Ticking head.
Purplepill
PostPosted: 13:47 - 05 Jul 2007    Post subject: Ticking head. Reply with quote
ok im getting my bike serviced next thursday as there is a quiet ticking noise coming from the head, more noticable when cold at low rpm. Im having the valve clearances reset, he's checking the CCT, balancing the carbs, checking cylinder compression and replacing sparkplugs (had oil and filter done a few weeks ago).
So my question is, could riding the bike until thursday damage the engine if its just the valve clearances that are out? theres no loss in performance, and too be honest the ticking isnt too noticable?
any help appreciated Razz Karma
''He had the confidence of a baby-goat dared to tickle a t-rex's nutsack''
Barry_M2
PostPosted: 15:03 - 05 Jul 2007    Post subject: Reply with quote
It does sound like the valve clearances. If they are only out a slight amount, riding it is not a problem.
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
TheShaggyDA
Repost Police
PostPosted: 17:10 - 05 Jul 2007    Post subject: Reply with quote
As long as valve clearances are ok at the normal riding temperature, then if they are a bit noisy when cold it's nothing to worry about. The normal "don't thrash it until it's warm" applies really Smile
gavin
PostPosted: 18:08 - 05 Jul 2007    Post subject: Reply with quote
leaking exhaust gasket? just had something similar on my transit van! thought it was valve clearances but it turned out to be the exhaust gasket.........
1988 TZR125 : 1990 RD350YPVS/ RGV250 HYBRID : 1982 RD80LC : 1983 RD80LC : 1994 RGV250 : 1991 TZR125 / CR500R HYBRID : 1976 BENELLI 500 QUATTRO : 2006 TRIUMPH 675
Purplepill
PostPosted: 21:33 - 05 Jul 2007    Post subject: Reply with quote
Ok cheers people Smile hadnt thought about the exhaust gasket but il look into it Thumbs Up
Jamie S
PostPosted: 23:27 - 05 Jul 2007    Post subject: Reply with quote
Or the cam chain....
Dalemac
PostPosted: 14:24 - 06 Jul 2007    Post subject: Reply with quote
most likely the valve clearances. Cam chain would probably snap before long if it was that.
Mine is in for a service today, has had the tappety noise for over 1200 miles, told the dealer when it started but they said it was fine and i will kick up a big fuss if they dont check the clearances as its really the only reason im letting them service it Wink
YBR125 -> GPZ500S -> SL1000
veeeffarr
PostPosted: 14:30 - 06 Jul 2007    Post subject: Reply with quote
If it's a Honda CBR600F then it's the CCT that needs replacing (£50)
If the ticking still persists when the bikes warm it's a new camchain (£100)
You can pop the CCT out yourself and clean and put back in, don't quote me but I think you can use brake fluid to clean the CCT.
T
Purplepill
PostPosted: 14:37 - 06 Jul 2007    Post subject: Reply with quote
Cheers toby, the CCT has been replaced before, but at 38K miles i suppose it could be it again, but the noise does persist when the bikes warm so i now think its the cam chain which to my knowledge hasnt been changed before, but im guessing it has at some point.
So il get him to have a good look at the cam chain Thumbs Up .
Also if it is the CCT and cam chain instead of/aswell as valve clearances that need sorting, what effect could riding it until next week have? if it was your bike would you not ride it because of this?
veeeffarr
PostPosted: 15:21 - 06 Jul 2007    Post subject: Reply with quote
Erm if it's ticking when warm I wouldn't risk it mate, how many miles are you thinking of doing? I'd probably van it to the garage.
Purplepill
PostPosted: 16:55 - 06 Jul 2007    Post subject: Reply with quote
about 150-200 miles, if need be i can take it to the garage now and leave it there until next week, i just dont want to be back on the old BMX again Embarassed
Jamie S This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
veeeffarr
PostPosted: 17:44 - 06 Jul 2007    Post subject: Reply with quote
jamie stokes wrote:
It's £25 for a cam chain toby.
Yeah thanks for that Jamie and how much for the mechanic to fit it as well?
Could you find me a VFR750 camchain for that price as well? Very Happy
Jamie S
PostPosted: 17:53 - 06 Jul 2007    Post subject: Reply with quote
If you want me to , give me 10 mins.
EDIT: what year ?
Bell end.
The cam chain was later dropped from the VFR in favor of gear driven cams
Embarassed
veeeffarr
PostPosted: 18:03 - 06 Jul 2007    Post subject: Reply with quote
ROFL Very Happy
Purplepill
PostPosted: 14:49 - 07 Jul 2007    Post subject: Reply with quote
Ok i took it in to the mechanic early, just to get his opinion on the noise,and to my relief,apparently it cant be the cam chain or sprockets as the noise isnt coming from there? he also said that the noise is hardly noticable and nothing to worry about and that the service next week will sort it (got new CCT for £30 anyway so might aswell fit that to), so maybe its just me being paraniod an its just slight valve noise? (im new to 4-strokes Embarassed ).
Oh well i guess il find out on thursday Thumbs Up cheers anyway people Wink .
eddclarke
PostPosted: 17:30 - 07 Jul 2007    Post subject: Reply with quote
My xr125 is doing the same, and that is going in for a service on friday, If its the cam chain will it be covered by the warranty?
Honda XR125L 06 ----> Yamaha FZ6 05 + ex SAS XR250 --> VFR800 + XR250r
Jamie S
PostPosted: 17:52 - 07 Jul 2007    Post subject: Reply with quote
Er ....... if you have gone through a cam chain and its new enough to have a warranty then there is something drastically wrong inside the engine.
Cam chains should last years.
eddclarke
PostPosted: 18:04 - 07 Jul 2007    Post subject: Reply with quote
Well i dont know if it is the cam chain, but i went to top up the oil and it seemed bone dry... and now there is a ticking, valves?
grassby2001
PostPosted: 18:39 - 07 Jul 2007    Post subject: Reply with quote
my bike has air injection fzr600 exup and 2 of the air injection that connects to near exaust outlets come out every so ofter and that dose a loudish clicking
just a thought you may have air injection?
https://www.bikepics.com/members/grassby2001/Default.asp
Practice safe sex....go fcuk yourself. Smile
https://www.swapz.co.uk/
eddclarke
PostPosted: 10:05 - 08 Jul 2007    Post subject: Reply with quote
nope, this is on the xr125 which is carb'd, not my fz6
Purplepill
PostPosted: 13:05 - 08 Jul 2007    Post subject: Reply with quote
its got direct air induction lol dont know if thats what you mean?
TGR
PostPosted: 00:50 - 12 Jul 2007    Post subject: Reply with quote
I've got the same kind of problem on my sachs and its booked in for a service in a fortnight! so do you think a 12 mile ride to the garage would be ok?
Thanks in advance
1991 Kawasaki ZXR400L - 1999 Suzuki GS500E - 1990 Kawasaki ZX750R H2 - 1991 Honda CBR 600 - 2015 Skyteam Monkey 125
Jamie S
PostPosted: 07:58 - 12 Jul 2007    Post subject: Reply with quote
Thanks in advance
12 Miles , take it easy and it should be fine , would be risky if you thrashed it all the way there though.
sickpup
Old Timer
PostPosted: 11:17 - 12 Jul 2007    Post subject: Reply with quote
No its £42+vat + P+P according to Dave Silvers. Also factor in the cost of a couple of gaskets, probably £15-£25+vat and the price starts to look a lot higher.
The last post was made 16 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.24 - MySQL Queries: 16 - Page Size: 132.2 Kb
