| repiV |
 repiV Spanner Monkey
| Chriss |
 Chriss World Chat Champion
 Posted: 22:30 - 02 Jul 2007 Post subject: |
Biggest thing I like steering dampers for is just stabilizing the bike round fast corners.
Probably does stop tank slappers, but you wouldn't know when it does it. ____________________ TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old. |
| repiV |
 Posted: 22:45 - 02 Jul 2007 Post subject: |
Well, that's fine by me - so long as I can power out of a corner without dreading the possibility of a tankslapper.
Usually you can get a feel for what the bike is capable of and how far you can push it in any given situation, but with tankslappers, the response from the bike is just so disproportionate to the input given. It's not something you can really feel out...if I managed to get tankslappers performing moderate to fairly brisk maneuvers on a Fazer and a Bandit, how do people manage to hoon litre sportsbikes without it happening constantly?  |
| i_am_tim |
 i_am_tim Nitrous Nuisance
 Posted: 22:48 - 02 Jul 2007 Post subject: |
you might struggle finding a fitting kit for a bandit, they arnt really know as the most flightly bikes around
but a worthwhile investment if you can a damper for my R6 is top of the list at the moment, but they are particuarly unstable when accelerating ____________________ previous bike: 2000 Aprilia rs 125 - SOLD
current bike: 2001 Yamaha R6 - sweeeeet |
| repiV |
| i_am_tim |
| repiV |
| Kickstart |
 Kickstart The Oracle
 Posted: 23:21 - 02 Jul 2007 Post subject: |
Steering damper can help, but really don't think one should be needed on a Bandit.
I would say neither of the things you have experienced are tank slappers. Sound more like over hard acceleration and having the back step out. And a steering damper would do nothing about that.
Proper tank slappers are pretty rare and also often VERY violent (violent enough to do you a serious injury even without falling off).
| repiV |
| Bullet |
 Bullet Trackday Trickster
| D O G |
 D O G World Chat Champion
 Posted: 23:48 - 02 Jul 2007 Post subject: |
I think we're not really talking about tank slappers here - i.e. when the slight shake of the head magnifies and transmits its way through the bike causing violent and uncontrollable nastiness.
A bit of head shake is quite nice really - I like the feeling when I get a bit of head nodding, tells you the bike is working a bit, ready for the ride etc...but maybe that's just me...
I read in Keith Code's book (written well before steering dampers were commonplace) that a slight headshake is necessary for the bike to work out the forces being applied to it, and isn't something to be scared of. Just don't grip the bars tight and rigid, which starts transmitting the vibration back to where you don't want it!
Learn to like it, don't bother with a steering damper, listen to what your bike is telling you, a steering damper simply takes a bit of information away from you. |
| Kickstart |
 Posted: 23:51 - 02 Jul 2007 Post subject: |
No way should it break traction going from 2nd to 1st (assuming you are not just stamping it down the box with the revs somewhere silly).
A tank slapper is caused when the bars shake a bit, and happen to hit their natural resonant frequency so start shaking very hard, likely hitting the lock stops. This is not the odd shake, more like half a dozen times a second with little hope you could hang on to them (and the possibility of a dislocated shoulder if you try).
Rather different to the bars shaking a bit.
A few bikes do suffer from it and need a steering damper to suppress it (but a steering damper will adversly affect low speed handling). Generally though that is bikes that have very sporty geometry. Not the restrained geometry of something like a Bandit.
The first time it happened your description sounded more like you wound the power on and the bike broke traction and the back tried to overtake the front (possibly followed by you shutting the throttle violently and the bike reacting by snapping back into line violently). Hence my comment.
While one bike might misbehave (eg, low tyre pressures, badly adjusted suspension), having 2 seperate and very different bikes do so tends to suggest they are not the problem.
| yzf750r |
 yzf750r World Chat Champion
 Posted: 06:42 - 03 Jul 2007 Post subject: |
just bought one for my ZX10R and ive put one on nearly everybike I have had.
I really dont need to smash my bike up and ive had a few slaps but just had to grit teeth and pull straight through them.
 ____________________ 04 zx10r with mods - 187.4bhp at the wheel! :o |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 10:47 - 03 Jul 2007 Post subject: |
As it's only a Bandit I would suggest checking things like tyre pressures, forks, bearings before splashing out on a damper. ____________________ My Flickr |
| sickpup |
 sickpup Old Timer
| repiV |
| repiV |
| Blau Zedong |
 Blau Zedong Banned
| repiV |
 Posted: 22:01 - 03 Jul 2007 Post subject: |
| Kickstart wrote: | Hi
I was probably going about 25mph at the time, so around 5-6k revs.
There's something seriously odd about the Bandit's handling in the wet. I've ridden a CG125, a GN125, a CB500 and two different models of Fazer and they've all handled fine in the wet. On those bikes I didn't have to adjust my riding much at all and the only time I ever lost traction on the rear was going round a corner in the pissing wet on my DAS and went over a manhole cover.
I'm really, really careful with it the Bandit in the wet, to the point that I hold cars up at times, but it's still a regular occurence. When I first noticed it I put it down to the tyres needing to be scrubbed in more but 900 miles later it's still dodgy.
I keep hassling the hire company to give me another Fazer but they're always on hire all the time.
| Quote: |
Referring to the incident on the Fazer, it did shake very hard (enough to slam the footpeg into the ground and bend it 90 degrees, throwing me off in the process), but it certainly wasn't anything like half a dozen times a second. I watched a video of a tankslapper (the one at the TT, on youtube) and it looked like pretty much the same thing happening only not as quickly.
| Quote: |
It was more of a wobble than a shake - it gave some noticeable steering input. Or is that what you meant?
| Quote: |
Hmm, if it buggers up the low speed handling that's pretty much put me off. London after all.
Oh, I can say, the one thing I actually like about the Bandit is that it's incredibly well balanced. I can ride it in a straight line at 1mph without taking my feet off the pegs, and balance it at a standstill for a few seconds...it's much easier to ride at very slow speeds than the Fazer.
| Quote: |
Hmm, could well have been. Although it didn't just swerve violently once - it was a repeated oscillation that got more and more violent each time. I suppose it lasted several seconds before it had me off.
| Quote: |
Keith |
Aye...
I just want to know how to prevent it really, I get a lot of pleasure from winding the throttle back.
Maybe this time it was related to the shitty grip on the rear tyre? |
| Chriss |
 Posted: 10:36 - 04 Jul 2007 Post subject: |
Hi, if you want to buy the standard steering damper off my SV, give me a shout.  ____________________ TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old. |
| repiV |
 Posted: 22:33 - 04 Jul 2007 Post subject: |
I'll defo let you know if I do decide to go down that route...how much ££ btw?
On a sidenote, I swapped the Bandit for an '06 FZ6 today. It feels like a prototype of some kind...like a fly-by-wire bike of sorts and they haven't quite worked out the kinks yet. Handles brilliantly, extremely well balanced, great design, but that bloody useless fuel injection...it's like riding a bucking bronco. It's hard work to ride quickly due to the revvy engine and hard work to ride slowly because of the snatchy throttle.
The whole setup just doesn't feel natural. It's like you twist the throttle and the message gets distorted along the way...
I definitely won't be buying an FZ6...although in its defence, at least it's not snore-inducing like the Bandit. Give me a Foxeye any day.  |
| dainesefreak |
 dainesefreak World Chat Champion
 Posted: 08:33 - 05 Jul 2007 Post subject: |
Buy a Blade, get a free damper.  |
| Kickstart |
 Posted: 13:17 - 05 Jul 2007 Post subject: |
| repiV wrote: | I was probably going about 25mph at the time, so around 5-6k revs. |
If you just knocked it down without blipping the throttle then that is easily enough to break traction in the wet. Do it while leaning and the back will slide out.
| repiV wrote: | Referring to the incident on the Fazer, it did shake very hard (enough to slam the footpeg into the ground and bend it 90 degrees, throwing me off in the process), but it certainly wasn't anything like half a dozen times a second. I watched a video of a tankslapper (the one at the TT, on youtube) and it looked like pretty much the same thing happening only not as quickly. |
Afraid that doesn't make much sense. To lean over far enough to ground the pegs hard means going over a long way (especially considering in such a situation you describe the suspension would not have compressed in time, so far more ground clearance). Added to which going forward it would push the peg up against its spring loading.
Something else must have interferred to cause the damage.
| repiV wrote: | It was more of a wobble than a shake - it gave some noticeable steering input. Or is that what you meant? |
Yes, just normal bar shaking. Used to be able to trigger the Divvy to do it quite easily when the front wheel bearings were very slightly iffy.
| repiV wrote: | Hmm, if it buggers up the low speed handling that's pretty much put me off. London after all.  |
Just makes turning the bars, well, damped. Like the front wheel is embedded in porridge.
| repiV wrote: | Maybe this time it was related to the shitty grip on the rear tyre? |
Tyre should not be that bad. Put it this way, I am 100% certain the tyre has far more grip in the wet than the ones on my FZR600 I use for commuting (some old Sportmax radials).
| .Chris. |
 .Chris. World Chat Champion
| cc123 |
 cc123 Geez a joab?
 Posted: 16:32 - 05 Jul 2007 Post subject: |
Got a Sprint one on my R6, great piece of kit now I can fully appreciate it.
Some roads I've done on the Ninja's the bars used to wiggle like mad on fast rippled section and low gear, agressive overtakes but now on the R6, nothing. It hasn't slapped me about at all. In town riding I spool it right off so its easy to steer then spin it up a few notches for the faster, bumpier stuff.  ____________________ Old bikes >>> https://www.bikepics.com/members/cc123/ |
The last post was made 19 years, 75 days ago. Instead of replying here, would creating a new thread be more useful? |
