all feels rather vague at the moment. The fade fade I can deal with, it's not bad, and only happens when I'm really flogging it. It's the lack of feel I can't deal with.
timjim
PostPosted: 23:22 - 11 Jun 2007    Post subject: brake fluid Reply with quote
ask politely at your local garage or take it to your local tip in a clearly labelled container.
PostPosted: 23:45 - 11 Jun 2007    Post subject: Reply with quote
What pads have you used?
Think the Thundercat uses smaller disks, but then it should weigh less and be going a lot slower.
I would be more inclined to try better pads / bleeding them again before bothering swapping the disks or anything like that.
Walloper
PostPosted: 00:20 - 12 Jun 2007    Post subject: Reply with quote
Local recycling centre have big tanks for oil, antifreeze and batteries etc.
Then they dump it into the land fill with your garden waste, household waste and other stuff you've carefully separated for weeks.
***Joking***
Walloper
PostPosted: 00:31 - 12 Jun 2007    Post subject: Reply with quote
Thundercat brakes are spot on.
Only thing you should notice is the cylinders are prone to seizing in the calipers and the build up of old brake pad causes the front to squeal like a boiling pig.
EBZ Pads are fine speak to your local H Gerrike chappie.
Get a drill to fit the holes in the disc and drill out the shit. It is very hard and feels like you are removing metal But batter on through each hole. Horrible job but it keeps them quiet till next pad change.
(Tip from insider at Yamaha..)
Back brake no problem except freezing as they hardly get used.
The last post was made 19 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 90.51 Kb
