Front Bandit Tokico caliper question
skint
PostPosted: 21:57 - 13 Jun 2007    Post subject: Front Bandit Tokico caliper question Reply with quote
Can anybody tell me if the mounting pin for the pads on the front calipers for a Bandit is threaded or does it just slide out. Mine is seized and I would like to know so that I can decide to bang it out by some method or do I have to turn it to extract it. The fiches don't seem to allude to the presence of a thread, but I thought it worth while checking first. The Bandit is a 600 K3 with Tokico calipers.
hmmmnz
PostPosted: 22:45 - 13 Jun 2007    Post subject: Reply with quote
https://images.powersportsnetwork.com/fiche/images/Suzuki/2000/Motorcycles/2118_52.gif
it just slides out
i take it your meaning
11 .PIN
59141-44B01
the humans are dead
I kick arse for the lord
skint
PostPosted: 08:21 - 14 Jun 2007    Post subject: Reply with quote
Yes, thats the one I mean. It does just look like it slides out doesn't it, but it has a 5mm hex head which made me wonder about a thread. I guess thats just for freeing it up in the first place only it doesn't seem to have worked in my case. Thanks.
BanditsHigh
Worse than a woman
PostPosted: 13:20 - 14 Jun 2007    Post subject: Reply with quote
Yep they are just a sliding fit ... take them out and clean up (if required) using some wet'n'dry ... regrease and reassemble.
You may also find that the hole that the rubber boot (7) sits in, into which the pin slides, has corrosion in in which is compressing the rubber boot and hence gripping the pin ... take the rubber boot out and clean the hole, grease it and boot slightly and then reassemble.
Check out your pistons as well ... the groove for the dust seal has a habit of corroding and forcing the seal out against the piston making it stick ... you'll need to remove the pistons and dust seal and carefully remove all of the corrosion before reassembling.
Hope you get it sorted ... Barry
timjim
PostPosted: 19:54 - 15 Jun 2007    Post subject: front caliper Reply with quote
The pads are held in with a threaded pin ..the 5mm allen key that youre talking about.It unscrews about 8 to 10 mm out of the caliper and may the need a slight tapping to get the pin out of the brake pads..dont knacker the threading in the caliper as its a 10mm x 1.0 thread and a thread chaser of that pitch isnt common.When you put the pads and the pin back in,put a thin smear of copper grease on the shaft of the pin and the thraeded portion.The pin is held tight in the caliper with a small grub screw with a slotted head which normally chews up,so is never fitted back in.ok??Tim Thumbs Up
BanditsHigh
Worse than a woman
PostPosted: 00:27 - 16 Jun 2007    Post subject: Reply with quote
The B12 pads are held in by a threaded allen headed bolt but I don't think the B6 are (see fig 11/12)!!
Anyway whatever, you'll soon work it out ... hope you get it sorted easily Thumbs Up
All the best ... Barry
timjim
PostPosted: 17:31 - 16 Jun 2007    Post subject: Bandit Reply with quote
Ive just reread your post and realised your question was aimed at an 03 bandit600..ive got a 96 Bandit600 and the brake pin is DEFINATELY screwed in..ive tried to download the parts diagram from the Bandit Owners Club site but couldnt resize it...sorryi couldnt be of more help.tim Karma
The last post was made 19 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.24 - MySQL Queries: 13 - Page Size: 52.46 Kb
