| 17-in-87 |
 17-in-87 Trackday Trickster
| iloveriding |
 iloveriding Trackday Trickster
| 17-in-87 |
| iloveriding |
| stinkwheel |
 Posted: 23:08 - 03 Jul 2007 Post subject: |
Take it for a ride then feel the coolant pipes. If they're rock-hard, it's probably bad news.
With a blown head gasket they loose coolant due to overpressure in the radiator rather than overheating. So, the bike overheats but it does it AFTER loosing the coolant, not before.
So, look at the fluid level in your coolant bottle. Take bike for a short wazz (enought to get the revs up but not to get the bike hot) then check the coolant bottle. If it was halfway and is now brimming, it's probably the head gasket. Could also be a defective radiator cap but usually isn't.
Another way would be to tape a small container onto the expansion bottle overflow pipe. Go for a short razz (again, not enough to get it hot but get the revs high) and check for coolant in your bottle.
When the head gasket went on my GPZ, it was just a tiny little jet of gas going between the cylinder and the coolant jacket. Initially it was fine up to about 8,000rpm at which point it overpressured the coolant and spat it all out. You could ride it all day long at 7k with no problems, push it to 8k and it puked all the coolant out in about five miles. The engine speed at which this happened gradually got lower and lower as the 'jet' got bigger.
EDIT: If it was loosing coolant into an oilway, you'd get mayonaise in your oil. If it was loosing coolant into your cylinders, you'd get white smoke out of the exhaust.
If it was loosing it out of a leak, you'd get a puddle.  ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| teampots |
 teampots Spanner Monkey
| i_am_tim |
 i_am_tim Nitrous Nuisance
| JakeyR |
 JakeyR World Chat Champion
 Posted: 13:54 - 04 Jul 2007 Post subject: |
| 17-in-87 |
 Posted: 18:29 - 04 Jul 2007 Post subject: |
Quick update - think I've sorted it.
Checked the oil for water contamination, or at least tried to. Normally check the oil level every week or so when I clean the bike, haven't cleaned the bike for a while because of the bad weather, it would appear that my oil level has dropped through normal use, making the bike run hotter than normal, therefore evaporating more water than normal.
Topped the oil up (half a litre before I could even see it in the window ) bike is now running cooler, coolant level seems to have sorted itself out.
Note to self - check your oil more frequently...
Thanks for all replys. ____________________ K1 GSX-R 600 - blue n white of course....
Growing old is compulsory - growing up is optional... |
The last post was made 18 years, 283 days ago. Instead of replying here, would creating a new thread be more useful? |
