CDI replacement
janquad
PostPosted: 19:19 - 21 Jun 2007    Post subject: CDI replacement Reply with quote
Any one know if there is a generic cdi replacement for bikes?
PostPosted: 19:40 - 21 Jun 2007    Post subject: Reply with quote
No, no generic units. It controls the ignition timing, and the timing will vary between different engines depending on loads of factors (eg, compression ratio).
janquad
PostPosted: 19:45 - 21 Jun 2007    Post subject: Reply with quote
so if there were generic cdi one could make money out of them if you could make them?
PostPosted: 20:22 - 21 Jun 2007    Post subject: Reply with quote
Maybe. There are aftermarket ignition units used to play around with the timing to get slightly more power (at the expense of needing to use high octane fuel, and removing the safety margin before you suffer from detonation). However these are generally not direct plug in units.
For normal use most people would just fit an igntion advancer.
As cdi units don't fail that often (few bikes are exceptions) then most of the time you can pick up a 2nd hand one for reasonable money.
nocduk1
PostPosted: 18:07 - 22 Jun 2007    Post subject: Re: CDI replacement Reply with quote
could try northwest motorcycle services at southport uk tel 01704531616
The last post was made 18 years, 186 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 48.72 Kb
