Battery problem
fazza59
PostPosted: 15:11 - 16 Jun 2007    Post subject: Battery problem Reply with quote
Hope someone might be able to help? My sons bike - Yamaha TZR50 has constantly on headlights which may not be a bad thing, however if he stops then gets back on his bike and turns the ignition on and doesn't start the bike within a minute the battery goes flat. I have checked to see if the battery is charging when it's running and Im getting 13.5 volts so all seems ok. Any suggestions as to what I can do, i.e. bypass the lights and and put on on off switch, buzzer to warn him? Or could it just be that the battery has seen its best and its time for a new battery? By the way the bike is only 18 month old.
Thanks
Current - Yamaha R1 - Yamaha XJ600N - Kawasaki GPZ 500S (project? Maybe )
Pics of my bikes
PostPosted: 15:21 - 16 Jun 2007    Post subject: Reply with quote
I would expect a half decent battery to cope with that, but being a 50 the battery is not likely to be that strong when new. If he has flattened it a few times leaving the lights on for ages before trying to start it then that will damage the battery.
For the cost of a new battery I would be tempted to fit one.
Walloper
PostPosted: 16:32 - 16 Jun 2007    Post subject: Reply with quote
Battery test.
SAFETY
Do this in a well ventilated place.
Blow across the battery to clear away any build up hydrogen gas.
If it is a wet battery and you can get to the cells through the vents/caps, then hold a probe on the + or - post and dip the other in the electrolyte/acid/liquid.
You should read about 2 Volts for each cell starting at - post working towards + post it should increase by 2 Volts as you go. Up to 12 Volts.
(You can dip between each cell too)
If you get uneven voltage say 1.9v-2.0v-1.2v etc then you have a dead cell 1.2v.
The battery is SCRAP.
Another quick test but more involved and if maintenance free type.
On a fully charged battery
Stick the bike in TOP gear.
Clamp the meter to and measure voltage across the + & - posts.
HOLD THE BRAKES ON.
Push the start button.
The starter will turn against the backwheel and stall.
(Only hold on for a few seconds 5-6)
This loads the battery same as a 'High Rate Discharge Tester' does.
The voltage across the battery should only drop a couple of volts then hold.
If it drops rapidly to zero then you have a short.
Battery is SCRAP.
Modern batteries are by design reliable and when they give it up it's normally time for a new one.
DrJustice
PostPosted: 18:37 - 16 Jun 2007    Post subject: Re: Battery problem Reply with quote
Thanks
Should still be under warranty ,I got 3 years with mine !
Take it back to the dealer .
Non Omnis Moriar
fazza59
PostPosted: 18:52 - 16 Jun 2007    Post subject: Re: Battery problem Reply with quote
DrJustice wrote:
Thanks
Battery is not under warranty, like brakes its consumable Rolling Eyes
Pics of my bikes
DrJustice
PostPosted: 20:33 - 16 Jun 2007    Post subject: Re: Battery problem Reply with quote
Thanks
I don't see how the battery could have seen its best in only 18 months !
Non Omnis Moriar
MattEMulsion
PostPosted: 09:21 - 17 Jun 2007    Post subject: Reply with quote
Well the best thing to do (and the cheapest option) would not be to turn the ignition on until he is ready to press the starter button. I can't think why you would want to turn the ignition on and leave it on without starting the bike anyway.
Yamaha YZF-R6
bugsy46
Village Idiot
PostPosted: 09:38 - 17 Jun 2007    Post subject: Reply with quote
In reply to walopers message-
If he is putting the bike into top gear and trying to start it, he can only do that with the clutch pulled in? So how is this going to try and turn the rear wheel. To perform a load test all the battery needs is a load (a high one such as the starter motor), place your volt meter across the teminals in neutral and thumb the starter taking note of the voltage drop. Why would you want to test the battery against such a high resistance? This isnt how you start a motorcycle. Any battery is going to struggle under such a load
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
Walloper
PostPosted: 10:21 - 17 Jun 2007    Post subject: Re: Battery problem Reply with quote
Whether consumable or not consumables are warrantied to provide a life within the warranty period.
Min. warranty is 1yr.
But some folk get deals from the OEM or the dealer.
Even the worst batteries on the market should give at least Three years life or more.
Fist fight the dealer or spend 50 quid for a new one.
Fight the dealer and you might lose any favour you may need later.
Or if they are 'expendible, let them Burn in Hell. Evil or Very Mad Laughing
Walloper
PostPosted: 10:36 - 17 Jun 2007    Post subject: Reply with quote
Oh!
What bike do you have cheeky chops?
Not everybike has an interlock devices you know.
If so then OBVIOUSLY you would seek an alternative way.....
You will not get sufficient load on the battery by turning the engine over and it would start then. Shocked
Loading the battery this way will not do any harm.
5-6 seconds remember.
AS I said it is the same as the load applied using a high Rate Discharge tool. either Copper Bar or Carbon Pile. Razz
bugsy46
Village Idiot
PostPosted: 10:55 - 17 Jun 2007    Post subject: Reply with quote
Its not about how much load you are applying
Its about how the battery copes with the load
What does the bike I own have to do with this subject?!
If you must know I ride a work hack sv650 which gets me to my honda dealership where I then change into my Honda technician overalls Laughing
If his battery breaks down under load whilst turning the starter motor it is faulty. And talking about alternative ways (ie the engine starting) then OBVIOUSLY you would remove the supressor cap or activate the kill switch. And anyway, common sense tells you if the battery dies after a minute of the ignition being on, and the system is putting out a suitable charge then how is the battery going to cope trying to start a bike in top gear with the brakes on!?!?
fazza59
PostPosted: 11:15 - 17 Jun 2007    Post subject: Reply with quote
I agree 100%, but he is 16 and forgets, gets ready to set off and one of his mates is talking to him and suddenly the battery is dead., not an excuse just a 16 year old air head!! Rolling Eyes
Have tried various tests and the battery is holding its charge and while running its putting charge back in, but as soon as the ignition is turned on the battery drops from 13.4 ish Volts rapidly down to 12 or less in 60 seconds. Looks like its gonna be a matter to remember to not turn on or bump it! His decision.
Thanks for you help guys
Pics of my bikes
Finglonga
PostPosted: 11:16 - 17 Jun 2007    Post subject: Re: Battery problem Reply with quote
No they have t be "fit for the purpose", and are expected to last a reasonable time before needing replacing.
Even tyres are covered in the warranty, if they develop a fault due to manufacturing faults then they must be replaced.
Simple, easiest and quickest way is take the bike to the place you purchased it and get them to fix it under warranty. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
True Blue
PostPosted: 11:20 - 17 Jun 2007    Post subject: Reply with quote
Definately think the batery is pumped mate. What does the voltage go down to if you turn the switch and crank it straight away?
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
Walloper
PostPosted: 11:27 - 17 Jun 2007    Post subject: Reply with quote
Aye aye aye.
Am far too busy for this.
Whatever you say.
Your still not 100% correct though. Wink Karma
The last post was made 19 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 94.65 Kb
