Aerodynamics vs weight?,
Itchy
PostPosted: 13:07 - 13 Jun 2007    Post subject: Aerodynamics vs weight?, Reply with quote
To fuel efficiency whats more effective ? , in one of my terribly random moments, I thought hmm what would happen if you put one of those bullet type fairings (like from the world's fastest Indian or very old style racing unlike WSB BSB or moto GP where they are banned) onto a CG125, since the CG is economical cus it weighs very little but enclosing it gives much better aerodynamics ,
but would add weight probably quite a bit compared to the bike as a whole.
I'm just bored and probably after a method to spite the Chancellor , darned running 2 bikes on petrol is costly! (esp since the CBR is somewhat thirstier than the NTV).
Any thoughts?
Ta
Walloper
PostPosted: 13:57 - 13 Jun 2007    Post subject: Reply with quote
I would hazard a guess and say...
Aerodynamic efficiency would be better than shedding weight.
Weight would be a limiting factor to get up to top speed. Though once there you only need maintain it. Less energy to maintain than to achieve.
But when you spin a weight or move it in a different direction to the direction you wish to go in you will have losses.
Problem on a bike and drag coeficient is that you are limited by the dimensions of the vehicle.
You should go outside and count buses if your bored. Evil or Very Mad Karma
There is a record for a guy on a push bike over 130mph..... Shocked (Not sure of exact figure)
But slipstreaming behind a fast car towing a big fk off board.
PostPosted: 14:35 - 13 Jun 2007    Post subject: Reply with quote
For top-speed, aerodynamics is everything. Weight means very little apart from increased internal friction (bearings, tyrewall flex etc) and more momentum to overcome so more time to get there.
Dazbo666
PostPosted: 14:39 - 13 Jun 2007    Post subject: Reply with quote
...so I should eat less pies and get myself a body suit???
I don't think anyone should be subjected to that image Sick LOL
Word of the day : DILLIGAF
kart racer
PostPosted: 14:40 - 13 Jun 2007    Post subject: Reply with quote
Aero will really only have an effect from around 70mph. I would guess below that the extra weight of the aero aids on a low powered machine such as a cg125 would outweigh the benefits.
over 70mph aero can really start to count so it could start to offset the weight you have gained from the extra bodywork.
Winners never quit, and quitters never win
wikiwiki
PostPosted: 14:46 - 13 Jun 2007    Post subject: Reply with quote
I'm a very basic person and i can only offer a basic incite,
If you're on a 125 and only pootling around town at 30-40 mph i'd say that a weight reduction would help more.
Remove the battery and engine, that fuel tank would be heavy with all that fuel in too, that'll make it nice and light.
Titanium clock surrounds FTW.
Incidentally, has anyone seen petrol at a pound a litre yet?
Amazingly i saw an esso 20 yards from old street roundabout (yeah, in the city!!) doing 93.9 per litre yesterday Shocked
Can't even get that in the supermarket stations.
PostPosted: 15:00 - 13 Jun 2007    Post subject: Reply with quote
Put a lightweight dustbin/streamliner fairing on a CG125 and gear it properly and it will go over a ton. Put a heavy fairing on the same bike pump the tyres up hard and it will go a ton again, weight has little to do with it.
Aerodynamic drag increases in square proportion to the multiple of the speed, therefore if you are going 10mph and multiply the speed by 7 to hit 70mph, you are generating 49 times the drag. Reducing the drag coefficient will give you a smaller number in the equation to multiply by 49 so any small reduction in drag coefficient will give big reduction in overall drag as speed increases. Body shape and position is also very important.
wikiwiki
PostPosted: 15:06 - 13 Jun 2007    Post subject: Reply with quote
I think i would sh1t myself if i was on a cg125 doing any more than 80.
TheShaggyDA
Repost Police
PostPosted: 15:19 - 13 Jun 2007    Post subject: Reply with quote
I think that considering the difference a simple air deflector makes when put on an artic, you'd get a better improvement sorting the aerodynamics first, then think about shedding weight.
https://img.alibaba.com/photo/11572258/Isuzu_Wind_Deflector.jpg
wikiwiki
PostPosted: 15:56 - 13 Jun 2007    Post subject: Reply with quote
Looks to me like that one's already shedded quite alot of weight in that it has no trailer Wink
PostPosted: 21:32 - 13 Jun 2007    Post subject: Reply with quote
For efficiency it will depend on the use of the bike. Round town, accelerating and braking the extra weight would be costly and the benefits nominal. At constant speed it is the other way round.
PostPosted: 21:53 - 13 Jun 2007    Post subject: Reply with quote
Consider then that 1960's 50cc TT race bikes were fitted with a dustbin fairing made of aluminium. This was considered to be a worthwhile exercise despite the (comparatively) massive increase in weight.
EDIT: Since you seem to be in a silly frame of mind, why not subject the theory to empirical testing. You will need a long, empty, level road and something heavy. I'd suggest a container full of water strapped to the back (maybe 10l to make it worthwhile? You could spend a hell of a lot of money making your bike 10kg lighter). Get the bike flat-out and dump the water, see if you go any faster.
Now get it flat out sitting bolt upright then adopot the full 'racing prone' position with your feet on the rear pegs, chin on the clocks and left hand behind your back, arch your shoulders slightly. See if you go any faster.
This should give you an idea of the relative benefits of weight loss vs drag reduction. From personal experience on my H100, I reckon moving from sitting to full prone is worth 5mph minimum on your top speed.
gmanxiii
PostPosted: 23:25 - 13 Jun 2007    Post subject: Reply with quote
you thinking of putting fairing back on your ntv? Razz
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
The last post was made 19 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 82.69 Kb
