NC30 VFR400 Help needed
Zed6
PostPosted: 23:31 - 29 Jun 2007    Post subject: NC30 VFR400 Help needed Reply with quote
What does it mean when the alternator plug has melted on the engine, not the regulator (that's fine)?
Do i need a new alternator? or just the plug, any help will be great, cheers.
Cog Head
PostPosted: 23:55 - 29 Jun 2007    Post subject: Reply with quote
i would have thought that the plug cap has melted to your engine, in which case, get a stanly blade and a lighter and heat the blade and cut the melted crap away,(get rid of all of it before you remove the spark plug just to make sure its not nakered)
then buy and replace the plug cap
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
Zed6
PostPosted: 00:53 - 30 Jun 2007    Post subject: Reply with quote
Ah right, cheers I'll try that Thumbs Up
Phoenix
Twisted Firestarter
PostPosted: 03:14 - 01 Jul 2007    Post subject: Reply with quote
I think Cog Head has somewhat misread your post, he's referring to spark plugs and plug caps, not alternator plugs.
If the alternator wiring plug has melted then it means that the regulator is probably on it's way out and isn't correcting the voltage properly and is overheating therefore melting the plug, it's the usual initial symptom. That and if you headlights dim when you rev the bike rather than go brighter, or you get a misfire at high rpm.
binge
Emo Kiddy
PostPosted: 05:55 - 01 Jul 2007    Post subject: Reply with quote
You are probably due a New regulator as has been said. Common fault on CBRs/VFRs etc.
<|ben|>
The last post was made 18 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 42.4 Kb
