linux help stupid questions
Evilbob
PostPosted: 17:47 - 08 Oct 2003    Post subject: linux help stupid questions Reply with quote
k just installed and trying to program but well have no clue what i am doing Embarassed
Q1) when i in shell i type c++ (gcc) and it dont do anything as i ashume that i havent got the programming bits installed and it keeps holding cd's hostage???
Q2) in emacs i type in code and try to compile but it says nothing to be done for my file to be done??
arrrrrrrrrrrrrrrrrrrrrrrrrrr this is sooooo going well please help me.
my karma is dieing not fair who cares about spelling? i get the point across, most of the time Smile
Evilbob
PostPosted: 17:47 - 08 Oct 2003    Post subject: also Reply with quote
what the hell is the make directory command as well????
PostPosted: 18:25 - 08 Oct 2003    Post subject: Reply with quote
mkdir to create a directory.
Don't forget to run a command in the current directory, it needs to be precceded by ./
I do think you're putting the cart before the horse somewhat though.
Also instead of emacs try pico.
Utils like pico emacs vi etc don't need the ./ but other executables do.
Evilbob
PostPosted: 20:57 - 08 Oct 2003    Post subject: linux Reply with quote
going all good but while i play i want to have mp3s playing.
any way so i only seem to get uncompiled stuff like *.tar.tz
anyway so un zip em
make em
make install
and then what the fuck happens i realise they go to /user/local/bin
but cant seem to do anything with em?!?!?! tryed asssiating it with files
making an icon and adding the prefixes
i just wanted a windo to pop up that would play my mp3s of a cd, the naff stuff with linux (red hat8) dont seem to work.
cheers
client program almost done (dancing)
EuropeanNC30R...
Gay Hairdresser
PostPosted: 22:30 - 08 Oct 2003    Post subject: Reply with quote
I had Red Hat 8 for while, it wouldn't play mp3's for me either. It said somewhere on the website it was a legal thing. There was instructions on how to sort it but they were beyond my ability at the time.
A makefile is a file that when you call it(using 'make' from the terminal in the makefile's directory), compiles all your code modules/functions at once so that they're linked together and can share code.(I think - haven't done anything with them for months and my memory's a bit sketchy Smile)
Evilbob
PostPosted: 22:32 - 08 Oct 2003    Post subject: arrrr Reply with quote
sodding language any one help
/* sending to port 7890 */
#include <iostream.h>
#include <stdio.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <netdb.h>
#include <sys/time.h>
#include <time.h>
unsigned long host_toaddr(char *who)
struct hostent *hostdata;
unsigned long *hostaddresspointer;
if ((hostdata = gethostbyname(who)) == NULL)
perror("Bad hostname lookup");
exit (11);
hostaddresspointer = (unsigned long *)(hostdata -> h_addr);
return *hostaddresspointer;
int main(int argc, char **argv)
setbuf(stdout, NULL);
int rxsock;
int txsock;
struct sockaddr_in listen_socket;
struct sockaddr_in dest_socket;
char packet_buffer[200];
if ((txsock = socket (AF_INET, SOCK_DGRAM, 0)) < 0)
{perror ("cant open tx socket");
exit (1);
if ((rxsock = socket (AF_INET, SOCK_DGRAM, 0)) < 0)
{perror ("cant open rx socket");
exit (2);
unsigned long host = host_toaddr(argv[1]);
dest_socket.sin_family = AF_INET;
dest_socket.sin_addr.s_addr = host;
dest_socket.sin_port = 7890;
/* if (sendto (txsock, packet_buffer, 40, 0, &dest_socket, sizeof(dest_socket)) < 0)
perror ("cant send");
exit (5);
Error is cannot convert `sockaddr_in*' to `const sockaddr*' for &dest_socket
GRGRGRGRGRGRG i getting a headack now
EuropeanNC30R...
Gay Hairdresser
PostPosted: 22:35 - 08 Oct 2003    Post subject: Reply with quote
Oh yeah I had the exact same problem as you when trying to compile C source files, GCC would detect any syntax errors with my code but then spit its dummy out when it came to compiling, just like it was half-installed. I tried for a while to get it working then gave up and switched to SuSE linux(where it worked fine).
Evilbob
PostPosted: 23:08 - 08 Oct 2003    Post subject: code Reply with quote
arrr nackers, might take it into uni and try there then Sad
thanks
The last post was made 22 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 58.19 Kb
