| mhenry9885 |
 mhenry9885 L Plate Warrior
| alains |
 alains World Chat Champion
| mhenry9885 |
| alains |
| mhenry9885 |
| alains |
| mhenry9885 |
| alains |
 Posted: 15:28 - 12 Jul 2007 Post subject: |
the motor of the servo is fed under 12V but the servo potentiometer is fed under 8V (may be it's your last mesurement)
i will explain the colours :
- white & black/white motor feed , applying 12V will move the servo in one way and reversing polarity in the other way
- white/red & green/blue servo potentiometer ends (fed under 8V with a value of 6KOhms +-10%)
- light green servo potentiometer cursor
the 3 other wires are coming from the loom and go to the control unit , they are :
- black +12V from the key switch
- green - 12V from the key switch
- red/white coming from the CDI , it tells the unit at which RPM the engine is (a loose contact at both ends can generate this bug)
download my file https://www.geneva-racing.com/~alains/NSRtips.doc , you will find how works the servo
if you've any question , do not hesitate ____________________ the worst day fishing is better than the best day working |
| mhenry9885 |
| alains |
 Posted: 09:47 - 09 Aug 2007 Post subject: |
when you put key on the pulley must go on HI and stay there at idle if you are under 2000 rpm , when you accelerate the pulley must go on LO , because closing the valves at this point increase the torque in order to help killing the bike inertia . when your bike begins to fly at 7500 the valves must open to allow more rpm otherwise the engine will splutter (pulley goes to HI)
so something should be wrong with your wiring check it again
https://www.geneva-racing.com/~alains/schema_R.jpg ____________________ the worst day fishing is better than the best day working |
| mhenry9885 |
| alains |
The last post was made 18 years, 337 days ago. Instead of replying here, would creating a new thread be more useful? |
