Opinions on Leathers
dabigginger
PostPosted: 15:56 - 12 Jun 2007    Post subject: Opinions on Leathers Reply with quote
I'm just wondering what you guys think about leathers. I currently wear a 2-piece textile Richa suit for the bike, but I hear that leathers offer better protection. I tried a used 2-piece Richa leather suit and I just didn't feel that comfortable in them. Is it just a case of a poor fit? I mean, they felt really tight and I found it quite hard to move about. I'm 6 foot tall and 11 1/2 stone, so I'm quite slim. Are all leathers like this?
Matt06
PostPosted: 16:00 - 12 Jun 2007    Post subject: Reply with quote
Maybe a larger size?
Remember that they will loosen up after a few weeks aswell.
Current: MT-10, Bandit, Grom, GPZ500
Previous: YBR125, GSXR400, ZXR400, MT-03, NTV650, R6, z750, ZX6R, MT-09
Walloper
PostPosted: 16:37 - 12 Jun 2007    Post subject: Reply with quote
Try different makes.
You will find them tight at first but after you get a soaking in the damn things they ease off....
Should really be skin tight to keep armour in place.
It is no use if it was meant to be on your elbow but protects your bicep perfectly.
Pte1643
PostPosted: 17:46 - 12 Jun 2007    Post subject: Re: Opinions on Leathers Reply with quote
They're supossed to be tight and stop things moving about.
Helps stop your arms/legs etc "Flailing" about too much if you have an "Off".
T.C
PostPosted: 19:01 - 12 Jun 2007    Post subject: Reply with quote
I wrote this a couple of years ago for my magazine column, but still relevant, might help you!!
Head injuries, although often the most serious, are not the only injuries motorcyclists suffer. Leg and arm injuries are common, and leg injuries in particular can be serious often causing permanent disability.
Under the EC personal protective equipment directive, a series of European standards are being developed for motorcyclist protective clothing that will be designed to.
1. Prevent or reduce laceration and abrasion injuries.
2. Prevent or reduce impact injuries such as fractures, broken bones and joint damage.
These standards marked with a CE mark are essentially to help riders distinguish between clothing that offers a minimal level of protection, and garments that may look similar but offers very little if any protection at all.
Unfortunately for many riders, the buying of new leathers is often no more than a fashion statement as opposed to a desire to maximise their protection, but, contrary to popular believe you can be fashionable and protected.
As with helmets, there are accidents and injuries from which even the best or most expensive clothing will not protect the rider. It is therefore important not only to try and reduce the severity of the injury, but also ensures that the garment is comfortable, does not impede your movement and will reduce the affects of fatigue thereby aiding concentration.
Leather is still regarded as the best form of protection against injury when riding a motorcycle. They are made from a natural material, which is breathable, abrasion resistant and supple. Like a crash helmet, they cannot offer total protection from injury, but they can reduce the severity and long term affects if they fit correctly.
Leather garments can be made from 4 different animals, Cow, which is the most commonly used, Goatskin, Buffalo or kangaroo skin.
Cowhide is the preferred choice of most manufacturers. It is heavy duty (compared with the others). It is hard wearing, and in the main the manufacturers use 1.4mm thick hides, which means that in the summer weather with the thickness and all the padding they can get hot inside.
Buffalo hide is often used on cheaper garments and this can be felt in the overall quality when compared to other leather products. Buffalo is tough, will last well but it tends to be a very stiff leather and can take some time to bed in and soften up.
Goatskin although worth considering as an alternative for summer use is very difficult to find in the UK. It is considerably lighter and more flexible than Cowhide, and many consider the goatskin to be stronger than cowhide due to the fibres being more closely knit together than cow skin. The downside is that goatskin stretches a lot quicker than cow so it may require specialist tailoring on an annual basis.
Kangaroo is probably the least known of the hides used although they are being used more regularly in very hot climates. The hides are supple, light and quite tough, but it has been found that they can react with sweat particularly when worn by riders who perspire freely. If this were the case then you would probably be well advised to look elsewhere as you may find your suit literally coming apart at the seams.
For those considering purchasing leathers for the first time, the question often asked is whether to purchase a suit/jacket combination, two piece suit or a 1 piece racing suit. The choice comes down to individual preference, but here are a few points that you may find useful to consider.
1. A jacket and trouser combination is probably the most popular choice for the majority of riders, and, they can be worn singularly or in combination. However, many jackets (not all) have a Thinsulate lining for warmth retention together with a quilted lining. Many riders to complain that they overheat in warm weather which can ultimately affect concentration. However, this combination is ideal if you are an awkward size or on a limited budget.
2. A two piece zip together suit can be a good choice for a number of reasons.
- They can normally only be worn as a complete garment thereby maintaining your crash protection.
- They come in a number of colour choices therefore conspicuity can be enhanced.
- They are normally lighter than jacket/trouser combinations which for some means they will be more comfortable for summer or warm weather use.
- When stopping for a break, the jacket can be unzipped from the trousers thereby enhancing comfort when away from the bike.
- They maintain their shape and size better.
- They often have features such as perforated leather to allow air to pass through in warm weather, stretch fabric panels behind the knees, waist and inner thighs which again can enhance warm weather comfort.
On the downside, riders may also wish to consider that:
- They can normally only be worn as a complete suit.
- They can take a while to break in and mould to your shape.
- They are not particularly warm in the colder weather.
- There are not as many pockets as in a jacket/trouser combination, which for some may be a good thing.
- The colours tend to be more flamboyant than jacket/trouser combinations.
One Piece suits are the other alternative often favoured by those who ride Supersports or participate in track days. Whilst offering a fair degree of protection, for road use they have often been deemed impractical as you cannot separate them when away from the motorcycle, but more importantly in serious accident situations, the emergency services have occasionally experienced difficulty in rendering an effective diagnosis or treatment simply because they cannot cut through the leather to tend to the riders injuries, or they cannot risk removing the garment without fear of causing further injury. This of course comes down to a matter of preference.
Leather is abrasion resistant, and its main function is allow you to slide, thereby reducing friction. From new, leathers should fit as tightly as possible to allow for stretching and moulding to the wearer’s shape. If the leather is a poor fit then there is the possibility that as the rider slides down the road, the friction caused by the road surface will cause the leather to snag. This could cause a flailing limb to snag and whilst the torso is still travelling at speed, the flailing limb will slow down too quickly and can result in severe injury. On the plus side, good fitting leather can slow down any potential blood loss, particularly internal blood loss, or it can at least stem the flow until medical help arrives on the scene.
If you are unfortunate enough to be involved in an accident as a result of which you are injured (and we all hope that it doesn’t happen), at least you can be comforted that the severity will be less than if you were wearing non protective clothing, and the sympathy you receive from the emergency services and Hospital will be far more favourable than your compatriot wearing his jeans and trainers
It is better to arrive 30 seconds late in this world, than 30 years early in the next
dabigginger
PostPosted: 00:01 - 13 Jun 2007    Post subject: Reply with quote
Thanks for the info, chaps! That's really helpful! Just out of interest, does anyone know how textile jackets, or more specifically, Richa ones do in an off?
T.C
PostPosted: 08:33 - 13 Jun 2007    Post subject: Reply with quote
From an abrasion resistance point of view, Cordura is 5 times more abrasion resistant than leather, but!!!! What you don't get is the protective qualities in terms of the garment holding bones together or reducing blood loss simply because you cannot have the same tight fit with man made that you can with leather.
Bardeey
PostPosted: 09:09 - 13 Jun 2007    Post subject: Reply with quote
Last Saturday I bought my new kit.. I have always been a textile fan but since I saw Cath's photo I sort of changed my views and wanted to become a 'leather man'.
When I got there I tried them all on etc but it just didn't feel right. I was shown something quite new which personally I think is awesome!! It's an RST set that is made out of leather & textiles! (Best of both worlds)
Leather in the soft spots textiles in the hard spots.
:: P Speedfight 49cc => Gilera DNA 124cc => Suzuki Bandit GSF V 400cc ::
:: CBT=Passed 07/08/05 :: Theory=Passed 31/05/07 :: Practical= Passed 02/08/07::
powelly
PostPosted: 09:19 - 13 Jun 2007    Post subject: Reply with quote
Cath's photo?
Edit: never mind, just seen them.
I must admit Im interested on opinions on this aswell as Im currently looking for my first set of gear for my DAS.
Yamaha RXS 100 > Gilera Runner 50 > Suzuki SV650SY
robbax
PostPosted: 10:47 - 13 Jun 2007    Post subject: Just been through this Reply with quote
I've just gone round the same loop, tried on loads of things and couldn't find anything that seemed right either too tight, legs too long so knee protectors round my shins, 2 piece jacket right size pants too big etc.
The guy in the bike shop convinced me to try a 1 piece on, man what a difference, so comfortable and a much better fit than anything else. My advice would be to try a couple of suits from different manufacturers, when you get the right one they are ace if a little inconvenient (carrying things that nromally just go in your pocket like alarm fob, mobile, credit card etc) but so comfortable
Hope this helps
Dazbo666
PostPosted: 11:07 - 13 Jun 2007    Post subject: Reply with quote
I've found leathers to be a completely different fit and feel too.
I'd been riding for the best part of a year in textiles, and recently bought some Richa leathers... (Richa Slider trousers, because they're one of the few I've found that have the option of a shorter leg length).
They obviously felt quite tight at first, but after just a week or so of wearing them, I guess they've stretched slightly and now feel like they were custom made for me.
So basically if I'm riding any further than my normal 5-10 mile commute, it's leathers every time
Word of the day : DILLIGAF
dabigginger
PostPosted: 22:51 - 13 Jun 2007    Post subject: Reply with quote
My jacket is made from Gore Tex. Is that the same kind of thing as cordura?
T.C
PostPosted: 09:09 - 14 Jun 2007    Post subject: Reply with quote
No. Gore Tex is the trade name of William Gore Ltd of Scotland and is a membrane that sits between the lining and the outer material to provide the waterproofing qualities to keep you dry.
In simple terms, anything with the name "Tex" is a version of Gore Tex, for example Abletex, Aquatex, but they cannot call it Gore tex as that name is a trademark brand.
Think of it as a breathable rubber glove type analagy that keeps water out but lets body heat escape.
Cordura is a Du Pont product and is the outer material which provides the abrasion protective qualities. Cordura comes in various grades from quite fine and soft for casual wear to heavier stiffer grades for protective wear in areas such as motorcycling.
Cordura feels quite similar to canvas.
Hope that answers it for you.
dabigginger
PostPosted: 20:49 - 14 Jun 2007    Post subject: Reply with quote
Ah ha! Thanks!
The last post was made 19 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.18 - MySQL Queries: 15 - Page Size: 88.94 Kb
