Leaky tank around pivot arm weld - NSR125R
Jinkz
PostPosted: 20:48 - 18 Jun 2007    Post subject: Leaky tank around pivot arm weld - NSR125R Reply with quote
Got petrol leaking and have narrowed it down to the pivot, problem is the leak is coming from underneath it Sad
Fuel is coming out very slowly in the right position (I mean slow as in a drip a week) but when I take the tank off and put it on its end it comes out a lot, seeps out.
I did have a small crash on it, and possibly thinking I bent it in the process to cause the hole.
Whats the best thing I can do?
baldy
PostPosted: 21:21 - 18 Jun 2007    Post subject: Reply with quote
Dont they do something you can put in the tank to seal it up?
One day i will rule the world, just not today.
Jinkz
PostPosted: 21:52 - 18 Jun 2007    Post subject: Reply with quote
Had a quick search on that, Frost tank sealer! All sorted me thinks.
Paddy Blake
PostPosted: 22:29 - 18 Jun 2007    Post subject: Reply with quote
Plastic padding,chemical metal.
https://marinestore.co.uk/page/mrst/PROD/plastic-padding-products-isopon/MD171295/
Paddy.
Resurrection
Ballast Boy
PostPosted: 22:31 - 18 Jun 2007    Post subject: Reply with quote
If your after a quick fix try some bluetak or something
Res
ZX9r
Jinkz
PostPosted: 09:04 - 19 Jun 2007    Post subject: Reply with quote
Of those 2 which is best to go for? Chemical metal seems appealing but messy?
Robby
Dirty Old Man
PostPosted: 09:07 - 19 Jun 2007    Post subject: Reply with quote
Petseal - 2 part epoxy resin that seals the tank up from the inside. Good stuff.
Jinkz
PostPosted: 18:04 - 19 Jun 2007    Post subject: Reply with quote
Would any of the stuff you put inside the tank effect the res at all? It won't seal it or anything? Bit dubious about the option.
The last post was made 18 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 54.27 Kb
