Common Places to mount an immobiliser
snakeman65
PostPosted: 18:42 - 17 Oct 2003    Post subject: Common Places to mount an immobiliser Reply with quote
Hi people.
I recently bought myself a yamaha RS125. Just need it for commuting.
However, it has an immobiliser. To be precise, a Taurus T3000. Unfortunately, the dealer did not have the certificate for it and only had one key!
I'm trying to get hold of a new key, but to do this, I need the serial number of the control unit. I've stripped the bike down as much as I can and I cant spot it anywhere!!
Does anybody know where these things are usually mounted? I tried tracing the wires from the ignition but they get lost in with all of the other electronics!
Cheers,
Chris
McJamweasel
BCF Junkie
PostPosted: 18:44 - 17 Oct 2003    Post subject: Reply with quote
Not sure I want to answer this one....
BCF: Be yourself, just don't be an arse.
TiN
Pocket Tin
PostPosted: 18:45 - 17 Oct 2003    Post subject: Reply with quote
They are usually located "under the seat", but I don't think that's very feasible on the Yam RS. Razz ...having said that - could it have been somehow integrated in the seat block? It should almost certainly be located away from engine and exhaust.
TiN
dotgems.net
Demonic69
The Pink Rhino
PostPosted: 18:48 - 17 Oct 2003    Post subject: Reply with quote
Erm, My serial no is on the back of my key and I have a taurus.
Back on a Blade. Just feels so right.
snakeman65
PostPosted: 21:59 - 17 Oct 2003    Post subject: Reply with quote
Hmm, i've looked at my key and its just got two screws in the back and a little no 1 on the front. That is all under the insulating tape that is holding it together though!! (hence why I feel that I really need a spare key!!!).
When you say the seat block, where exactly do you mean? I have taken the seat off and I can't see any wires near the top of the bike where the seat was.
I think tomorrow i'll have to unclip and cut the ties round all of the wires and trace it back properly Sad
Cheers for your help.
P_J
PostPosted: 12:28 - 18 Oct 2003    Post subject: Reply with quote
I had a T3000 fitted on my NSR from new, the unit is mounted behind the right rear faring. You can see it when you remove the seat but you have to remove the fairing to get to the unit.
Obviously its going to be different on your bike.
The unit looks like a small black metal box with an enlarged 'base plate', presumably to screw/attatch it to the bike. (Just in case you aint found it yet.
PJ
Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk
TiN
Pocket Tin
PostPosted: 16:23 - 18 Oct 2003    Post subject: Reply with quote
Hmm, if you can fully detach the seat unit, then I guess that it isn't hidden in there (otherwise the wires will probably give it away). Are you absolutely sure that there is an immobiliser on there? Try hotwiring it to check...
TiN
dotgems.net
The last post was made 23 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 52.04 Kb
