Should bikes have a reverse gear?
Fahd
PostPosted: 17:51 - 04 Jul 2007    Post subject: Should bikes have a reverse gear? Reply with quote
I know it sounds like an incredibly stupid question because unless you're some sort of gymnastic clown you can't balance a bike backwards, however with incredibly heavy bikes like the Suzuki Hayabusa why don't they just put a reverse gear on to help the rider out, for example I can't see it being very fun trying to roll one of those backwards uphill even if it does increase your leg strength like nothing else on Earth... Razz Anyway before I get flamed and told it's just being lazy, it's just an idea & this is a forum after all... Cool
I Ride: Honda CBR 400RR.
I Drive: Audi S3.
veeeffarr
PostPosted: 17:57 - 04 Jul 2007    Post subject: Reply with quote
Dangerous as fuck on a sequential gearbox?
T
St0rmer66
PostPosted: 18:00 - 04 Jul 2007    Post subject: Reply with quote
As Toby hinted on, only if it was separate to the other gearbox somehow, so you couldn't accidentally select it.
I think the Honda Goldwing already has a reverse gear anyway.
:: Honda XR 125 L ('53) => Kawasaki GPZ 500S ('02) => Suzuki SV650S ('00) => Aprilia RSV-R ('51) ::
Jamie S
PostPosted: 18:02 - 04 Jul 2007    Post subject: Reply with quote
Honda goldwings have , but on a bike that big you need it.
Edit. ^ beat me to it
hmmmnz
PostPosted: 18:03 - 04 Jul 2007    Post subject: Reply with quote
the goldwings have a reverse gear, and a electric center stand Very Happy
basically a car with only 2 wheels Very Happy
the humans are dead
I kick arse for the lord
Jamie S
Really ? hows that work then ?
Whosthedaddy
PostPosted: 18:04 - 04 Jul 2007    Post subject: Reply with quote
So the question still stands why shouldn't all bikes have them.
A rider may weigh 45kg and ride a 200kg sports bike thats not that uncommon I suppose.
I have no problem with paddling or man handling a bike of that weight, but a slighter person may have difficulty and hence benefit from a reverse gear.
Whosthedaddy
PostPosted: 18:05 - 04 Jul 2007    Post subject: Reply with quote
With a button probably.
Evo
PostPosted: 18:18 - 04 Jul 2007    Post subject: Reply with quote
I started my RS50 in reverse if that counts Laughing (Reverse Bump)
Lost my balance and barely staid on. It was a new thing to me so had to try it.
Can you start all bikes like that ? Running the drive(While in gear) in reverse then trying to start it and it goes backwards.
Surely it causes unwanted damage however.
Bikes owned
1989 VFR 400 RR NC30
Ariel Badger
PostPosted: 18:18 - 04 Jul 2007    Post subject: Re: Should bikes have a reverse gear? Reply with quote
Why on earth would you want to push a Busa up hill backwards?
LeeWat
PostPosted: 19:13 - 04 Jul 2007    Post subject: reverse gear Reply with quote
A bloke at work has a Goldthing and he told me his reverse gear is done by the starter motor, so the reverse is used before the bike is actually started. As to the electric mainstand, the one on his is an hydraulic one (called landing gear) and operates at slow speeds aswell to stop him dropping the 1/3 of a ton bikecar (stabilisers come to mind).
Lee.
Fahd, you can balance a bike backwards when you've riden them long enough, i never have a problem with my bulldog going backwards up the incline behind my garage, except when its wet and slippy like now Shocked
Simson S51 Enduro, Kawasaki AR80, Yamaha RD125LC, Yamaha XV535, Yamaha XJ600N, Suzuki GS1100G, Kawasaki KLR250, Yamaha BT1100 Bulldog (4/4/08 Deceased). Suzuki XF650 Breakwind.
PostPosted: 20:09 - 04 Jul 2007    Post subject: Re: Should bikes have a reverse gear? Reply with quote
A Hayabusa isn't /that/ bad as far as weight goes, however the obvious thing to do would be to turn it around and use the engine, if it's an issue Smile.
As mentioned, it's not going to be fun to go at any speed using an actual 'reverse gear'.
Lone-Wolf
PostPosted: 20:11 - 04 Jul 2007    Post subject: Reply with quote
Wotcha.
My Cossack outfit had a reverse gear. Excellent for screwing the head up on car drivers Laughing They just don't expect the thing to go backwards.
Cheers.
L.W. - www.moonshiners.org.uk
Finglonga
PostPosted: 21:12 - 04 Jul 2007    Post subject: Reply with quote
Isn't it run off the starter motor though so not as such a reverse gear?https://img.photobucket.com/albums/v112/finglonga/Finglonga%20Inc/ne_nau.gif?t=1176536532
Andy Sez....
F.Y.Y.F.F.
colin1
Captain Safety
PostPosted: 21:16 - 04 Jul 2007    Post subject: Reply with quote
reverse gear wouldnt be dangerous, but it would be an added expense that many bikers wouldnt want to pay for
heavy touring bikes being the exception i guess
PostPosted: 22:22 - 04 Jul 2007    Post subject: Reply with quote
Many 2-strokes will run backwards if you bump them that way or if you overadvance the ignition to a massive degree. 4-strokes will not.
It's easy enough to coast a bike backwards down a slope, riding one backwards under power is nigh-on impossable. I tried it on my mates police Ural which has a reverse gear lever on the drive-shaft, designed for use with a sidecar. It was an entertaining experience.
BorderHooner
PostPosted: 23:30 - 04 Jul 2007    Post subject: Reply with quote
Hayabusa heavy? I'm 5ft 8"-12st 4lb and have no problem at all man handling my Busa. Then again I could just be strong, I simply bent down and lifted my Firestorm up after dropping it on the verge.
Reverse gears are obviously for wimps.
Benelli. Happy as a pig in cacky.
Diggs
PostPosted: 23:40 - 04 Jul 2007    Post subject: Reply with quote
The trick is to push them downhill only!
Incidentally, i saw a Goldwing with stabilisers last week on the Huddersfield ring-road. I was about to cross as this Wing pulled up - as it did, stabilisers appeared from either side and before the bike actually came to a stop, they were down and taking the weight. I watched the bloke set off, and within a few yards they had retracted once more...
Off topic I know, but relevant in a roundabout kinda way...
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
funmonkee
PostPosted: 00:24 - 05 Jul 2007    Post subject: Reply with quote
My Vmax is fairly heavy, but I can pick it up. You just have to think a bit ahead and don't park up pointing down hill etc... always roll back into a space Thumbs Up
I see alot of people trikin vmax etc and always wondered if what trouble they get into without a reverse gear... Question
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
lozzypop1
Certified MILF!
PostPosted: 04:02 - 05 Jul 2007    Post subject: Reply with quote
I think it would be a bad idea.
Car drivers already blame each and every accident they can on the motorcyclist, imagine how pleased they would be if they could rear-end people then say that the rider reversed into their car? Wink
krebsy
PostPosted: 10:33 - 05 Jul 2007    Post subject: Reply with quote
It would be handy for the occasional time when you've parked down a sloping driveway and there's not enough space to turn around (like my folks).
My Garage is up a slight incline with a raised angled kerb and I normally park forwards then roll downhill back out, but If I'm working on the bike or cleaning it on the hard standing on the garden side then it would be handy to be able to reverse it into the garage. manhandling it up the slope is hard because as soon as it reaches the dropped kerb it takes a hell of a lot of effort to get it into the garage.
Then again, I might just fit a slow winch instead and draw it into the garage that way.. Wink
K.
1280 x 1024.
Spoon261
PostPosted: 13:05 - 05 Jul 2007    Post subject: Reply with quote
The starter motor sounds an interesting way to reverse a bike.
I assume the starter motor is a normal DC electric motor, so if you reverse the polarity, the motor will spin the other way and reverse the engine.
Does it hurt a 4 stroke to go backwards, with the spark plug turned off?
DEN MONKEY
PostPosted: 13:09 - 05 Jul 2007    Post subject: Reply with quote
Being a short ass and feelin like a retard tryin to paddle backward up hill, I wouldn't mind it.
I always manage though. Get off and push the bastard
meh
Ravo
PostPosted: 15:45 - 05 Jul 2007    Post subject: Reply with quote
Goldwing = Cadillac of motorcycles. Once you get old the comfort offered by a Goldwing is second to none. Hell, when you're touring that comfort is second to none. Well, maybe the Valkyrie.
Tarmacsurfer
PostPosted: 15:57 - 05 Jul 2007    Post subject: Reply with quote
As pointed out, on a sequential then yes a reverse may well be dangerous. On the early UK RD250 DX there was a blanked off 6th gear, many people used to open them up and remove the blank. The only problem with this was the fact that unless you did it *exactly* right then you'd end up with a box that would go from 6th to 1st in one jump. Not funny. On the other hand, many if not most "bikers" seem happy to spend many thousands of pounds a year on new brake disks (ie the latest model) and a set of race rep leathers and lid. I really don't think that the cost argument holds water here.
The wings are indeed reversed on the starter motor, some of the bike engined project cars use the same approach.
I'm immortal. Well, so far.
The last post was made 19 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 130.61 Kb
