Jetting...
eddclarke
PostPosted: 22:23 - 21 Jun 2007    Post subject: Jetting... Reply with quote
Ive finally got the baffle out of my arrow exhaust, i know ill need to rejet it, but what harm will be done if its not rejetted straight away?
Oh and its a xr125
thanks
Honda XR125L 06 ----> Yamaha FZ6 05 + ex SAS XR250 --> VFR800 + XR250r
teampots
PostPosted: 22:27 - 21 Jun 2007    Post subject: Reply with quote
probably wont do a thing unless you get a new air filter to go with it, just means the exhaust gasses pass out easier, the air going in to the engine wont be cleaner unless you do have a aftermarket air filter so shouldnt run lean
in short it wont do naff all to the engine unless you get an aftermarket airfilter to go with it thats really when you may need to rejet but its not really a big deal imo on a 4t single
Current - Fazer 600
Prev - Bandit x2 (Killed) CB400 (Superfour) CBR125
Currently Restoring - Kawasaki S1 250 Triple (Slowly but surely)
teabag
PostPosted: 14:20 - 22 Jun 2007    Post subject: Reply with quote
I've got an XR125L and was thinking about the arrow exhaust when the OE one finally rusts through.
I've already opened out the third port on the airbox inlet. The bike seems to maintain speed a bit better on hills or in headwinds with this mod.
What difference does the Arrow make, if any?
NS125R = 2 years > GSX600F = 7 years > XR125L = 3.5 years > SV650S........and a Citroen Synergie HDI for the kids.
eddclarke
PostPosted: 15:01 - 22 Jun 2007    Post subject: Reply with quote
It doesnt really make a difference, maybe a teeny one, Can you explain what i need to do to the air box? ive not heard about this before
Odie
PostPosted: 15:21 - 22 Jun 2007    Post subject: Reply with quote
ERRR, weak mixture = holed piston Thumbs Down
teabag
PostPosted: 16:47 - 22 Jun 2007    Post subject: Reply with quote
If you take the seat off and remove the top of the airbox, you'll notice that the rubber air intake duct has got one of the three holes blocked (at least mine did). Using a sharp knife, carefully cut out the membrane blocking the middle hole, trying to keep the edges smooth. With this and the baffle less pipe you will definitely need rejetting.
The last post was made 18 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 47.97 Kb
