Bros 400 chain adjustment
mr jamez
PostPosted: 23:49 - 06 Jul 2007    Post subject: Bros 400 chain adjustment Reply with quote
As the Bros has a single sided swing arm do I need any special tools ie a big C spanner like the VFR? how different is the procedure? I don't think I have much of a chance at the moment considering the size of the nut.
Smile
NSR 125F > BROS 400 > NC30 > BROS 400 > Trumpet S4 > '97 VFR 750
Paddy Blake
PostPosted: 01:25 - 07 Jul 2007    Post subject: Reply with quote
Loosen the 17mm bolt then put a long screw driver or the like in to the
slots in the adjuster and line it up with a nut at the back of the sprocket
then hold it tight and turn the wheel backward moving the screw driver
as you feel it being pulled down.
Paddy.
mr jamez
PostPosted: 09:05 - 07 Jul 2007    Post subject: Reply with quote
Cheers, I'll give it a go later Smile
carvell
Scuttler
PostPosted: 11:54 - 07 Jul 2007    Post subject: Reply with quote
Wot he said, although you're supposed to use a C spanner, not a screwdriver.
Manual here:
https://www.hawkworks.net/manual/3.html#3-12-chain-adjustment
Yamaha TDM 850
mr jamez
PostPosted: 18:34 - 03 Aug 2007    Post subject: Reply with quote
Not having much luck with this. I couldn't move the 'eccentric bearing carrier' with a screwdriver so ordered a C-spanner from wemoto, no luck.
I'm wondering if they sent my the correct tool, it slips very easily, how hard is this thing to turn because it won't budge even with a 'tap' from a screwdriver and hammer.
Paddy Blake
PostPosted: 20:22 - 03 Aug 2007    Post subject: Reply with quote
The slots are easily damaged and someone could have hammered it
before.
Put the C spanner in different places to find where a good slot could be.
Paddy.
The last post was made 19 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 47.13 Kb
