| Jamie S |
 Jamie S World Chat Champion
 Posted: 23:47 - 03 Jul 2007 Post subject: Reverse gearing .. for a laugh ....? |
If I take my gear leaver off, turn it 180degrees and put it back on would it become 1 up 5 down ?
My gear lever is only one spline btw, it does not have linkages ect. .
Cheers.
If that woukd work I can see some tricking of family and friend's coming along ....  |
| stinkwheel |
 Posted: 00:09 - 04 Jul 2007 Post subject: |
Commonly done on some Japanese classic racers (noteably CB350s). They fit rearsets then flip and shorten the gear lever so it a) reaches and b) Gives 'racing change' which is indeed up for down and down for up. This allows changing up at silly lean angles where you couldn't get your toe under the lever and also makes it easier to change up when the front end is lifting.
If you do it on your normal bike, you won't be able to reach the gear lever unless you move the footpegs. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Jamie S |
 Posted: 00:13 - 04 Jul 2007 Post subject: |
I have got an old (snapped ) gear lever for my bike so will cut it and weld it so it misses the footrest , cheers for confirming that stink wheel , will have a bash at it tomorrow.
| ColdInsomnia |
 ColdInsomnia World Chat Champion
| Gazdaman |
 Gazdaman I did a trackday!!!
| Jamie S |
| G |
 G The Voice of Reason
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 12:08 - 04 Jul 2007 Post subject: |
| LeeWat |
 LeeWat Nitrous Nuisance
 Posted: 18:01 - 04 Jul 2007 Post subject: Reversing Gear Shifter |
Seeing as its on a spline with no linkage, no it wouldn't work.
A mate of mine had some weird 125 suzuki a long time ago that was all down, i kept putting it in neutral when i tired to change to 2nd, much revving of engine and paddling ensued.
Just re-read your post, you wouldn't be able to shift gear as the bit you put your toe under would be facing the engine  ____________________ Simson S51 Enduro, Kawasaki AR80, Yamaha RD125LC, Yamaha XV535, Yamaha XJ600N, Suzuki GS1100G, Kawasaki KLR250, Yamaha BT1100 Bulldog (4/4/08 Deceased). Suzuki XF650 Breakwind.
| Resurrection |
 Resurrection Ballast Boy
| Jamie S |
| Jamie S |
| Ariel Badger |
 Ariel Badger Super Spammer
 Posted: 18:25 - 04 Jul 2007 Post subject: |
5n1 does not sound a good idea  ____________________ Bikers make great organ donors, get 115 on your licence today. |
| LeeWat |
 Posted: 19:03 - 04 Jul 2007 Post subject: Gear shifter |
Jamie, just realised what you meant, putting the shifter on as in facing backwards, In my demented mind i read it as just rotating it through 180 so the toe bit was facing inwards
Sorry m8 my mistake.
Lee ____________________ Simson S51 Enduro, Kawasaki AR80, Yamaha RD125LC, Yamaha XV535, Yamaha XJ600N, Suzuki GS1100G, Kawasaki KLR250, Yamaha BT1100 Bulldog (4/4/08 Deceased). Suzuki XF650 Breakwind. |
| mr.z |
 mr.z World Chat Champion
 Posted: 19:25 - 04 Jul 2007 Post subject: |
Boring old fart comment here...
as i see it your much more likely to need to slow down in a hurry, last thing you want to be doing is fumbling for gears when your engine braking desperately trying to slow down.. this maybe doesn't apply to most of you with them new fangled working brakes but if you've ever ridden a heavy bike with woefully inadequate brakes, or a cg125, then you'll understand. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| -Savage- |
 -Savage- World Chat Champion
 Posted: 21:09 - 04 Jul 2007 Post subject: |
I know what you mean mr.z, the front disks on my CBR were well warped, so I didn't like using them so generally it was engine breaking, locking the rear coming into a corner became a nice trick lol, ____________________ My Bikes - - - Royal Enfield 500 with sidecar, VFR800, CBR600FX,
Peugeot Speedfight 100, Kymco Hipster 125, GSXR750K5, Jawa TS 350 |
The last post was made 18 years, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
