Tips for the rain?
AngelGrinder
PostPosted: 21:52 - 24 Jun 2007    Post subject: Tips for the rain? Reply with quote
Been out a few times in the rain (I have only done a CBT, so not taught much about the rain) and just wondering on peoples tips for riding in it?
Earlier I managed to lose the back end quite badly, nearly came off, but luckily stayed calm, took rear brake off, applied front and put my feet out...
Lesson - Don't use rear brake much in rain.
How much can you lean in the rain, whats the best technique to getting round tight corners? Go really slowly, or will the bike grip much more than I would think?
Also... not that it applies, but I've heard conflicting views - when carrying a pillion passenger, should they lean with you, or stay upright?
Cheers!
P.s I will be doing proper test, and having lessons shortly to improve my abilities.
Jamie S
PostPosted: 21:57 - 24 Jun 2007    Post subject: Re: Tips for the rain? Reply with quote
They should just relax and lean the way the bike goes , but not over-lean if you know what I mean ?
AngelGrinder
PostPosted: 22:05 - 24 Jun 2007    Post subject: Re: Tips for the rain? Reply with quote
Yeah, just tell them to relax and go with the flow Cool
TomR6
PostPosted: 22:19 - 24 Jun 2007    Post subject: Reply with quote
Avoid manhole covers, but if you have to go over them, keep it straight and go over smoothly.
2005 Yamaha R6
faddius
PostPosted: 22:28 - 24 Jun 2007    Post subject: Reply with quote
Good tyres are a bonus.
Drive smoothly, dont downshift too quickly and dont pull away from lights too quickly.
Dont lean too far over, lean in slowly and you can generally feel where the tyre is happy before it starts sliding.
Dab your brakes every now and then to keep them dry, spray from the road soaks the discs and the pads wont bite for a couple of seconds if you brake which can be fatal.
As for pillion, same as above, just be more careful, you have extra weight on the back wheel so its more likely to slide if you try a corner too hard, and because of the weight you got less chance of coming back up.
Oh, and dont feel its fun to go round a shallow bend on an A road at 90 and go through a puddle whilst lent over, did that today, swear both tyres slid a couple of inches before gripping again Sad
AngelGrinder
PostPosted: 22:37 - 24 Jun 2007    Post subject: Reply with quote
I am still only just getting used to going round bends at about 40mph (not that the bike will go much faster than that lol)
Shook me up a bit earlier when the back really wobbled....alot, nearly threw me off, but happy with my response of not panicking and rectifying the problem....so...think it was a good lesson!
faddius
PostPosted: 22:49 - 24 Jun 2007    Post subject: Reply with quote
Oh another thing, have a good idea on how to estimate what the roads are going to be like.
You can walk out into the middle of the road and rub your foot around a bit to see if its greasy, or theres this you can remember.
Road looks dry, rained within the last few days - Roads are good.
Road looks dry, hasnt rained for a long time - Longer it hasnt rained, greasier itll be
Road looks semi dry, been raining that day - Generally ok, look out for petrol and diesal.
Road looks semi dry, hasnt rained that day - Same as above
Road looks wet - been raining lightly - Be careful, alot of grease
Road looks wet - been raining heavily for a short while - Same as above
Road looks wet - been raining heavily for a while - Roads shouldnt be greasy, keep eye out for puddles, tyres wont grip as well as in the dry but will grip quite nicely.
Im sure you could work out the logic behind each one and use common sense to be able to tell what roads will be like in the future. Very Happy
TomR6
What do you ride?
2005 Yamaha R6
AngelGrinder
PostPosted: 22:52 - 24 Jun 2007    Post subject: Reply with quote
T0M wrote:
What do you ride?
SR 125
AngelGrinder
yea, makes sense, good to know that the tyres still do alright in the rain.
keyser soze
PostPosted: 23:49 - 24 Jun 2007    Post subject: Reply with quote
thing i like about riding in the rain is once you are used to it you'll be a better rider.
things to avoid in the rain are manhole covers, white lines and writing, cats eyes, crossings, joints in the tarmac. only brake when up right. stay away from the car in front. change gears smoothly.
oh and stay warm and dry.
Dalemac
PostPosted: 00:28 - 25 Jun 2007    Post subject: Reply with quote
also when they rip up bits of road, they retarmac it then put som form of black sealant around the edges to prevent cracking, avoid that also as it is very slippery when wet.
YBR125 -> GPZ500S -> SL1000
alun111
PostPosted: 07:48 - 25 Jun 2007    Post subject: Reply with quote
don't accelerate as fast and brake early and certainly don't shift down too early as the back can swing right out.
iooi
PostPosted: 08:54 - 25 Jun 2007    Post subject: Re: Tips for the rain? Reply with quote
Well not that i would recomend trying this but get someone on the back and try getting them to stay upright while you attempt to go round a corner...... Confused
Last time someone did that to me they had to walk home as i refused to take them any further..... Did wonder for a while afterwards why i never got a 2nd date... Crying or Very sad But life goes on and i want to go round corners....
As to your braking, just think what happens when the front lets go... Unlike the rear where you have some control, when the front goes you are on the deck.
Just increase your distances and do everything smoothly. If you have to cross manholes, white lines etc do not attempt to do anything while on them, just let the bike flow over them.
Stuff like that is far worse at slow speeds.
sagalout
PostPosted: 09:31 - 25 Jun 2007    Post subject: Reply with quote
Riding in rain is all in the head. The bike will happily lean as far as you lean it in the dry, unless you regularly scrape the pegs.
Its braking which is more likely to cause a problem. Obey the 4 second rule, dont apply the brakes mid corner and generally just be as smooth as possible and you'll be fine.
Louise
PostPosted: 10:25 - 25 Jun 2007    Post subject: Reply with quote
All the horror storys I hear & 'offs' people have had on BCF in the rain has put bad image in my head.
I just take it easy. I promised myself I wouldnt take a pillion in the rain, But I had no choise last week. Wasnt too bad, just tell them to relax as they normally would.
eifion
PostPosted: 11:04 - 25 Jun 2007    Post subject: Reply with quote
The worst is the the first half hour or so of rain after a long dry spell. All the oil and crap that's soaked into the road comes to the surface on the rain and it's really greasy. Once it's been raining steadily for a while the roads are wet, but pretty clean, so shouldn't cause too much problem.
Avoid manhole covers if you can, they can be very slic in the wet, but if you're upright and heading for one it's often better to ride over it than try to swerve around it on a wet road at the last minute. Just relax, keep the bike upright and ride smoothly over, don't touch the break, and give enough power to maintain your speed so you keep the bike balanced.
SR125 -> 6 year gap -> SV650 -> Deauville -> NC750X -> Vstrom 650
T.C
PostPosted: 11:59 - 25 Jun 2007    Post subject: Reply with quote
Rain, Rain, Rain!
Why do so many people dislike riding in the rain? Is it because they feel that the tyres won’t grip? Is it because to them riding on wet roads is like riding on a bed of glass? Is it simply the thought of getting wet that puts people off? Regardless of the reasons, wet weather riding is something that we riders in the UK have to contend with from time to time, even if it is no more than being caught out in a shower in the middle of summer!
Believe it or not, wet weather riding is not an issue if you are mentally prepared for it, and by applying a little bit of thought to the subject it shouldn’t be an issue for any one of us.
Firstly, the most potentially dangerous period is after a long hot dry spell, the rubbish that gets left on the road such as rubber and oil deposits can cause a problem in the first few hours after it starts to rain. These deposits tend to roll up into little balls and the marble affect will be a factor not dissimilar to those experienced by racing riders when they go off the racing line in the dry, so obviously care is required in that initial period.
However, the main problem in many cases not the road but the rider as a mental block often kicks in and they believe that an accident is just around the next corner, why? Well in most cases it is a combination of two things, one is the belief that the tyres will not grip as well in the wet as they do in the dry. Well that is true to a point, but (unlike when I first started riding when tyres were 95% nylon and 5% rubber) modern tyres are actually very good at providing wet weather grip, and the level of grip will actually far exceed the ability of the average rider.
The second factor is that often at the first sign of rain, many riders tense up, and this tenseness is transmitted to the bike and so the whole operation of the motorcycle becomes what I term “mechanical”. What this means is that rather than just relaxing and let the bike handle normally, they feel that they have to be in the permanent braced position where even the slightest of movements on the handlebars is over exaggerated as they try to negotiate the bend as upright as possible.
A modern motorcycle will handle just about anything that is thrown at it in terms of weather conditions these days, the key to good wet weather riding is smoothness and the ability to relax.
Harsh or jerky throttle movements will cause the bike to shake its tail particularly when exiting a bend, excess speed in conjunction with poor throttle operation will cause serious problems, but smooth delivery of the power in combination with a relaxed riding style will eliminate the majority of the problems that might otherwise be encountered. As an example, next time you see a wet race on the television, look at how much smoother the riders are in comparison to when it is dry. Look at the angles of lean. OK they won’t lean as far as they would in the dry and their speed through the corners will not be as high, but the bikes will still turn in very respectable figures simply because the riders are relaxed and smooth, well this is a principle we can transfer from the track to the road.
Braking distances as well as speed need to be adjusted to cope not only with changes in the road surface, but also to counter the fact that visibility will be reduced which will affect reaction time, but, much to many peoples surprise bikes will actually stop very well in the wet providing it is upright and travelling in a straight line.
The whole key to good and in some cases enjoyable wet weather riding is smoothness! Smooth power deliver, smooth braking (done in plenty of time as well) along with a relaxed riding style will often have a very positive affect on the way the bike performs and your overall enjoyment of riding in wet weather.
It is better to arrive 30 seconds late in this world, than 30 years early in the next
LeeR
PostPosted: 12:45 - 25 Jun 2007    Post subject: Reply with quote
Top post T.C. and your sig. was my mantra on the way to work today. Karma Thumbs Up
My claim to fame: Austin Vince nicked my pen...
DaveW
PostPosted: 15:32 - 25 Jun 2007    Post subject: Reply with quote
T.C wrote:
Rain, Rain, Rain!
Very well illustrated this weekend at Donnington!!!
I think the problem is building confidence and trust in the bike in the wet and I'm a sucker for that too, but remembering the rule of looking ahead round the corner rather than at the floor with that big shiny wet grid in the path helps a lot as you tend not to tense up as much.
But I wouldn't go doing a Rossi round the bends as fast as I do in the dry - not enough confidence yet.
Take your time, relax and keep it smooth. You may still have a wobble on a wet grid, but it should only be that if your taking it steady. Also if using the rear brake, use it only in conjunction with the clutch OUT, even in the dry this applies, it will lock easily as the weight is transfered to the front making the back light. I've locked the rear wheel after a bit of right hand action and trying to brake hard and gear down at the same time by pulling the clutch - really you should ease off the rear brake, but its easy said than done. Very Happy
Note: Can you take pillion on a 125 with just a CBT - I thought not unless you have passed your test. But yes tell the pillion to lean with you, if they stay upright, you'll find the bike will run wide!!
Yamaha R6 '05 model, upside down forks, radial brakes, Blue flame can, dubble bubble and clear turn signals - as they say in America
AngelGrinder
PostPosted: 18:50 - 25 Jun 2007    Post subject: Reply with quote
No you can't was just wondering, wouldn't dream of ever putting another persons life at risk by being illegal and in-experienced!
Kal
PostPosted: 19:18 - 25 Jun 2007    Post subject: Re: Tips for the rain? Reply with quote
Cheers!
Your bike probably has mre grip than you think it does however nothing wrong with playing the safety game when you aren't confident.
Plan everything earlier. Slow everything down - cornering slower allows the bike to stay closer to its most stable position than cornering quickly - it also gives you more opportunity for observation reducing your braking streses all round.
Apply brakes gently, consistantly and earlier. In wet conditions you should be looking at 50/50 split rather than dry weathers 70/30 opitmal front/back split.
Distance - open your travellng distance up. The 2 second rule becomes 4 (in the ice I'd suggest doubling it again). If someone decides to pull into your observation space drop back. Don't be temtped to close it up, even if you are late - it's better to be a little late than to take a side trip to hospital and arrive even later.
Be smooth. Lots of people spend their summers learning how to go quickly and get their knees down on rounabouts, I'd suggest you won't go far wrong if you learn how to get your acceleration, braking and gear changes totally smooth but then I hate the pillion woodpeaker effect.
Kal...
ilovensr
PostPosted: 10:30 - 26 Jun 2007    Post subject: Re: Tips for the rain? Reply with quote
i remember this question from my theory, and on ice your stopping distances can be 10 times longer than on 'normal' dry roads, so id say 8 seconds is a bit optimistic, might want to make it a bit longer Confused
Current Bikes:
Honda NSR125 >>> Garaged
Kawasaki ER5 >>> Excellent commuter
Kal
PostPosted: 11:58 - 26 Jun 2007    Post subject: Reply with quote
Only problem with that is at 30mph you'd be giving away over 250m. I wouldn't want to try that in town - giving away 100m is bad enough.
Kal...
Resurrection
Ballast Boy
PostPosted: 20:15 - 26 Jun 2007    Post subject: Reply with quote
Thats all well and good for that section of that road your foots on.
If you live anywhere like i do road surfaces and textures and camber etc can change every few hundred yards so that info you've just given is rubbish and you could end up getting someone inexperienced hurt if they generalise and think something is unsafe and don't ride properly or are too cocky because there street looked alright.
Angel what you wanna do is don't push yourself and ride within your limits.
Judge each situation on its own factors and dont panic.
Remember your bike will only go as fast as you want it too.
Res
ZX9r
The last post was made 19 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 140.83 Kb
