1996 VFR750F fork clunking
tatters
Exxon Valdez
PostPosted: 17:39 - 16 Jun 2007    Post subject: 1996 VFR750F fork clunking Reply with quote
Keep getting a clunk noise when the forks decompress after braking hard, l,ve checked the wheel and headstock bearings and changed the fork oil plus theres no lose bolts (including the top yoke nut).
Any ideas?
bugsy46
Village Idiot
PostPosted: 19:55 - 16 Jun 2007    Post subject: Reply with quote
did the clunking start after the oil change?
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
tatters
Exxon Valdez
PostPosted: 20:21 - 16 Jun 2007    Post subject: Reply with quote
nope its being doing it since l,ve owned the bike
bugsy46
Village Idiot
PostPosted: 20:50 - 16 Jun 2007    Post subject: Reply with quote
for a lot of forks this is normal, to be sure just check the rod operation and that the internals have been built up correctly
sickpup
Old Timer
PostPosted: 14:04 - 17 Jun 2007    Post subject: Reply with quote
Are you sure its not the calipers or brake pads moving on their mounts?
There should not be any clunks.
instigator
PostPosted: 17:04 - 17 Jun 2007    Post subject: Reply with quote
Tell that to the x000's of early sv650 owners with standard front suspension. Neutral
sickpup
Old Timer
PostPosted: 17:07 - 17 Jun 2007    Post subject: Reply with quote
There should be no clunking. If it was right they wouldn't have had to change it.
bugsy46
Village Idiot
PostPosted: 17:18 - 17 Jun 2007    Post subject: Reply with quote
Lol! Sickpup has spoken!
"THERE SHOULD BE NO CLUNKS"!!!
I shall be sure to strip down the next set of forks that clunk at work!
sickpup
Old Timer
PostPosted: 17:27 - 17 Jun 2007    Post subject: Reply with quote
So you should. Maybe if you looked at these bikes that clunk you would learn what the problem is and that it isn't always the forks that are clunking.
There should be no back and forth movement to cause clunks and no bottoming out to cause clunks. If there is theres something wrong.
Just to add to the list it could also be the disks moving on their buttons/bobbins if they are the floating types.
bugsy46
Village Idiot
PostPosted: 18:29 - 17 Jun 2007    Post subject: Reply with quote
Lol yeah ok!
Tatters, check for play in the forks themselves to see whether or not the bushes have worn past their service limits. Also check the internals to see if the previous owner has maybe built the forks up wrong. Try to narrow the noise down to see if its one fork leg. If it is chances are it needs investigating, if its both, chances are its normal. Some forks clunk, some dont.
The last post was made 19 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 64.63 Kb
