Changing exaust - derestricting an NS125R
c-m
PostPosted: 10:33 - 20 Jun 2007    Post subject: Changing exaust - derestricting an NS125R Reply with quote
I understand that the NS125R (not nsr) is restricted by two plates in the exhaust which are a bitch to get out.
If I aquuire an unrestricted exhuast, will I need to change anything else, such as the carb or air box?
If so what exactly would need doing?
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
alains
PostPosted: 10:53 - 20 Jun 2007    Post subject: Reply with quote
i think you have a carb dellorto 26 with a main jet of 110 , you should upjet your main jet by 10 points and the slow jet by 4 points
c-m
PostPosted: 11:05 - 20 Jun 2007    Post subject: Reply with quote
ok, thats no problem.
would that just be for the exhuast change, or would I need to up the airflow too?
alains
PostPosted: 11:58 - 20 Jun 2007    Post subject: Reply with quote
later if necessary . control your plug after 30 miles , if it will be darker than chocolate you will open it a bit . look also at which notch is set the throttle needle and before opening your air box lift 1 notch
The last post was made 18 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 40.13 Kb
