Base Gasket's Cagiva Mito!
TGR
PostPosted: 16:38 - 18 Jun 2007    Post subject: Base Gasket's Cagiva Mito! Reply with quote
Finally found abit more time to work on the Mito and this time I had to strip the top end. So I did the job I needed to do and then opened the full gasket kit and in the kit is 3 head gaskets Shocked so since I took only one gasket off which one would I use?
https://img175.imagevenue.com/loc366/th_81490_001_122_366lo.jpg
top blue one is the thickest and the other blue and the black are basically the same thickness as each other just different colours.
1991 Kawasaki ZXR400L - 1999 Suzuki GS500E - 1990 Kawasaki ZX750R H2 - 1991 Honda CBR 600 - 2015 Skyteam Monkey 125
salty21
PostPosted: 19:10 - 18 Jun 2007    Post subject: Reply with quote
maybe different thicknesses to adjust the squish thing(the gap between the cylinder head and the piston at TDC) but may be wrong, im sure someone will be along shortly to correct me if i am
tatters
Exxon Valdez
PostPosted: 19:18 - 18 Jun 2007    Post subject: Reply with quote
There base gaskets the mito uses a orange "o" ring for the cyilnder head
TGR
PostPosted: 19:37 - 18 Jun 2007    Post subject: Reply with quote
@ tatters
Thank you for the correction Thumbs Up changed the thread title to reflect the issue Smile
@ salty21
Thank you Smile
The last post was made 19 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 41.02 Kb
