Carb Icing
P_J
PostPosted: 21:05 - 20 Oct 2003    Post subject: Carb Icing Reply with quote
What is "Carb Icing", and no jokes about cakes or other fine desserts please.
Also, anyone got any ideas why, on the way home tonight, my bike was whistling like it had a turbo. Quite a high note but not a squeal, and seemed to be when reving up and when it was coming down too(what is that called when the rev's are dying down?). It wasnt loud but i could hear it at low speed with visor down, not sure if was still at high speed because of the wind.
PJ
Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk
McJamweasel
BCF Junkie
PostPosted: 21:08 - 20 Oct 2003    Post subject: Reply with quote
Its where the carb gets cold and ices up! Very Happy
Scotty
Scooter Boi
PostPosted: 21:10 - 20 Oct 2003    Post subject: Reply with quote
well the cold air comes through a freeze's up the carb, making things stick :s
Regards
Scott
P_J
which causes?
Damage?
Stalling?
crap performance?
And are we talking the inside or outside parts?
PJ
Only1PJ.co.uk
McJamweasel
BCF Junkie
PostPosted: 21:11 - 20 Oct 2003    Post subject: Reply with quote
The petrol/air going through the carb cools it down. When its cold and damp outside this can mean that the jets get blocked with ice, hence no petrol gets through. And no petrol = .... ?
Scotty
Scooter Boi
PostPosted: 21:12 - 20 Oct 2003    Post subject: Reply with quote
More than likley you will flood engine, not start, have no control over the engine.
all this is what i think i guess
mixture could be all wrong too.
Regards
Scott
P_J
PostPosted: 21:14 - 20 Oct 2003    Post subject: Reply with quote
Exactly that id have thought ... = nothing Smile
So about the whistling then? nothing to do with the above?
PJ
Only1PJ.co.uk
McJamweasel
BCF Junkie
PostPosted: 21:15 - 20 Oct 2003    Post subject: Reply with quote
Dunno. Doubt it.
WildGoose
White Van Man
PostPosted: 21:49 - 20 Oct 2003    Post subject: Reply with quote
cbr got it quite a bit, on cold nights, just ran like a sack of shit, and stalled everywhere
way round it was a cheap heater in garage when you wanted to start so at least it was starting on warm air, then let the bike warm normally
then it would run fine when you took it out
but such hassle just for a ride!
PostPosted: 23:39 - 20 Oct 2003    Post subject: Reply with quote
My old FZ used to suffer from it badly. Would drop from 45mpg to 25mpg, and would not run below 4000rpm.
Basically the fuel being drawn from the carb takes alot of heat with it. Eventually the carb gets really cold and starts to freeze the water in the air going through.
On my old MBX125 I once had carb icing like problems, looked down at the carb and the outside was covered in frost.
Craig_
PostPosted: 23:51 - 20 Oct 2003    Post subject: Reply with quote
Carb Icing is where you get the icing sug... ahh wait you said no jokes about cakes.
Yeh its just the carbs freezing up and causing a non starter or a sack of shite feeling, wont cause damage, can clear up when engine gets hot.
Heater idea is good to.
VAG Cars - www.vagcars.co.uk - North East VAG Owners Club
McJamweasel
BCF Junkie
PostPosted: 23:52 - 20 Oct 2003    Post subject: Reply with quote
You can get stuff to put in the fuel to help stop it. Dunno if its any good tho.
Do injectors suffer from it as well?
PostPosted: 00:08 - 21 Oct 2003    Post subject: Reply with quote
The additives does work but is expensive.
Most Kawasakis direct some coolant through the carb float bowls to warm them up a touch. Kawasaki had a big problem with carb icing about 15 years ago and had to recall pretty much every liquid cooled 4 stroke they had sold in the UK to fit them with new carbs.
Injectors work at a hell of a preasure. Don't think they suffer from it.
Craig_
PostPosted: 00:12 - 21 Oct 2003    Post subject: Reply with quote
My RS50 had a coolant line running through the manifol to get the heat there.
The last post was made 23 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 83.73 Kb
