tech help :-(
Kris
PostPosted: 12:06 - 17 Oct 2003    Post subject: tech help :-( Reply with quote
Alright this is one for the techies Very Happy Please look at the attached screen dump.
My pc at work keeps locking up when performing some functions in AutoCAD (a drawing program). The file I'm opening is not large btw. The CPU usage looks to be flatlining at 100%. Could someone please explain to me what this means and what would remedy the situation - just so I'm armed when I approach the I.T dept....
Very Happy Please keep it 'low-tech' in the explanations please!
www.prisonplanet.com
PostPosted: 12:14 - 17 Oct 2003    Post subject: Reply with quote
You may have been better off showing us the AutoCAD screen. Smile could be a bug in AutoCAD, a memory leak or something. Try upgrading it to the latest version. The CPU usage doesn't tell us a lot, apart from that you'd be better off with a faster machine!
What version of AutoCAD are you running??
one1895
I liked BCF so much I made my own copy
PostPosted: 12:16 - 17 Oct 2003    Post subject: Reply with quote
Have you tried CTRL+ALT+DLT and closed any background programs you're not using? Using the 'msconfig' command under start/run can disable programs starting up.
What's the spec of your PC?
Hull & Yorkshire Bikers - Sheffield & Yorkshire Bikers - Manchester Bikers - Nottingham Bikers
Kris
PostPosted: 12:18 - 17 Oct 2003    Post subject: Reply with quote
2000 LT
We've used the licenses for 2002 on other machines so I'm stuck with this one. (although it's fine as it is TBH) And I think the pc would run even slower with 2002.
BTW I've worked on much bigger files than this one with no probs before Confused I thought it may be the server I'm working on slowing it up - so copied the file to the hard disk to work on. Still no better Sad
andrew
Mister Road Rage
Didnt think msconfig worked under NT??
Open the proccess window in task manager and see if any proccess other than auto cad is using too much processor time. I doubt its an auto cad memory leak because you would have noticed it a while ago. Definatley something else causing the problem. Also is it possible to try and open the file on someone elses machine? See if it does the same on theirs.
Kris
PostPosted: 12:19 - 17 Oct 2003    Post subject: Reply with quote
Pentium DELL Dimension XPS D333 using winblows NT. No idea about the rest Mr. Green
andrew
Mister Road Rage
PostPosted: 12:22 - 17 Oct 2003    Post subject: Reply with quote
Duh! Have you looked in the process list?
EuropeanNC30R...
Gay Hairdresser
PostPosted: 12:23 - 17 Oct 2003    Post subject: Reply with quote
Sounds like a bug in the program.
Kris
PostPosted: 12:25 - 17 Oct 2003    Post subject: Reply with quote
just autocad open. nothing like you said Confused
dainesefreak
PostPosted: 12:26 - 17 Oct 2003    Post subject: Reply with quote
MSConfig doesn't exist in NT. Post a picture of the Task List Kris. A 333mhz machine isn't the speediest of machine to be running CAD.
andrew
Mister Road Rage
PostPosted: 12:30 - 17 Oct 2003    Post subject: Reply with quote
Nothing open? your looking in the wrong window, your looking in the applications tab, go to the next one accross it says "processes" on it. There might not be anything eating up the cpu but there should *definatley be other stuff open in it. Have another look. And the spec of the machine isnt really relevant if youve only started getting this problem.
Demonic69
The Pink Rhino
PostPosted: 12:35 - 17 Oct 2003    Post subject: Reply with quote
Your processor's too slow. buy a new one Very Happy
Back on a Blade. Just feels so right.
Kris
PostPosted: 12:37 - 17 Oct 2003    Post subject: Reply with quote
No i mean no other programs open. No other applications using much cpu time either Confused
andrew
Mister Road Rage
PostPosted: 12:38 - 17 Oct 2003    Post subject: Reply with quote
What deano said ^^^ Smile
Kris
PostPosted: 12:40 - 17 Oct 2003    Post subject: Reply with quote
I've got 75p Very Happy
Whats in my price range?
Demonic69
The Pink Rhino
PostPosted: 12:41 - 17 Oct 2003    Post subject: Reply with quote
That Brand new P67 Invisible processor! It's got unlimited GhZ performance with a 33333333333MhZfsb Very Happy
WildGoose
White Van Man
PostPosted: 12:43 - 17 Oct 2003    Post subject: Reply with quote
nah, you'd be better of with one of these #
https://www.akadsek.de/new/images/hamster.jpg
i run an Intel Hamsterium Processor 450, not bad for the money
andrew
Mister Road Rage
hhhmmmm i have 75p on my desk ill take one two deano.
Kickstart@Work
PostPosted: 12:57 - 17 Oct 2003    Post subject: Reply with quote
If it is running at 100% cpu then it is hammering something.
I would suspect the file is corrupt. Not sure about Autocad but I presume that some of the info is stored as complex equations, and that these are evaluated to produce the display on screen. My guess is that it has landed up corrupted and is trying to evaluate something that has no solution.
Short time check I would try loading it onto another machine first though.
Atheism is a not for prophet organisation
The last post was made 22 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 100.35 Kb
