wet & dry
numark1
Scared of girls
PostPosted: 11:06 - 01 Jul 2007    Post subject: wet & dry Reply with quote
I want to remove the "not for road use on my exhaust" and have looked at how to wet and dry it but i still am unsure. can anyone tell me how?? i have 400 800 and 1200 grit. do you actually wet the paper or what? how do you do it??
Thanks ( i did search all round first)
Whosthedaddy
PostPosted: 13:33 - 01 Jul 2007    Post subject: Reply with quote
Use the paper wet.
Stick them in a bucket of soapy water and just keep moistening after a few minutes of hard scrubbing.
The lower the number the coarser the grit or grain.
Start with the rough stuff and then go though the finer and finer grades to establish a mirror finish thats as smooth as a smooth thing.
The Tot
PostPosted: 14:46 - 01 Jul 2007    Post subject: Reply with quote
I started off with wire wool/brillo pads, then i took some good quality wet and dry paper from uni. I started off with 120 and got it as rough as possible -took a good few hours of elbow grease - wetted with warm soapy water before proceeding to 240 then 400 then finished off with an 800. I left it at that, but there's no evidence of a not for road use stamp on it. I've not bothered getting a mirrored finish.
Never argue with autism
Walloper
PostPosted: 00:56 - 02 Jul 2007    Post subject: Reply with quote
Wet & Dry paper is used as an alternative to Glass Paper as a waterproof adhesive is used to bond the abrasive to the backing.
As an abrasive is used it clogs with the material removed and this reduces the effectiveness of the abrasive.
So wet & dry can be rinsed in water which washes out the waste
and restored to almost as new again. Eventualy the abrasive is worn down by mechanical wear and you replace with fresh.
Glass paper is not waterproof so if it gets wet the abrasive falls off. Crying or Very sad
gazzabo
PostPosted: 02:21 - 02 Jul 2007    Post subject: Re: wet & dry Reply with quote
thats illegal isn't it . Shocked
RD50 < RD125 < 750 Zepher < Fazer 600 < FZ1000 , in silver/black , sex on wheels .
If you love your bike, set it free......
If it comes back you've high sided.
Walloper
PostPosted: 10:14 - 02 Jul 2007    Post subject: Re: wet & dry Reply with quote
No you can use any grit you like.
But it is illegal to spend most of a sunny Saturday afternoon doing so when you should be out putting heat in the bloody tyres.
It is not illegal to remove the marking.
It would be illegal to use the vehicle on a public road if the marking has been tamerfered with.
The last post was made 19 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 50.32 Kb
