| pwntifex |
 pwntifex World Chat Champion
 Posted: 00:32 - 10 Jul 2007 Post subject: MTB Diagnosis |
Not sure which section to put this in actually
Anyway, was out on my mtb earlier and after a couple of casual kerb jumps and a bit of rough terrain, the front end suddenly started squealing whenever I turned the bars.
My first thought was 'headstock bearings'. Is this likely to be correct?
Is it an easy job to do on most MTBs? Don't fancy putting it thru the local bike shop, they charge mucho moolah.
Ta ____________________ the warped one: This is a follow up from the thread 'my willy hurts' |
| rzren |
 rzren Renault 5 Driver
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 10:14 - 10 Jul 2007 Post subject: |
Make sure you rule out an obvious cause like a caught or trapped brake cable  ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| KLR600 |
 KLR600 World Chat Champion
 Posted: 11:59 - 10 Jul 2007 Post subject: |
Do you have disc brakes? If so give them a good going over.
Working on MTB's is really easy, you only need to undo 5/6 allen key bolts and the forks will drop out. I'd re-grease all the headset bearings and check all around that area but I'd be surprised if it was that causing a squeal. ____________________ Now: '00 Kawasaki ZRX1100R - Past: '84 Yamaha DT125, '89 Kawasaki KLR600, '97 Yamaha XJ600N
<Take Cool Photos!> |
| fenton |
 fenton World Chat Champion
 Posted: 12:12 - 10 Jul 2007 Post subject: |
Take all the headstock apart, make sure all the bearings are still in place. I know its unlikely, but when i last took the CB apart to spray it i was missing four or five. get a rag and clean out all the inside of the frame. then do the same with the forks. Make sure nothings bent and or missing. Then grease them back up. I know what you mean by its squeaking because i had exactly the same problem but with the GT this time. ( i do tend to rag my bikes ) I did all of the above, and it seemed fine.
If that doesnt work take your wheel hub apart and clean and re grease that. it could be that youve bent the pin.
Fenton  ____________________ PEANUT BUTTER JELLY TIME!!!!! I cannot be held liable for anything that i post.
CBR400RR NC29 ( '06 - '09 )... TL1000 RK1 ( '10 - present ) |
| KLR600 |
 Posted: 12:24 - 10 Jul 2007 Post subject: |
Having thought about it a little bit more I realised it could be your headset cups (the ones pressed into the frame) moving very slightly in the frame causing the squealing. The only way to check this though is to replace the headset, perhaps with one that has longer cups that go further into the frame. It's also a bike shop jobbie as they have a special tool for pressing headsets into frames to make sure they go in straight. ____________________ Now: '00 Kawasaki ZRX1100R - Past: '84 Yamaha DT125, '89 Kawasaki KLR600, '97 Yamaha XJ600N
| pwntifex |
 Posted: 13:28 - 10 Jul 2007 Post subject: |
I went up and down the road on it about ten minutes ago, tried everything from sedate riding to throwing it about, but couldn't replicate the sound.
Now that I think about it, it was less of a squealing and more of a sort of rubbing sound, as if the brake pads were locking onto the wheel, but it only happened when the bars were turned. It may have been a trapped cable as Daz mentioned, iuno.
There was a faint sort of hint of it earlier, but nothing major, so I'm not too worried.
I'll have to give it a good going over when I receive all my shiny new bits in the post, though.
Thanks for the advice, you guys. Karma all round! ____________________ the warped one: This is a follow up from the thread 'my willy hurts' |
| Cigaro |
 Cigaro World Chat Champion
 Posted: 09:32 - 11 Jul 2007 Post subject: |
I had a similar thing on my MTB, turned out to be a bent front wheel that was binding on the brakes  |
The last post was made 18 years, 231 days ago. Instead of replying here, would creating a new thread be more useful? |
