Changing Chain & Sprockets
Dan
PostPosted: 13:53 - 23 May 2002    Post subject: Changing Chain & Sprockets Reply with quote
is it difficult to change the chain and sprockets by urself or is it best to go to the bike shop and get it done, i think i can do it myself and dont want to spend 30 odd quid on labour. i did change them ok with my old 50.
cheers
dan Razz
Ryan
PostPosted: 16:08 - 23 May 2002    Post subject: Yep Reply with quote
Id say do it, i dont know much about nsr's but it was easy enough on my RS, just dont forget anything silly like puttig the split link clip on the wrong way .and draw diagrams of how u took things apart if u have a bad memory
McJamweasel
BCF Junkie
PostPosted: 22:28 - 23 May 2002    Post subject: Reply with quote
Yeah man, do it. Its really not that hard, although a paddock stand(and the right size chain) does make it a lot easier.
BCF: Be yourself, just don't be an arse.
Dan
PostPosted: 22:55 - 23 May 2002    Post subject: 1 Reply with quote
yeah i was going to do it myself. is a stand needed ? or can u u do it without? if so how? cos u need to take the whele off dnt u?alri
Ropehead
PostPosted: 00:19 - 24 May 2002    Post subject: Bla Bla Reply with quote
put bricks under each side of the swing arm (and a nice rag) untill its off the ground then slip the wheel out.
Changing it is the easy bit just make sure u get the tension right (should be about 50mm at the slacist point top to bottom) if i'm not right Keith will correct me dont worry,
Then u have just got 2 get the wheel alignment. BOOM
off u go
Hope this helps
PostPosted: 19:47 - 25 May 2002    Post subject: Reply with quote
I would [b[not[/b[ use bricks to hold the bike up. Bricks are bad at taking a concentrated load and will quite possibly suddenly collapse. Very dangerous working on a car, but could lead to damage working on the bike. Use a pair of cheap car axle stands. 50mm is a vit much for the chain looseness. Should be 25mm~35mm (ish) at the tightest point. If you turn the chain adjusters back in each the same number of turns then the back wheel will be no more out of line than it was before
The last post was made 24 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 47.25 Kb
